Thread Tools Rating: Thread Rating: 8 votes, 4.63 average. Display Modes
Old 06-16-2021, 02:56 PM #35476
tubby45 tubby45 is offline
tubby45 is on a distinguished road
Went to get state inspection done. Totally forgot I had disconnected the battery a week ago to test something out.
Don't forget to drive 50+ miles for a reset before getting your inspection done -_-
tubby45 is offline   Reply With QuoteReply With Quote
Old 06-16-2021, 10:17 PM #35477
cwilliams563's Avatar
cwilliams563 cwilliams563 is offline
cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about
Originally Posted by Bluesky 07 View Post
Curious, should that have said, "You can't use the original HU..."?
Negative, you can use the factory HU or aftermarket.
The signal from the powered sub hooks to the speaker wire outputs.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
cwilliams563 is offline   Reply With QuoteReply With Quote
Old 06-16-2021, 10:42 PM #35478
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 is a splendid one to behold Bluesky 07 is a splendid one to behold Bluesky 07 is a splendid one to behold Bluesky 07 is a splendid one to behold Bluesky 07 is a splendid one to behold Bluesky 07 is a splendid one to behold Bluesky 07 is a splendid one to behold
Bluesky 07's Avatar
Okay, thanks. I have an old Bazooka tube behind the driver's seat and it's hooked up through the speaker wires. I've had that thing for going on 15 years and it's still pounding away.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 06-16-2021, 11:26 PM #35479
southern_runner southern_runner is offline
southern_runner is on a distinguished road
Dropped the t-case. Got a used one to replace. Old one had a hole knocked into the side of it after the front driveshaft broke loose.
I got the 4Runner from my neighbor. Replacing the t-case, new driveshafts, new headlight assemblies, new windshield, and a bunch of little stuff like dash lights, hood struts, new stereo and speakers all around, etc.
Once I get the t-case back in it's going for a timing belt, I'm not going to try and tackle that one since I can't get it in the garage.
What did you do with your 4runner today?-20210601_094409-jpg  What did you do with your 4runner today?-20210525_165134-jpg
southern_runner is offline   Reply With QuoteReply With Quote
Old 06-17-2021, 01:10 AM #35480
shurmack shurmack is offline
shurmack is on a distinguished road
Had to go back to the dealer to fix a VIN cut key. I only received 1 keyset with the car that was so worn, it only worked in the Ignition, no luck in the door or hatch.
Decided to have the dealer cut a new VIN key so I would have a clean primary key. I should have checked it when i was there, but did not. When I got home I programmed it following a thread here with success. But then found out it only worked in one direction on the door and hatch (dot down).
Took it back to the dealer they cleaned it up, and was able to get it to work both direction in the door. Cleaned it up a second time and with a little force was able to get the trunk to work in both direction. Third time was a charm.
Lesson is, if you have a dealer cut a vin key, test it all before you leave
shurmack is offline   Reply With QuoteReply With Quote
Old 06-20-2021, 02:42 AM #35481
dsanford dsanford is offline
dsanford is on a distinguished road
I was able to get a couple things done that desperately needed to be done.
Had to do a full front brake service. I had a seized caliper on the front left, so that meant everything new had to go in. Duralast calipers (for the lifetime warranty), Duralast “Elite” pads and Duralast rotors. I did not have time to order the slotted rotors I would like to have or the Powerstop pads to match the rear. No one carried these parts local and RockAuto shipping was WAY too much to have them in a day. Had to have it done over the weekend to get to work the following. Had to paint the calipers because one came finished and the other came unfinished.
Next was lower ball joints. While I was in there, new sway bar end links and bushings to the frame went in to get rid of the clunks I had going on. I went with MOOG on all these parts.
Couple months before that, I had to replace the radiator. Ordered a Denso from RockAuto and it went in without a hitch.
All these repairs give me peace of mind but I have been chasing neglect from the previous owner. One day I’ll be able to get into some real mods. :-)
Lastly I finally got around to Plastidip the emblems. Chrome be gone.
What did you do with your 4runner today?-f5630bea-875c-4ddd-bb28-02bc4acc5a36-jpeg  What did you do with your 4runner today?-5576247f-bacb-4b63-8c17-d53144375efd-jpg
2006 GGM Sport 4WD / Lots of maintenance from neglect (from previous owner) / Interior & Exterior LED swap / Sony XAV-AX1000, Kicker front door speakers, Kenwood tweeter replacement / Diode Dynamics SS3 Fogs
dsanford is offline   Reply With QuoteReply With Quote
Old 06-21-2021, 03:27 AM #35482
WyEast-08's Avatar
WyEast-08 WyEast-08 is offline
WyEast-08 is on a distinguished road
WyEast-08's Avatar
Did some exploring in Central Oregon.
Unfortunately, on the way home, opened up the glove box to find that something had gotten into the glove box and made a nest during the trip.
