04-14-2021, 09:11 PM
#35326
oil change and fixed a fuse for my baja designs pods. I have an RCI skid ready to install but I was wondering if you guys would wait for the full set to put it all on at once? Or just throw the skid on and piece it together?
*I have yet to purchase the rest of the skids. Hopefully in the future.
07 SR5 4x4
04-14-2021, 09:41 PM
#35327
Throw it on now, the front stock skids are pretty weak. Especially the one under the oil pan, its like paper thin.
04-14-2021, 10:03 PM
#35328
you right you right!
07 SR5 4x4
04-14-2021, 10:46 PM
#35329
I did a whoopsie without even trying lol. A single piece to replace the front two skids skid is also going to prevent this from happening, since there won't be a seam to grab.
Sent from my Pixel 2 XL using Tapatalk
04-15-2021, 08:33 AM
#35330
Real Name: Kevin
Real Name: Kevin
'04 4Runner - Build Thread | '05 CBR 600RR & 1000RR - The slow vehicles ;)
04-15-2021, 04:59 PM
#35331
I was able to get my front brakes replaced along with sway bar bushings. Failed trying to get the front output shaft seal replaced. I was able to get the front driveshaft off but couldn’t get the nut off of the flange for the T-case. Not enough leverage or torque! I’ll try again this weekend on a lift. My spring compressor should be here tomorrow and hopefully I can get my front coil overs done and total chaos UCA’s rebuilt next.
2004 SR5 V8 AWD
04-16-2021, 06:52 PM
#35332
Put a new air filter in.
2007 SR5
04-16-2021, 06:57 PM
#35333
Originally Posted by Quorth
Upgraded my headlights to LED's today. Starting small
Which LEDs did you get...and are you happy with them?
Currently in my garage:
2018 Tundra SR5 Dbl. Cab
2021 Mazda MX-5 RF Club BBR
2022 Mazda CX-5 Turbo
04-17-2021, 02:36 PM
#35334
Replaced the center console AUX port,
FYI you don't actual need to remove the center console.
Pull off the bezel and stuff around the shifter,
Reach in and disconnect it from the rear.
Then push it rearward towards the back of the car and it will just pop out into the storage compartment.
2007 SR5
04-17-2021, 02:41 PM
#35335
Got my front output shaft seal replaced. Things went way smoother with a lift. Sorry for the wonky pics for some reason this place flips them all weird.
2004 SR5 V8 AWD
04-17-2021, 06:15 PM
#35336
A little paint and a de-badge
I considered doing the Plasti-Dip on my front and rear emblems but ended up painting them with primer and then a semi-gloss black. I like how it turned out. Then I got brave and de-badged the tailgate. Being my 4Runner is 14 years I was afraid that once I removed the letters there would be the infamous “ghosting” of the letters on the paint. Well.....I am happy to report that it was possible to get rid of any “ghosting”. Once the letters were removed (with a heat gun and trim tool) I used Goo Gone to remove any tape residue, them I used rubbing compound by hand to do 90% of any ghosting removal. Honestly there wasn’t any on the doors and on the tailgate there was just a little where the 4Runner emblem was. I then used my DA polisher and a little “Finesse It 2” to restore the shine on the clear coat and Voila...In less than an hour I had the entire vehicle de-badged, cleaned and polished. Very happy with the results! Thank you previous owners for taking care of the paint and garaging this gem of a truck! My next project is perhaps the wheels.
04-17-2021, 09:32 PM
#35337
Dropped the trans pan, did new filter gasket, fluid flush. Easiest auto trans service I’ve ever done. The drain plug was really nice!
2008 SR5 4Runner V6 4WD
04-20-2021, 12:31 PM
#35338
Amazon.com: Auxbeam 9005 Led Bulb, F-S2 Series 9005 HB3 H10 9145 Bulb Conversion Kit, 8000 Lumens 6500K White, Replacement Halogen Bulb Fog Light, Pack of 2: Automotive
Amazon.com: Auxbeam H11 Led Bulb, F-S2 Series H11 H8 H9 Bulb Conversion Kit, 8000 Lumens 6500K White, Replacement Halogen Bulb Fog Light, Pack of 2: Automotive
They were recommended in another thread that I can no longer find. They seem to work well, they are much much brighter. Also super easy to install, though I will say that one of the high beams was somewhat of a challenge to get to "click" in on the connection, but other than that it was fine.
04-21-2021, 03:05 PM
#35339
35% Window tint. Looking good!
04-21-2021, 09:43 PM
#35340
Goodyear MT/Rs(265 70 17) on 2017 wheels...
'04 V8 Limited - Eibach Pro Truck lift, TRQ LCA, TPMS bypass
