08-18-2019, 06:24 PM
#33001
Slowly climbing!
2008 Toyota 4Runner Limited V6
| Spidertrax | OME 886 and Icon Overland Coils | Kenwood DNX9980HD | JL 8W3| HID | Full LED |
| S2000 headlight retrofit | URD Spec U Long Tube Headers | Borla Cat-Back Dual Exhaust | 5th Gen Brakes |
08-18-2019, 06:29 PM
#33002
Installed new stainless steel Spectra gas tank straps. My rear most strap was toast. Pushed on the exposed bit on the frame side a while back and it crumpled into dust.
This is a fantastic DIY if anyone needs to do the same:
Fuel Tank Strap Replacement.
I ordered new OEM cotter pins/clips and strap bolts. Couldn’t find a part number on the gas tank skid bolts so I just bought some 8mm bolts locally. Hit everything with CorrosionX HD afterward to rust proof.
What I learned: when installing the new strap, attach the pin side first then do the bolt/frame side second.
Also a U-joint socket attachment is essential for the front most bolt directly above the drive shaft.
My front most gas tank skid bolt snapped though so that will need an EZ-out at some point.
08-18-2019, 09:14 PM
#33003
Rotated the tires
Fixed the spare tire with a plug
Greased the driveshaft
Added rigid sae fog lights using brackets I had from my old work truck.
08-19-2019, 10:50 AM
#33004
Real Name: Jared
Real Name: Jared
Tore out my tired and leaking XREAS system and replaced it with new Moog springs and Bilstein 5100s, added Spidertrax wheel spacers and installed an Air Lift Wireless One system to help manage the load when hauling my motorcycle or tent trailer.
Sent from my iPhone using Tapatalk Pro
2006 Sport Edition 4X4 V6
08-19-2019, 01:10 PM
#33005
Got pics? I'm in a similar situation and considering that approach.
08-19-2019, 01:39 PM
#33006
Real Name: Kevin
Real Name: Kevin
Dropped her off at this shop this morning for official headgasket diagnosis and replacement. :'(
Not looking forward to the bill, but it'll be nice to not have to worry about it. Should basically last forever after this speedbump! *knocks on frame*
'04 4Runner - Build Thread | '05 CBR 600RR & 1000RR - The slow vehicles ;)
08-19-2019, 02:24 PM
#33007
I bought one... 2007 107k miles, took me a month of looking and I had to drive 3 hours to get it but well worth it.
Sent from my Pixel 2 XL using Tapatalk
08-19-2019, 05:01 PM
#33008
*Frame crumbles....... well, shit
08-19-2019, 05:07 PM
#33009
Real Name: Russell (OB #9908)
Congrats & welcome.
08-19-2019, 06:01 PM
#33010
Real Name: Kevin
Real Name: Kevin
Literally happened a month or two ago when I pulled off my towhook in my hand lol
Fortunately, that was localized and caused by a coolant leak. The rest of the frame looks pretty great.
08-20-2019, 07:39 AM
#33012
My straps are bad, and on the list to replace in the very near future. Where did you find stainless straps? I saw the Spectra brand on Rock Auto, but it didn’t mention stainless. I would definitely prefer stainless for obvious reasons!
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
08-20-2019, 08:42 AM
#33013
had my oil tested a while ago with blackstone, then left for a road trip. got the diagnosis back, and they said they detected traces of coolant in the oil. checked the coolant and it was indeed low. topped it off with some toyota formulated stuff, and haven't noticed a measurable drop in it.
when i got home from the trip, took it to an independent toyota shop and talked to the dude there. he didn't seem too concerned about it, as the truck is not throwing any codes, doesn't puff white on cold starts, and doesn't have a hard stumble. now, i have noticed some stumbles on cold starts, but it's more like a hiccup than anything. feeling a bit conflicted about the whole situation.
when i got the truck, i switched to mobil1 synthetic. that was 30k miles ago. for the next couple of changes i'm going back to a conv oil and send it back to blackstone.
08-20-2019, 08:52 AM
#33014
Real Name: Kevin
Real Name: Kevin
My personal opinion: There should *never* be coolant in your oil. None. Not trace amounts. Nothing. The fact that Blackstone brought it up means there's an issue that you should definitely look into. And it's honestly scarier (to me) than if coolant was leaking into a cylinder, which is what would cause white smoke/misfires (and is what typically happens when people talk about 4th gen headgasket issues).
It means that coolant is leaking into your crankcase somehow. It won't necessarily affect driving performance. The risk is that it thins out your oil and you spin a rod bearing because they're not lubricated well enough. Essentially destroying your engine as that will send metal shavings throughout the block.
#33015
Added 18 inch wheels and Falken Wildpeaks.
No lift.
2003 4Runner SR5 V8
319k and counting...
