This weekend I replaced sway bar end links and bushings front and rear. Went with Energy Suspension bushings. After driving with them, I'm a big fan.
Tried replacing rear brakes (calipers, rotors, and pads). Pulled the rotor off the passenger side but didn't back the parking brake shoes off first and knocked some stuff loose along with bending a pin that holds some stuff together.
Got the pin out, bent it back in a vise, and got it all back together. Didn't make that same mistake on the driver side. Went to change the calipers and discovered that Rockauto sent me a caliper that wasn't even remotely close to being correct and another that had a hole in the casting exposing the rubber guide pin boot so I had to put it all back together with the old stuff. Good times.
Replaced the muffler and tailpipe with Walker stuff. The original muffler was full of holes around the where the hangers connect to the muffler and the flange between the muffler and tailpipe was toast, which was a shame because the rest of the taipipe was in great shape. The Walker stuff is kinda crappy but it works so whatever. Thought I would have a quiet exhaust after that only to discover the ticking sound I was getting is actually a cracked exhaust manifold. Awesome.
Did an oil change after that since the mechanic the previous owner took it to didn't even bother replacing the crush washer for the drain plug, they just put the drain plug in with no washer at all. Lazy turd.
Drove it for a couple days and then today when I was leaving for work I discovered transmission fluid pouring out the bottom of the skid plate. Pulled the plate to find the same mechanic replaced the radiator and ended up routing the transmission to radiator hoses incorrectly which caused one of them to kink which led to the hose tearing. I really dislike incompetent "mechanics".
I'm starting to think I'm cursed. Or this 4Runner is cursed. Or both.
