12-13-2015, 02:20 PM
#1531
Originally Posted by t-man
Lift spindles for the front, lift springs for rear. Can throw spacer on top if still need more height.
Thanks!!!
12-13-2015, 02:34 PM
#1532
Real Name: Tony
Real Name: Tony
Originally Posted by bhest
Thanks!!!
What size tires you thinking of?
2005 Toyota 4Runner, Sport Edition, V8, K&N filter, Doug Thorley headers, custom dual exhaust, Bilstein 5100 W/ Tacoma TRD coils in front, FJ Cruiser coils, Daystar 1.5" spacer W/ Doetsch Tech 8000 10" shocks in rear, 2.5" 4crawler Body Lift, removed Sway-Bars, removed mud flaps, removed running boards, chopped body mount, 315/70-R17 Hankook Dynapro MT
Build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
12-13-2015, 02:50 PM
#1533
32's or 33's
12-13-2015, 02:58 PM
#1534
Real Name: Tony
Real Name: Tony
32's or 33's
Oh OK. You only need about 2.5"-3" of lift for that. You'll have to cut the body mount and pull the inner liner forward, but that's normal routine for bigger tires.
12-13-2015, 03:00 PM
#1535
I'm looking for some help for lifting my 2005 SR5 V6. I was e-mailing back and forth with a local shop, here is a copy/paste of the conversation:
"Hey I've got a stock 2005 4runner sr5 and am looking to get a 3" lift in the next few months.
I don't want a simple spacer kit, I'm pretty serious about offroading and would like a rock crawling rig for Moab, but it still has to be good on road as a family suv.
3" lift front and back is what I want.
I was thinking about bilstein 5100 front and rear shock absorbers but have not decided on coils yet. Not sure if I want coils for medium load or heavy load though.
I would like an estimate on how much this would cost and what some options are for coils that you guys have."
RESPONSE:
The Bilstein 5100 is essentially a spacer lift. You run the stock coils and adjust the shock to how much lift you are wanting. if your thinking of running the OME coils, you need to run their struts. Here is the ARB application guide: http://arbusa.com/uploads/PDF/access...ota4Runner.pdf the tallest is going to be 2" without any additional spacer. depending on the weight you are carrying, it may sit higher or lower. if you want a true 3" lift, you may need to consider doing after market coil overs so you can set them where you want them. and in the rear, you may do the coils plus a spacer to achieve that. and at that point ,the 5100 will not work in the rear either. you would need to run either OME or measure and we can get a shock that will work for you. I hope this helps, if there is anything you are looking, send it over to me, and i can try to price it out for you and check availability.
the Toytec is just a spacer lift, we sell one also, but yes, if you did the OME coils and added a spacer, you can achieve 3" of lift. We do only Toyota and Suzuki's no jeeps, and we sell parts for all years of Toyota. The boss' wife drives a 4th gen 4runner. I can sell you what you like, i think a diff drop is worth the install, but to each their own, (you know how opinions are). we offer a spacer lift to get 3" of lift, and you maintain the factory ride quality. it is much cheaper, but whatever you like, we can get it for you. just let me know what you need and i will get it written up for you. the bilsteins 5100 are intended for 0-2" of lift, and i don't think they will work with 3" of lift, it may limit the amount of travel your getting. we do have them though they sell for $94.27 each.
OME Front Coil Springs - Light Load, Stock Weight, No Bar or Winch, 2.5-3" Lift (2884)
Old Man Emu OME Rear Coil Springs, Medium Load (2895)
Toyota Tacoma Old Man Emu Nitrocharger Sport Front Shock, (90000)
Old Man Emu OME Nitrocharger Sport Shock (60004)
$880.12 for the ome parts. What I'm wanting is a 3" suspension lift for rock crawling.
He's saing the Bilstein 5100 is a spacer lift, but i don't think he is including the fact I would be replacing coils too.
I have no idea what a good place is to buy parts at online (I want to compare prices) and exactly what I want.
I really like this build and it has OME 884s in the front, and Toytec Superflex coils in the back, with bilstein 5100s all around.
