12-02-2020, 07:56 PM
#34891
Originally Posted by JuniorPigeon
Not to rain on your parade, just looking out, but wire nuts are not for vehicle use and you may end up with problems again down the road. They're made for solid core wire and a static environment.
Thanks for the heads up. They are tight for now but I get it. They were barely wrapped and electrical taped only prior so that was one issue.
I have flickering headlights now and the dash blinks when I tap the brakes, so I got a new brake light switch, as suring up the radio wires didn't help. Switch goes in tomorrow when it is light out. I took it out half way home today and it does not click, and it pulled out of the socket spacer which the new one has built onto it. The fact that it may not have been spaced properly may have wasted it.
12-02-2020, 08:07 PM
#34892
Originally Posted by Kryptoroxx
Been working on this for about a week. All thats left is drilling and tapping the holes for the latch before I retrieve the bumper, add mudflaps to the bumper, mount the license plate, and run the wires for the lighting.
This is turning out killer, keep us posted with some final install shots after its painted and mounted. I'll keep an eye on your build thread!
12-02-2020, 08:28 PM
#34893
Just looked at it cause it's broken.
12-02-2020, 08:49 PM
#34894
12-02-2020, 09:08 PM
#34895
What's wrong with it?
Sent from my SM-G986U using Tapatalk
12-02-2020, 11:56 PM
#34896
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
12-03-2020, 03:19 AM
#34897
Real Name: Richard
Real Name: Richard
Fresh lube
'05 SR5 V8 4WD
|Bilstein 5100|Falken Wildpeak AT3 265/70/17|'06-'09 headlights/tails| Lexus RX330 projector retrofit
12-03-2020, 12:40 PM
#34898
Originally Posted by aemravan
Andddd done.. just need to aim the lights now
Which pods did you use for the high beams?
12-05-2020, 01:39 AM
#34900
Real Name: Paul
Real Name: Paul
That looks like peanut butter haha
I got new wheels and tires from a 5th gen. Now to fix the frame rust...
12-06-2020, 06:20 PM
#34901
Removed all of the XREAS stuff + springs and shocks, and installed the Eibach ProTruck suspension - alone, in my garage, with hand tools (except for the cordless impact) and did the no spring compressor front coil install. Also used new KYB top hats up front. Set the front perches to the lowest setting and love how it turned out - very slight rake, which will be perfect when I load up the cargo area.
The no spring compressor approach is fantastic! Much safer, and I found that all of my lower control arm bolts move freely (huge relief).
Only took a short ride so far (pending alignment), and I think I'm really going to be happy with this suspension. Esp since I got it Black Friday for ~$650 to my door.
Not pleased at finding a torn cv boot, but at this point it's to be expected.
12-06-2020, 07:17 PM
#34902
Real Name: John
Real Name: John
Finished off the bumper and went wheeling for once!
98 Toyota 4runner 3rz 5spd 4x4 - Sold Build Thread
06 4runner 2uz Build Build Thread
Instagram: @Kryptowerkz
12-07-2020, 09:58 AM
#34903
Real Name: Kevin
Real Name: Kevin
'04 4Runner - Build Thread | '05 CBR 600RR & 1000RR - The slow vehicles ;)
12-07-2020, 11:50 AM
#34904
Installed my UpTop Overland Bravo rack. A few things drove me to this rack over a Prinsu or any other brand, but as of right now I am pretty disappointed with the product for a couple reasons. No instructions at all, missing parts, the bolts that attach the rack to the truck at the feet only bite into the thread opening by 2, maybe 3 threads at most (where the factory bolts went in 3/4" at least). The way the feet connect to the rest of the rack quite frankly just feels like an afterthought, especially on the front feet. It appears this rack was launched in July of this year, so I imagine they just adapted another rack to work on the 4th gen, but it just feels like it was rushed or they cut corners. Not feeling too confident to put a 150lb tent up there just yet. Hopefully UpTop comes through to fix the issues.
12-07-2020, 12:03 PM
#34905
Real Name: Aaron
Real Name: Aaron
Not bashing at all, just out of curiosity what drove you to this rack over Prinsu and other brands? To me the side panels don't look as readily modular and it could be the picture, but it seems like the cross rails are way high compared to the roof itself.
Sorry to hear about the bad experience, hopefully they make it right for you.
2007 4Runner Limited V8
| 2.5 Fox 3" lift w/ remotes & DSC | Dobinson 677V rear | SPC UCAs | 1" BL | SCS F5 | 315/70 DuraTracs | Prinsu full rack | RLC rear bumper/swingout | C4 front bumper | Warn VR8-S | F55 fairlead/Flatlink-E | Rocksteady skids | ARB 2500 awning | Dometic CFX 40W | Partner Steel 22" stove | Adventure Index drawer/sleeping platform | ARB twin compressor | Odyssey 34R dual batteries | Blue Sea SI ACR/fuse panel/USB | Renogy 100W Eclipse | Baja Designs Squadron R & S2 | G5R retrofits | Doug Thorley headers/Y pipe | weBoost OTR |
