Thread Tools Rating: Thread Rating: 12 votes, 4.58 average. Display Modes
Old 03-26-2020, 06:41 PM #33781
evan1242's Avatar
evan1242 evan1242 is offline
evan1242 will become famous soon enough evan1242 will become famous soon enough
evan1242's Avatar
Found the exact hitch basket I wanted used for $90
evan1242 is offline   Reply With QuoteReply With Quote
Old 03-26-2020, 11:36 PM #33782
Trekburt Trekburt is offline
Trekburt is on a distinguished road
Put together a LED light harness for the engone bay today - surprisingly bright, and less than $10.
Sent from my SM-J727V using Tapatalk
Trekburt is offline   Reply With QuoteReply With Quote
Old 03-28-2020, 12:48 PM #33783
IllustratedMan's Avatar
IllustratedMan IllustratedMan is offline
IllustratedMan is on a distinguished road
Changed the spark plugs. Apparently the previous owners thought it was optional or somethingWhat did you do with your 4runner today?
‘07 with 187,000 miles and what would appear to be original plugs
2007 V6 SE. Dobinsons 302/221-325/701. Falken wildpeak 265/70r17. RSG angled sliders. LFD front skid.
IllustratedMan is offline   Reply With QuoteReply With Quote
Old 03-28-2020, 03:49 PM #33784
RoyBell RoyBell is offline
RoyBell will become famous soon enough
Finished my lift finally. Hoping the rear settles a little. Front fenders 37", rears are 38". The fronts have been on for 2 weeks though. Should I wait to get it aligned in case I need to raise the front more?
Just the Toyotas
'86 FJ60
'07 4R V8
RoyBell is offline   Reply With QuoteReply With Quote
Old 03-28-2020, 05:31 PM #33785
04rnr's Avatar
04rnr 04rnr is offline
04rnr is a jewel in the rough 04rnr is a jewel in the rough 04rnr is a jewel in the rough
04rnr's Avatar
Finished installing my @victory 4x4 molle panels
What did you do with your 4runner today?-20200328_150717-copy-jpg  What did you do with your 4runner today?-20200328_150732-copy-jpg
2007 Sport.
"Colorado is FULL, try N.M."
"Everyone is an expert"
04rnr is offline   Reply With QuoteReply With Quote
Old 03-29-2020, 07:54 AM #33786
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Took the bumper off to repaint some spots I missed and scratches are starting to rust. Might re torque the header bolts while the paints drying.
What did you do with your 4runner today?-bumper-maintenance-jpg
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 03-29-2020, 10:58 AM #33787
Monty87ls Monty87ls is offline
Monty87ls is on a distinguished road
This was yesterday and the day before but I got the front part of my dash cam and radar detector installed and hardwired.
Got the driver side speakers tweeters replaced on friday and the passenger done yesterday. I'm happy with how I mounted the tweeters. After researching on here I had a plan then when took the stock tweeter out I just pulled it all apart and used that. Easy enough, just had to wait for the metal to cool down after I melted the glue to get the magnet off
Sent from my SM-N975U1 using Tapatalk
Monty87ls is offline   Reply With QuoteReply With Quote
Old 03-29-2020, 11:01 AM #33788
Originally Posted by WyEast-08 View Post
Love my 4runner but a major issue has been the front cup holders. Going around corners with one hand on my coffee mug to prevent it from falling over has been a major irritant let alone any type of gravel road with washboard.
Took only 5 minutes and it's super simple. I just cut a thin strip of grey packing material, stuck it to double sided foam tape and then attached to the inside of the adjustable levers of the cup holder. All it does is reduce the gap between the lever and the container. Not perfect, but for about 10 cents, works pretty well.
Random question but is that trim factory? I like it better then the silver on mine!
Old 03-29-2020, 02:28 PM #33789
azgold azgold is offline
azgold is on a distinguished road
2006 SR5 4Runner 219,000 miles W/ 3" lift up front.
Installed new upper & lower Control Arm Assemblies, and new Tie rod ends.
Then had an alignment done. I cant decipher the alignment paper so im not sure if its ok or not....
What did you do with your 4runner today?-20200329_111531-jpg  What did you do with your 4runner today?-20200329_110937-jpg
azgold is offline   Reply With QuoteReply With Quote
Old 03-29-2020, 04:35 PM #33790
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Created a work of modern art.
Actually, that’s the remainder of my X-REAS that I’ve needed to remove since swapping out my suspension last year. I also rotated my tires since Discount Tire is providing urgent services (flat repair, etc.) only.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 03-30-2020, 01:55 PM #33791
Warwicke36's Avatar
Warwicke36 Warwicke36 is offline
Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough
Warwicke36's Avatar
Replaced my left front axle seal + drain and filled the front diff with some Amsoil. Exciting stuff...
2004 Sport 4.0
Warwicke36 is offline   Reply With QuoteReply With Quote
Old 03-30-2020, 04:20 PM #33792
WyEast-08's Avatar
WyEast-08 WyEast-08 is offline
WyEast-08 is on a distinguished road
WyEast-08's Avatar
Yes, that is factory trim.
WyEast-08 is offline   Reply With QuoteReply With Quote
Old 03-30-2020, 05:35 PM #33793
MikeinNH67's Avatar
MikeinNH67's Avatar
That on a Limited? I think that's what my trim looks like.
What I did this weekend was pull the rear bumper cover off to see how the frame rails were doing. 6 hours or so later I had new steel welded in to where I found rust holes. I posted some pics in the thread below.
Who had their 4runner frame replaced?
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 03-30-2020, 06:12 PM #33794
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
I have a 2004 Limited, mine looks somewhat similar in color but it is different, mine looks more like a green granite, it is speckled and not streaks like his.
2004 Limited V8
Old 03-30-2020, 08:26 PM #33795
MikeinNH67's Avatar
MikeinNH67's Avatar
Interesting, guess I'd have to look closer at mine but I assume it probably looks more like yours because of the age. I think it is more speckle-ish.
Mike
03 4runner Limited
4runner , 4th gen , desertarmor , mods , outgearsolutions
Bought my first 4runner today! mechagouki New Members 57 02-20-2024 01:12 PM
Weird Problem today with my 4Runner today. myT4RisGREEN 3rd gen T4Rs 12 12-11-2021 08:17 PM
My 4runner got smacked today! Rez90 4th Gen T4Rs 11 10-09-2013 05:03 PM
I got my 4Runner today NavyChiefnMD 5th gen T4Rs 5 12-17-2009 01:12 PM
