Old 11-14-2011, 12:20 PM #1
Jester4kicks Jester4kicks is offline
Jester4kicks is on a distinguished road
Swap toytec springs on OME lift?
I've been rethinking the OME lift that I already installed on my runner. I like the lift, but it's just a little too stiff with the current weight. I'll keep the springs around for when I add some armor and such, but I'm exploring solutions in the meantime.
I've heard toytec springs are much closer to the stock stiffness. Would it be possible to get just the springs and swap them in for my OME springs (retaining my nitrocharger shocks)?
I think I found the right rears (ToyTec "Superflex" rear Coils (FJ & 03-09 4Run) - Toytec Lifts: Toyota Lift Kits: FJ Cruiser Lift Kits, Tacoma Lift Kits, Tundra Lift Kits, 4 Runner Lift Kits, Sequoia Lift Kits, Toyota Truck Lift Kits) but what about the fronts? Or would just doing the rears be enough to smooth the ride out a bit?
Thanks!
2006 V6 SR5 4WD - OME 885, Toytec Superflex rear coils + Daystar 1.5" spacer on driver's side to eliminate sag, Nitrocharger 90000/60004 shocks, Spidertrax 1.25" spacers, 285/70/17 Firestone Destination A/T's, Spenski Off-road cargo barrier, Whitson Metalworks roof rack, Shrockworks sliders
Jester4kicks is offline   Reply With QuoteReply With Quote
Old 11-14-2011, 01:52 PM #2
zstampe's Avatar
zstampe zstampe is offline
zstampe is on a distinguished road
zstampe's Avatar
Thanks!
The fronts they sell are ome. What ome springs do you have?
2006 SR5 4x4 My build: http://www.toyota-4runner.org/4th-ge...ml#post1104330
"We're the middle children of history man. No purpose or place. We have no great war, no great depression. Our great wars a spiritual war....our great depression is our lives. We've all been raised on television to believe that one day we'd all be millionaires, movie gods or rock stars. But we won't. And we're slowly learning that fact....."
zstampe is offline   Reply With QuoteReply With Quote
Old 11-14-2011, 02:23 PM #3
Casper421's Avatar
Casper421 Casper421 is offline
Real Name: Chris
Casper421 is on a distinguished road
Casper421's Avatar
Real Name: Chris
Ark knows all the #'s but I believe OME 895's are 40% stiffer than stock while Superflex coils are around 10% stiffer. The Superflex coils will be a much nicer ride than the 895's especially with no added weight. Yes, you can use the nitrocharger shocks with the Superflex coils.
2007 SE V8
HID's, interior LED mod, sweet floor mats, awesome tunes and some more stuff...
...more stuff
Casper421 is offline   Reply With QuoteReply With Quote
Old 11-14-2011, 02:48 PM #4
885/895.
Casper, that sounds like what I'm thinking of. Will the ride height be about the same going from the 895's to the superflex's?
Old 11-14-2011, 03:10 PM #5
ARK_SWAMP_RIDER's Avatar
ARK_SWAMP_RIDER ARK_SWAMP_RIDER is offline
ARK_SWAMP_RIDER will become famous soon enough ARK_SWAMP_RIDER will become famous soon enough
OME is over 40% stiffer, Toytecs are 10% stiffer. I believe you'll get around 2" lift with either coil, definitely a better ride with the Toytec rear coils.
On a v6 at stock weight, I hear 884s are a better choice than 885s. However, they have the same spring rate so I'm not sure it makes a ton of difference (885s are taller).
2003 Limited V8 - sold - Build Thread | JL Audio amp/sub | Icon stage 2 | 1/2" Body Lift | 265/70/18 Nitto TG G2's | 18" Limited wheels | Spidertrax | Clazzio's
2016 Trail Premium - Bilstein 5100 | Airlift 1000 | 285/70/17 Cooper AT3 4S | XenonDepot HID | RAV4 Blindspot Mirrors | Kicker Subaru Tweeter Upgrade | Lock'er Down Console Safe | Sprint Booster
ARK_SWAMP_RIDER is offline   Reply With QuoteReply With Quote
Old 11-14-2011, 03:29 PM #6
deedst4r's Avatar
deedst4r deedst4r is offline
deedst4r is on a distinguished road
deedst4r's Avatar
what is the big difference in the OME shocks and 5100's?
2007 SR5 4wd - 35% front tint - Remote start system - 12inch kicker sub - crunch 500w amp - 265/70/17 Cooper Discoverer AT3 - Plasti-dip grille - Cobra 19 DX CB radio - 100w PA speaker - TRD Off Road stickers - 6K LED license plate lights - HCF delete - Husky all weather mats - Satoshi grille mod - OME 885 front coils - Toytec superflex rear coils - Bilstein 5100 shocks - Light Racing UCA's - SCS Stealth 6 wheels - LED Reverse lights - *ordered BAMF sliders and LCA skids*
Build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
deedst4r is offline   Reply With QuoteReply With Quote
Old 11-14-2011, 03:47 PM #7
Probably different in length and valving, haven't seen specific numbers for both (have for bilstein, not ome though).
Old 11-14-2011, 05:42 PM #8
Well swapping in the superflex springs in the rear sounds like it will produce the exact results I'm hoping for. I'll keep an eye on this thread for any additional thoughts, but unless someone jumps in with a big reason NOT to do this... I'll probably pull the trigger tomorrow.
Thanks everyone for the replies!
Old 11-14-2011, 07:40 PM #9
No reason not to IMO, outside of adding weight in the future. Since you'll be keeping the OME, no worries there. I'd start there, and consider swapping the fronts if that doesn't do what you want. You should be able to tell if it's the front/rear that's too stiff. If it's both, you'll need to use the 884's instead of the 885's.
Old 11-15-2011, 09:24 PM #10
HAHA!! Most epic order, evar!!!
Swap toytec springs on OME lift?-epicorder-png
Toytec/Eibach front coil lift springs /bilstein 5100 rayny1014 Classifieds - buy & sell (no commercial ads please) 1 05-08-2011 04:30 PM
FS: FJ Springs and 1/4" Toytec Spacers 4runnerlabr Classifieds - buy & sell (no commercial ads please) 5 03-27-2011 05:32 PM
Toytec front springs question Alistor Engines / Suspension / Wheels / Tires / Audio / Accessories 2 11-18-2010 07:43 PM
1 more FJ, toytec swap complete jetboy1975 4th Gen T4Rs 18 10-10-2010 08:53 AM
Front FJ Springs gave me a touch more lift than 4runner springs and DS Budget Boost! clemsonxplorer 4th Gen T4Rs 12 08-20-2010 09:11 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