Should I trust this shop that they know what they are talking about? Should I talk to someone else at it? They only sell stuff, they don't install.
12-13-2015, 03:11 PM
#1536
Real Name: Tony
Real Name: Tony
RESPONSE:
OME is good, and I agree with the bilstein 5100 shocks. They are a great entrance upgrade but if you want a crawler I'd go with coilovers. You will get much more performance with them. Cost more of course, but work way better. I'm not saying OME is bad either, I just think for what you are saying you want the coilovers are going to be much better.
12-13-2015, 03:26 PM
#1537
Wait, so I'm confused on all the lingo. I thought coilovers were the same as the coils (spring looking things)
Do coilovers only go on the front, for IFS? and in the rear you'll have coils + a shock absorber?
I was looking at both Toytec and OME complete kits just to make things easier:
Toytec
OME
Is there a major difference in off-road capability between these 2? I think I was leaning more towards the toytec kit.
12-13-2015, 03:42 PM
#1538
Real Name: Tony
Real Name: Tony
Toytec
OME
Coilovers are just for the front. Coilovers are a coil that goes around a shock, much like our front setup. The difference is the coilover has threads to adjust the springs up and down. Regular shock/coil setup has a non-adjustable perch like your stock setup. Bilstein 5100 shocks let you adjust that perch up and down for lift, much like a coilover. Now, of the 2 kits you listed the toytec one is just bilstein 5100 shocks that the front has been converted to the coilover threads. They are still Bilsteins. The OME kit is arguably a better kit overall. Fox, camburg, icon, King, etc will have much better coilover designs. They are better valved and controllable.
You don't necessarily need better shocks for rock crawling, but you do need good armor. Skid plates, sliders, etc. Also, long travel is great for rock crawling as it let's your suspension flex more so you can climb things easier. Camburg, total Chaos, and Allpro make kids for the front. Metal tech makes me for the rear. Rock crawling is expensive. Hell anything offroad is! It just depends on your budget. I guess a better question for me to ask is what your total build funds are currently? Based off that we can give you a couple options to suit your budget until you can do more later.
12-13-2015, 05:08 PM
#1539
Right now I'm just focusing on a lift. I'm young, married, have a child, work full time and school full time.
I live in Utah and we do a lot of local offroading and Moab crawling also. I'm on a budget of around $1,000 for all of the suspension for now. I'm going to very slowly build my 4runner.
I'm starting with suspension, then probably in the next few months I'll also get some sliders, but one of my offroad friends said he can build some for cost of the parts (he welds). So far my stock skid plates have done me a really good job, I've slid around on them quite a bit in Moab and they've held up well for skid plates. I do want to look into better armor replacements for all of them though, and I'm still on edge for a front bumper since that will be so expensive, although I would love to have one if budget wasn't a concern. I might see if my welding friend could help build one.
I don't care to have the most well built one in the offroad group, I just want to be able to keep up with all the jeeps in moab. Especially with my budget, I won't have an amazing rock crawler anytime soon, it just needs to be more capable than stock.
This 4runner is also my daily driver.
12-13-2015, 06:10 PM
#1540
Real Name: Tony
Real Name: Tony
That helps! My bad for not asking the correct questions to start! So, personally I have only had the Bilsteins. I have flogged the hell out of them and I can say I'm not overly impressed. My understanding is that they are just a little stiffer to help with towing and/or heavier tires which I feel they do a decent job at. Big improvement over stock IMHO. Now, I hav3 read of several people switching to OME and saying they are drastically better than the billys. So, with that in mind and your budget I would go with the OME setup. I took a screen shot of what I would order which is in your budget.
Now, if you can swing it you can buy the Radflo kit from Metal Tech for ~$1500. http://www.metaltech4x4.com/p-626-ra...nsion-kit.aspx
This is a true coilover setup, 2" shocks that will perform much better. You can also add parts as needed, control arms front/rear, and all those other goodies later. (as with anything you go with) In the end it's up to you of course. Make sure you start a build thread and show us what you do!
