Originally Posted by maxdef
I opened up my transfer case actuator to see how everything was after wondering how bad mine might be, but I was very surprised to see it quite clean and rust free. There is some visible gunk near the bottom seal line, and it appears to be some gear oil as it looks like old Royal Purple from when I filled it a few years ago. Not quite sure if that's what I was seeing; I've also never had any leaks. I wiped up some of the hardly-firmed grease and added a little more on the visible teeth/gears. A dab of fresh oil on the gasket and mating surface and it was back on.
![](https://i.imgur.com/KrET79G.jpeg)
hi
maxdef
, I ahve a question on another post and maybe you can answer.
" my 4Lo isn't working for a long time. I noticed that the breather hose was disconnected for not sure how long. I don't do off roads or cross flood waters but I understand that moisture can still sip in. When I switch it to 4Lo i can hear the transfer case actuator beeps. I already tried to tap, heat gun, wiggle without success.
Would it be ok to put a couple of sprays of WD 40 right into the breather hose inlet and hopefully lubricate the gears inside??
My 4Hi is working fine but wondering if a couple of WD 40 sparys will damage the electronics inside.
Pls help!
Thanks!"
Is there lots of electronics inside that will be damaged if I sqirt q couple of sprays of WD40? Thanks in advance
