11-30-2015, 09:21 PM
#1501
Originally Posted by t-man
Yes that ones important! What kind of coils are you thinking of going with?
Lol for sure. I was thinking Toytec or OME. Hard to tell the difference from here. What would you suggest? Not limited to those two...
'06 Limited 4wd - OME/Bilstein 5100 suspension, CBI front bumper, 5th gen TRD wheels/KO2s
11-30-2015, 09:29 PM
#1502
Real Name: Tony
Real Name: Tony
Well, I haven't personally used them, but I always hear about how great the OME are. You can get most of your lift just from the coils too. I think they're all about the same price too. If you get cold that lift and then an offroad bumper later you can adjust the Bilsteins up higher to compensate.
2005 Toyota 4Runner, Sport Edition, V8, K&N filter, Doug Thorley headers, custom dual exhaust, Bilstein 5100 W/ Tacoma TRD coils in front, FJ Cruiser coils, Daystar 1.5" spacer W/ Doetsch Tech 8000 10" shocks in rear, 2.5" 4crawler Body Lift, removed Sway-Bars, removed mud flaps, removed running boards, chopped body mount, 315/70-R17 Hankook Dynapro MT
Build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
11-30-2015, 10:19 PM
#1503
Yes! And I was worried I would have to get new coils after the bumper to keep the same lift. Taking all this advice.
@ t-man
11-30-2015, 10:24 PM
#1504
Real Name: Tony
Real Name: Tony
@ t-man
Glad to help!
12-02-2015, 11:59 AM
#1505
Yes, I put a spacer on and set my Bilsteins at 0" lift a couple weeks ago. Gave me a smoother ride. You can adjust the Bilsteins to get the lift you want. Just remember, if you go above 3" you'll need uca's and a dif drop to compensate.
Do you happen to have a part number for the FJ Coils? Would they provide any extra lift or would it just provide a more comfortable ride?
I am about to order the parts from Toytec and just wanted to make sure I am good with what I am getting. So far I have the Bilstein 5100's for both the front and rear and the OME 895 rear coils. Would you recommend adding anything else while I am ordering these?
I see that Toytec has a differential drop kit for $30, which isn't much in my opinion. If I did go ahead and get the Differential drop kit, what options would that open up for me that would achieve more than 3 inches?
Sorry for so many questions but I am just trying to make sure I get the right suspension the first time because I wont be upgrading for a while.
12-02-2015, 12:54 PM
#1506
Real Name: Tony
Real Name: Tony
Of you go on rockauto and punch in 2007 FJ cruiser you'll find the coils under the suspension tab.
The FJ coils will provide .5-1" of lift over stock and are slightly firmer providing better control over bumps and such.
Going over 3" puts your cv axles in a bind. By dropping the dif it drops your cv down so the angle is closer to stock again. At 3" my cv boots have about an 1/8" clearance to the shock mount on my lca's. A drop would correct that as well. The drop is just cheap assurance for your cv axles health.
Aftermarket coils will have a higher spring rate, again helping in offroad ability, handling , and they will lift more than the FJ coils as well.
12-02-2015, 07:17 PM
#1507
Review for me please?
I'm not sure if this is the right place to ask this question, so I'll apologize in advance, but I was this close to hitting the enter button to order the below setup for the 2006 V8 I just bought, and I stopped myself because I really wanted a few of the friendly experts on here to stop me if it is a bad idea.
Corndfed 3/2. I am not much of an offroader. Occasional dirt roads. I just want the lift for aesthetics and bigger tires.
Moto Metal O969. 18X9, 0 offset. I like the looks of black and chrome but also that the chrome inserts can come out and be painted gunmetal.
Toyo Open Country AT II. LT275/65R18. Wanted the AT for the nicer ride than an MT and the price is right. I've had Hankook ATs and Dueler Revo II and liked them both but sidewall was too plain (These other tires where on my earlier Toyota trucks).
Question: I have done a lot of googling on here, including reading the sticky on lifts and believe I will fit ok, but again, I wanted someone to help me confirm that I should only have some minor trimming of the fender well with a 0 offset, 9" wheel and the above size tire. I don't really foresee caring if it does it at full lock occasionally.
As soon as I am able to post, I'll be happy to put the pictures on here along with my new headlights and my soon-to-be instrument cluster light color swap.
Thanks a whole bunch
12-03-2015, 12:39 PM
#1508
Suspension options for a 2/1
Hello,
I'd start a new thread, but I don't have the minimum thread count so I'll spam here.
I have a 2007 4wd SR5 v6 with ~95k miles on it. New tire time is approaching and I'd like to step up to something a bit more, but not crazy - I've done that with a previous car. I've decided i'd like to stay around the 2" front, 1" rear option to fit some nicely sized 265/70/17 Nitto Terra Grappler G2s on either some stock or after market rims. If i go aftermarket rims I will stay around the 31" total tire size but might go up to 18".
With that, if i'm going to take apart the front and rear suspension I might as well refresh the stock versus adding spacers and this is where I'm can't seem to find the correct info.
Any suggestions on how to do a 2/1 lift with new suspension and not with spacers? Or is that a poor choice for a reason I don't know about?