I plan on making my own sliders too. Need to find a welder friend myself. Lol
12-13-2015, 06:32 PM
#1541
That helps! My bad for not asking the correct questions to start! So, personally I have only had the Bilsteins. I have flogged the hell out of them and I can say I'm not overly impressed. My understanding is that they are just a little stiffer to help with towing and/or heavier tires which I feel they do a decent job at. Big improvement over stock IMHO. Now, I hav3 read of several people switching to OME and saying they are drastically better than the billys. So, with that in mind and your budget I would go with the OME setup. I took a screen shot of what I would order which is in your budget. Attachment 183301
Now, if you can swing it you can buy the Radflo kit from Metal Tech for ~$1500. Radflo 2.0" 03-Current 4Runner Suspension Kit
What do you think about the diff drop? Is it a good idea to get it? a lot of people seem to swing one way or another on here with suggesting it or not.
And is there a specific reason you chose the 885 instead of the 884? I don't plan on getting a replacement bumper anytime soon, and if i end up getting one it probably won't be for 4-5 years anyway.
Although I did just buy a pop up tent trailer so I'll be towing that quite a bit.
12-13-2015, 06:39 PM
#1542
Real Name: Tony
Real Name: Tony
You don't need the dif drop, I just look at it as a cheap safety measure. Won't be an issue unless you add spacers to that. I chose the med spring because it will help with hard jounces and such. Mostly if you decide to go faster in the desert it will help a ton. Best of both worlds situation.
Depending on the weight of the trailer you may want to get the heavier springs. I tow an enclosed trailer, approximately 5800lbs, and I sag even with FJ coils.
12-13-2015, 07:16 PM
#1543
Real Name: John
Real Name: John
These guys know what they are talking about. If you want cheap, go with Bilstiens and a spacer in the rear, I did, it cost me used $90, I love it!!! You want more, do it a bit at a time. Unless you go (new) full blown custom suspension, 4runner suspensions in my opinion are NOT very expensive, but they can be. Good luck.
2004 V6 2wd Sport - BFG Mud T/A KM 255/75/17, Bilstein 5100’s: front FJ coils, 4" lift spindles set @ .85, rear Metal Tech LT MD coils, SS brake lines, Uniball UCAs, Spidertrax; K&N air filter w/ HCF delete, WeatherTech Liners, dual batteries w/ isolator, inverter w/ 110v outlets, on-board air, satellite radio, custom grill emblem and roof rack; Mods: auto headlights, aux remote reverse LED pods and GY6.35 50w reverse bulbs, rear camera, interior LEDs, VSC, 12v w/ added outlets and windows always on, DRL on/off w/ always on mode, fog/map light, key reminder, TPMS bypass, front wheel liner relocate; de-badged, mud flaps, running boards, resonator, Xreas, front/rear sway bar removed
12-13-2015, 07:34 PM
#1544
Ok, I'll probably end up going with the one you linked then without the dif drop. Med spring sounds good, my trailer is only about 2000 lbs loaded.
What are the "Front Top Plate Spacers" that cost $60?
What do you think about spidertrax? I'd like the aggressive look from the wider stance, but if they aren't any more useful for offroading I'll just skip them to put that money elsewhere. I read somewhere (on reddit i think) that they put extra strain on the IFS and can cause issues because of that.
12-13-2015, 07:44 PM
#1545
Real Name: Tony
Real Name: Tony
Here's a link to a good thread about OME. Old Man Emu springs and shocks.
The spacers give you a full 3" of lift which isn't a bad use of the $60.
Wheel spacers are fine, most of us run them until we can get some aftermarket rims with the correct offset. Depending on tire size you may need the spacers to get your tire away from the spindle too. They and any offset rims provide more force on the front wheel bearings. This over time can make them wear faster. One other note, if you use wheel spacers you need to make sure you have a torque wrench so you can torque the lug nuts down to the correct amount. If they aren't you run the risk of breaking them and losing a wheel going down the road. Other than that, you will be fine.
