Originally Posted by SilverGs
Hi snobrdr033,
1. Can you please elaborate a bit more on what soldering you had to do for the under-running board LED install you did?
2. Do you have any close up pics of the soldering as well as the lights themselves? I want to see how you zip-tied them.
3. Any pics of the LED's on at night?
I'm guessing you hooked them up to the dome light circuit so that they come on when you unlock the doors or turn on the dome light? If not, what did you do?
Sorry for the slow response, I did not check this thread lately.
1. I bought a 30" (I believe that was the length) piece of pre-made LED strip (5000K) and on the actual strip, it has markings where you can cut it to make smaller strips. It has small points where you cut that you can solder wire on, if that makes sense. I was kinda confused until I actually had the LED strip in my hands.
Then I bought some small, 20-22 ga wire to solder on the leads for each individual strip. I also got the small rubber caps that you silicone on the ends to seal it from water/dirt. I ended up with 4 separate LED strips - 1 for under each door. Wire leads were a bit long but easy to zip tie up to hide and still connect, I think I had the leads around 12-18" each, which is more than enough.
2. I didn't take any pics while I was installing or soldering, but can take some now if you'd still like them. I tried to glue and double sided tape the strips onto the undercarriage, however they would not hold longer than a day. So I did some looking around under there and saw small holes from the running boards/plastic rivet type pieces. If you get under and look where you'd place the LED strip, you can see what I am referring to - hopefully, ha.
3. Can take pics of this if you want.
I don't know how to upload pics to the forum here, but can snap them with my phone to show you the close up. Just let me know, I can email too.
I used the 3M "quick connect" splicers to "cut" into the pos/neg wires on each of the running board lights. They come on/off on some sort of a dimmer when you lock/unlock the truck. The LED strips look pretty cool when you lock/unlock since they also dim when turning on and off. Very cool mod and well worth the time for the look and functionality.
Hope that answers your questions.
'05 Black Limited V8 with XREAS / LED Interior & Exterior Swap / Custom LED Ground Lighting Strips Mounted Below Running Boards / HCF Delete / AFE Air Filter (Dry) / Optima YellowTop / DDM Tuning 35W 5000K HID Fogs / Weathertech Digital Floor Liners & Cargo Mat / 20" Enkei Wheels / Tacoma Skidplate / Built In Headrest DVD Monitors with Custom Covers / iPod Adapter / Pioneer AVIC-D3 HU with Navigation / PassPort 9500xi, Hardwired / 50% Tint / Custom White/Blue LED Gauges & HVAC /
Coming Soon: Lift, UCAs, 1.25" Spidertrax (have 'em, just waiting on install)