Any help would be great.
12-03-2015, 02:31 PM
#1509
Good stuff on here especially the last few pages worth. Thanks for the input...for every dude that asks the questions, there's 20 of us lurking. Ha
'15 SR5 White 265 70 17 Grabbers/SCS Stealth 6/5100's-leveled/Budbuilt sliders
'08 SR5 Black-stock thus far
12-03-2015, 03:34 PM
#1510
Real Name: Tony
Real Name: Tony
Originally Posted by thecramey
Hello,
If you order Bilstein shocks they are adjustable and you can get up to 2.5" of lift with them. For the rear you can get aftermarket coils that lift or even FJ coils will give you .5-1" of lift. Fj coils front with the bilsteins set at .85 will give you a mostly level look, set them at 1.75 with the FJ coils and you'll be just over 2" of lift for the front. No spacers. Also, any coilover or shock w/ lift coil will get you where you'd like too.
12-05-2015, 12:38 PM
#1511
Good suggestions there. I thinking I'll try the OME 883 coils in the front, bilsteins all around, and a set of custom coils (10% stiffer than stock + 1") from coilsprings.com. Custom rear coils for ~250 a pair in the rear.
Should give me ~1" in rear, ~2-2.5 in front.
12-05-2015, 09:08 PM
#1512
Sorry if the answer is contained somewhere in this thread, but I just don't have time to read the over 100 pages.
I'm thinking of going with OME coil springs, and either OME shocks/struts, or Bil 5100 shocks/struts.
The original post said this about the OME coils:
OME (Old Man EMU, not to be confused with stock, OEM)
• OME offers different coil options for v6/v8 4runners and also for those at stock or with added weight.
• Provide lift by using more wraps of coils and higher spring rate
- Higher spring rate = stiffer ride
• Front coils-should provide 2.5”-3” lift for listed application
- 883-Good for leveling the front with stock rear-approx 1.5" lift
- 884-For use on stock weight v6
- 885-For use on stock weigh v8, or v6 with added weight
- 886-For use on v8 with added weight
- Front coils often combined with ¼” thick spacer for a full 3” lift
• Rear coils
- 895e-stock weight, 1” lift
- 895-stock weight, 2” lift, over 40% stiffer than stock
- 896-weight added, 2” lift
However the print off I got from the local OME dealer (same one you can get of their website, has different info on the lift height).
For the front springs is says the 884 will lift 1", the 885 2", and the 886 2.5". It does not give me the option of 883 for 2008 4Runner.
For the rear springs it says 895, 896 and 897 all lift 2".
I'm confused as OME says, for example, that the 884 coils will provide 1" of lift, whereas this posting says the 884 will lift the front 2.5-3"
Also on OME's site it does not give me the option of 895e for rear coils, only 895, 896, 897.
Sorry kind of confused...
12-05-2015, 11:21 PM
#1513
is there any difference in the spacer kits/manufacturers?
12-06-2015, 05:55 AM
#1514
Okay anyone got suggestion in tires? removing XREAS adding 5100s all around with fronts set at 2.5 and 1.5" daystar spacer in rear...265/70-17 new pro comp wheels w 0 offset...looking at new cooper stt pros - thoughts?
12-06-2015, 08:19 AM
#1515
No problem. It is a confusing decision and one you don't want to go back and have to fix. I used a full OME kit on my 06/V6. My build is here "Sammy" Build and Exploration Thread
I did wanted some lift but not the 3" that is common. I initially went with the 884/895e springs. I like where the rear sat but the front looked and felt nose high. Axle to wheel well numbers showed about 1/4" or so of rake though if IIRC. I also didn't like the angles I was seeing under the front end. I contacted ARB who advised that the 895e rear springs are meant to be paired with the 883 fronts. I made the swap and like the stance much better. It dropped me about 1" in the front and gave me about 1" of rake.
For technicalities. 883, 884, 885 are all the same spring rates each is approximately .5" taller in height. From my reading and my experience physical height difference in springs or spacers in the front yields double the change in ride height. So my .5" spring height difference yielded my 1" difference in height. I believe the 895/895e is the same story. Same spring rate just different height.
In my experience and from seeing other people's threads the net lift numbers ARB/OME provide are a pipe dream. Although I forgot to measure before hand, based on measuring identical year/package trucks and from data from the site that the 884 actually showed me about a 3.5+" lift in the front. 883 is at about 2.5" I ordered from Toytec but talked to Wheelers as well. Both techs said my initial setup would be fine. I obviously didn't agree after it was all said and done. Slee has my setup listed as their low lift for the 4th Gens. I suggested to both Toytec and Wheelers that since they offer the 895e as a package build option that, based on ARB's advise, they also put the 883 springs in as an option. I had to go searching and they carry them but I think they were listed in the Tacoma section. I do not know if they ever considered my suggestion.
That was long but hopefully helpful.
Defensor Fortis 02'-12'
" Sammy" 2006 SR5/OME Lift/Wulf UCA/C4 Fab Sliders and Skid/Kenda Klever AT2/BajaRack/Snorkel/Homebrew Drawer/Interior LED swap/TRED Pros