Got home and replaced the cabin filter (chewed seeds and parts of a tissue)
Opened up the engine cowling and made a steel mesh covering for cabin air intake using Kwik Mesh from Home Depot.
https://www.toyota-4runner.org/attac...d=383603&stc=1
https://www.toyota-4runner.org/attac...17d=1624260306
What did you do with your 4runner today?-mt-washington-v3-jpg  What did you do with your 4runner today?-air-intake-v2-jpg
WyEast-08 is offline   Reply With QuoteReply With Quote
Old 06-22-2021, 10:55 AM #35483
04SR5sam 04SR5sam is offline
04SR5sam is on a distinguished road
Replacing the front left hub as well as doing the 100k timing belt job this week. RIP my wallet
04SR5sam is offline   Reply With QuoteReply With Quote
Old 06-22-2021, 05:41 PM #35484
gm350reratliff's Avatar
gm350reratliff gm350reratliff is offline
gm350reratliff will become famous soon enough
Finally replaced the chrome door handles with black handles.
I also detailed it today inside and out since it was pretty filthy. What started as a simple wash and vacuum snowballed into a full detail, buff and wax thanks to my OCD and a can of Red Bull. Should be good for a while now.
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html[/CENTER]
gm350reratliff is offline   Reply With QuoteReply With Quote
Old 06-22-2021, 08:24 PM #35485
montijo505's Avatar
montijo505 has much to be proud of montijo505 has much to be proud of montijo505 has much to be proud of montijo505 has much to be proud of montijo505 has much to be proud of montijo505 has much to be proud of montijo505 has much to be proud of montijo505 has much to be proud of
montijo505's Avatar
Got a link or part number for the handles?
Old 06-23-2021, 12:15 AM #35486
Yes, I do. I used the Dorman textured black handles. 82499 for the driver front door, 82498 for the passenger front door, and 93994 for the rear doors. So far the fit and feel is great.
Old 06-23-2021, 10:21 AM #35487
momo.75's Avatar
momo.75 momo.75 is offline
Registered User
Real Name: Morris
momo.75 is a splendid one to behold momo.75 is a splendid one to behold momo.75 is a splendid one to behold momo.75 is a splendid one to behold momo.75 is a splendid one to behold momo.75 is a splendid one to behold momo.75 is a splendid one to behold
Registered User
momo.75's Avatar
Real Name: Morris
Looks really good!
momo.75 is offline   Reply With QuoteReply With Quote
Old 06-23-2021, 10:49 AM #35488
GrandpaDaddyG GrandpaDaddyG is offline
Real Name: GPA Burley
GrandpaDaddyG is on a distinguished road
Old and Worried 1997 RWD 4R S/S Assembly
Since I had the Frontend Strut/Spring Assembly replaced and the read shocks as well! Was told that I ordered 4WD Struts/Springs instead of 2WD and all the parts had been installed since the second week of June 2021!
My question to you all, is a difference in the 4WD versus the RWD Strut/Spring Assembly, sure looks like the struts on part house give different numbers! Is there a specification page for this somewhere! When I spoke with the various part houses get conflicting stories on the parts being interchangeable, etc.. just concerned!
Thank you!
Al Burley
Dallas, Georgia
GrandpaDaddyG is offline   Reply With QuoteReply With Quote
Old 06-25-2021, 08:21 AM #35489
kcdehart's Avatar
kcdehart kcdehart is offline
Real Name: Kevin
kcdehart is a jewel in the rough kcdehart is a jewel in the rough kcdehart is a jewel in the rough
kcdehart's Avatar
Real Name: Kevin
Finally got tired of having a floppy shifter so found a used assembly on eBay and ordered it. Hopefully this one isn't dead, too New shifter assemblies are a lot more than the $50 that I paid, though, and it has a warranty. So I'll take the risk. Holding it over in 3rd is a pain when towing.
Also should be receiving the world famous Napa awning today! Gonna be great for trackdays.
'04 4Runner - Build Thread | '01 Lexus GS430 - Loud V8 grandma-mobile | '05 CBR 600RR & 1000RR - The slow vehicles ;)
kcdehart is offline   Reply With QuoteReply With Quote
Old 06-27-2021, 12:32 AM #35490
Recove Recove is offline
Recove is on a distinguished road
Replaced front wheels bearing and cv axle. I took me around 8 hours
Recove is offline   Reply With QuoteReply With Quote
4runner , 4th gen , mods
My 4runner got smacked today! Rez90 4th Gen T4Rs 11 10-09-2013 05:03 PM
Weird Problem today with my 4Runner today. myT4RisGREEN 3rd gen T4Rs 9 05-18-2013 10:07 PM
Bought my first 4runner today! mechagouki New Members 2 09-18-2010 10:03 PM
I got my 4Runner today NavyChiefnMD 5th gen T4Rs 5 12-17-2009 01:12 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
