09-24-2020, 12:30 PM
#34651
Real Name: Kevin
Real Name: Kevin
Originally Posted by gaber6
$30 UCA from rock auto.
Stock was shot at 190k and ready to fall apart on one big pothole.
1 hour job.
I figure for the price, I can replace it three times compared to the next higher priced one and it can't be that much worse. One more rattle to fix and I already have the steering shaft ready to go for that.
While I see the logic, things get a lot more expensive than a good UCA if this one fails suddenly, rather than gradually like the OEM did.
'04 4Runner - Build Thread | '05 CBR 600RR & 1000RR - The slow vehicles ;)
09-24-2020, 04:03 PM
#34652
Right. I mean it is a ball joint and some bushings in stamped steel. I'm not offroading, so I feel safe enough
09-24-2020, 05:13 PM
#34653
Not today but yesterday....I crawled under the back to lube up my spare tire winch and found the emissions canister above the spare was no longer attached to the mounts. The mounts were rusted to nothingness so I made a bracket that went between the floor support rails to bolt it to on the rear side. Can't reach the front side easily so that end got the zip tie repair. Another thing to check in the salt belt, wahoo.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
09-24-2020, 08:33 PM
#34654
Real Name: Doug
Real Name: Doug
Making Cladding Awesome today.
The rear bumper is being done off the car.
As the front bumper will be done tomorrow.
2003 Imperial Jade 4Runner Sport Ed.
09-26-2020, 07:04 PM
#34655
Real Name: Todd
Real Name: Todd
Added a new stick.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
09-26-2020, 08:13 PM
#34656
Real Name: Joe
Real Name: Joe
Originally Posted by xtremewlr
Added a new stick.
Is that functional?! I have excite
#34657
Added a new stick.
Finally got it done? What's your experience so far?
Sent from my SM-G986U using Tapatalk
09-26-2020, 08:15 PM
#34658
Real Name: Joe
Real Name: Joe
Finally acquired all the necessary parts to test out the new (to me) bike rack. The madden voyage around the block was a success!
09-26-2020, 08:29 PM
#34659
Real Name: Todd
Real Name: Todd
Of course. Why would I go thru all that work and not have a functional transfer case?
Waiting on the driveshafts still, they won't be done until Thursday or Friday. Front shortened and rear lengthened for the FJ tcase. I just finished it up today, except for doing the wiring to get the 4WD and 4LO dash light to turn on. Worry about that later.
The tcase is a direct bolt-in. The "hard" part is cutting the hole in the trans tunnel and modifying the stick to come out where I have it. Just takes time and patience. I do have twin sticks for it but wanted to go with the J-shifter for now. Might swap the twins later.
09-26-2020, 10:23 PM
#34660
To the store! Sadly that is all
09-27-2020, 09:20 PM
#34661
My just-finished look didnt last long..
Spent some time last 2 weeks installing the diff drop (surprising difference, my cvs are just about parallel), rebooting both axles, sway bar relocation. Installed the victory 4x4 ladder, gas can, relocated shovel mount, blah blah blah. Then I pulled off my spidetrax spacers and listed wheels for sale. Have a guy coming to get them Friday.
With that said.. i also installed a 1" body lift, pulled off the nfab steps, did an aggressive body mount chop (not welding it in, cant see too much of a point from a structural perspective.. ), cut and beat in the pinch welds in the fender, trimmed the fenders a bit, did the front diff fluid change, installed some ditch light pods, etc.
The tires have delivered and wheels should be here tomorrow.. pretty excited to go to 35s... but it was a late night wishful decision when I couldn't sleep...and well...35s...here I come... lol
Sent from my SM-G970U using Tapatalk
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
09-27-2020, 11:03 PM
#34662
You should do the body mount relocate. I think you're gonna have to cut way more than that.
07 SR5 4x4
09-28-2020, 01:26 AM
#34663
Sick! Pumped to see the results.
09-28-2020, 01:51 AM
#34664
Changed out these upper coolant hoses with OEM hoses and clamps.
Worked on test fitting my new wheels. Got these 16's to clear the big breaks with a 1/4" spacer. Super pumped to get to run them.
Also removed fenders and began sketching out a plan for pinch welds, body mount chop, and fender trimming. 35's should be here this week! Picking up suspension tomorrow.
09-28-2020, 08:23 AM
#34665
Real Name: Aaron
Real Name: Aaron
Those wheels are rad
2007 4Runner Limited V8
| 2.5 Fox 3" lift w/ remotes & DSC | Dobinson 677V rear | SPC UCAs | 1" BL | SCS F5 | 315/70 DuraTracs | Prinsu full rack | RLC rear bumper/swingout | C4 front bumper | Warn VR8-S | F55 fairlead/Flatlink-E | Rocksteady skids | ARB 2500 awning | Dometic CFX 40W | Partner Steel 22" stove | Adventure Index drawer/sleeping platform | ARB twin compressor | Odyssey 34R dual batteries | Blue Sea SI ACR/fuse panel/USB | Renogy 100W Eclipse | Baja Designs Squadron R & S2 | G5R retrofits | Doug Thorley headers/Y pipe | weBoost OTR |
