12-11-2019, 12:39 AM
#33316
Real Name: Anita Keller
much better to have more cars while playing this online games.
NJ Casinos with No Wagering Requirement
12-11-2019, 02:19 PM
#33317
Real Name: 03 v8 Limited
Fixed a squeaking brake
And a sagging spring
Sent from my SM-G950U using Tapatalk
12-11-2019, 03:01 PM
#33318
Real Name: Chris
Real Name: Chris
I got these OEM mudguards on Black Friday and they look great! PT769-89110 - Genuine Toyota Mudguards Mudguards The fit is perfect and I got a nice deal on em so I'm really happy with my purchase.
12-11-2019, 03:37 PM
#33319
Today I adjusted my hood bump stops and stopped an irritating squeak every time I hit a harsh bump. The hood squeak from prior posts is legit. Twist twist silent.
12-11-2019, 04:45 PM
#33320
Originally Posted by Brutalguyracing
Um.....ouch.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
12-11-2019, 09:54 PM
#33321
Replaced the steering rack with a low mile one last weekend, eliminating the stock worn out steering rack bushings in the process. Still have a clunk when I go over bumps Literally the only thing I haven't changed yet is the lower ball joints and wheel bearings
2007 Sport Edition V8 4WD w/Nav, JBL and rear seat entertainment, Fox 2.5 R/R coilovers, FJC rear springs with Fox 2.0 Pro series shocks, Rear ARB locker, 305/70R17 Ridge Grapplers, DT short headers
12-11-2019, 10:48 PM
#33322
Originally Posted by momo.75
Those are really cool. I hadn't ever seen those before
Do it Momo
12-12-2019, 06:18 PM
#33323
Real Name: Scott
Real Name: Scott
I've replaced everything, including the LBJ's and wheel bearings, and still have the damn clunk. I have tried everything I can think of to diagnose it with no success.
-Semper Fi-
2006 4Runner Sport Edition 4WD V6/Suspension/Armor/Lights/Wheels and tires/Drawers/Camping things/Surfboards/Rhodesian Ridgebacks . . .
BUILD AND ADVENTURE THREAD
12-12-2019, 06:34 PM
#33324
Real Name: Kevin
Real Name: Kevin
Do you guys still have the front swaybar connected at all? I could not get mine to stop clunking till I removed it...
Might also want to loosen/retorque (while on the ground) the upper and lower control arm mounting bolts. They can sometimes bind if they were tightened while the suspension was unloaded.
Also might be worth taking a look at the skid plate bolts and making sure they're all snug.
'04 4Runner - Build Thread | '05 CBR 600RR & 1000RR - The slow vehicles ;)
12-12-2019, 09:32 PM
#33325
I now have an annoying clunk except I know exactly what mine is. My skid plate touches my diff (barely) because of my diff drop. Every speed bump and backing in to my garage it clunks. I’ll probably remove the diff drop, but it doesn’t bother me much honestly.
12-12-2019, 09:41 PM
#33326
yesterday, I finally got to weld the top plate to my RCI sliders, now to paint them then weld them on,, woohooo
2007 Sport.
"Colorado is FULL, try N.M."
"Everyone is an expert"
12-12-2019, 09:46 PM
#33327
No front sway bar, no skid plates installed. I just installed new Whiteline lower control arm bushings too and those bolts are tight. Also put new uniballs in the Total Chaos UCAs.
12-12-2019, 11:07 PM
#33328
Started looking into lift kits for my girlfriends xterra…. now im worried that her ride might end up taller than mine
2006 limited v8 4wd
Toytec/ebiach 3” coilover lift with 1/2” top plate spacers, Jba high caster UCA’s, blistein 5100 rear shocks with toytec superflex hd springs, Cooper st max 255/80/17 with mb 352 in 17x9 -12 mm offset, auxbeam light bar in front bumper, custom retrofit headlights, SS brake lines, 5th gen brakes, custom rear storage box
12-13-2019, 02:29 AM
#33329
5-6 inches is what I saw people talking about. Will it make you feel........small?
12-13-2019, 08:09 AM
#33330
Those things look like a meathead who skips leg day when they’re lifted too high in my opinion
