04-14-2016, 11:09 AM
#1681
Finished, 5100's on 2, FJ coils, and a wash. Dropping off to my son now. Thanks everyone for holding my hand through my fist build.
04-14-2016, 11:13 AM
#1682
What lift setting are you using in the front, by 2 you mean the 1.75" notch? Do you have a spacer in the rear? Looks nice
2003 V6 Limited
04-14-2016, 11:14 AM
#1683
Set on second perch and no lift in the back just FJ coil
04-14-2016, 11:22 AM
#1684
Looks great! What was the total lift gain in front/back?
2003 V6 SR5 4x4 - 3/2 lift w/ Bilstein 5100's & ARB Springs, at3 285/70/17, 1.25" spacers, customer roof rack, customer cargo drawers
1990 V6 4x4 - sold
04-14-2016, 11:41 AM
#1685
I totally spaced measuring prior to lift. But I will say a bump over 2". Final measurement for front is 37" on both sides, and for rear driver side 38 1/2 and passenger side 39". I'll take measurements after a month or so to see what the settling in difference is. I had the 1.5 daystar ready to install, but after I saw the front after installing 5100's I didn't want to go any higher. Figured it would not match up and make my new tires look smaller. So I held back and glad I did. I think it looks perfect. It's only 2wheel drive, so no need. I rides sweet. Could not have done it without the help from some awesome guys on here.
04-14-2016, 08:29 PM
#1686
Maui, that looks perfect. I'm about to do the same thing to my 04, 2WD, V8.
Do you have the parts list and where did you buy from?
-2004 4Runner Limited 2WD, V8
Bilstein 5100s/MOOG FJ Springs, GROM USB/Bluetooth, Fosgate Sub/AMP Upgrade, Hankook Dynapro AT 265/70-17
-1999 4Runner SR5 2WD, V6
205,000 miles, Tundra Brake Mod (Daughter rolled over and totaled, but she walked away)
04-14-2016, 08:38 PM
#1687
Bought it all from RockAuto. Just put your year and make, and you will get the correct parts. I can look my records up and and see, but you can also call them. They will hook you up
04-15-2016, 02:51 AM
#1688
Real Name: Miah
Real Name: Miah
Way to go looks amazing!!!
Your one hell of a father for what you did, stepped out of your comfort zone and stepped into something you thought you were incapable of doing and above your skill level....
And you still let a bunch of 4Runner luvin wrenching wheeling junkies talk you into it? You had your times of confusion along with some battles but you always came back the next day to get ur done.
Well brotha you've earned my respect.
Job well done, fuk'r!!!
4th Gen 2WD to 4WD CONVERSION
2003 SR5 T4R Pac Blue Metallic w/rear locker, on 35" Mastercraft MXT’s, TC uca"s, TC lca"s, 2.5 King C/O's w/remote resi TC lca gusset kit, Taco Tabs, 2.5 Icon remote resi w/adj on rear Shock Hoops, adj panhqrd A 3.5" lift springs, 10" HD Series AirLift bag, hidden winch W/ 10k Smittybuilt, DMZ eng mounts
04-17-2016, 05:25 PM
#1689
Real Name: Robby
Real Name: Robby
I have an 05 (v6) with 5100s all around, stock springs in the front and 2in spacer in the rear. I ordered Icon 2" coils and need a recommendation for the front coil to replace the stock coil springs...Im looking at the toytec/eibach coilsl or the OME 885s... any other coils i should consider?
I have a Demello aluminum front bumper, front runner roof rack w/ 2 jerry cans, a 150lb RTT and sliders.. so a decent amount of added weight.
Sent from my SM-N920T using Tapatalk
Build -- CLICK HERE Instagram and Facebook @ Ordinaryoverland
04-20-2016, 08:15 PM
#1690
Correct combo of coils and shocks?
Moved
04-22-2016, 01:15 AM
#1691
1st Mod to stock '07 Ltd 8 cyl 4WD
I just bought a set of Bilstein 5100s for the front of my '07 Ltd 8 cyl 4WD, no XREAS. 121K miles
Reason: I want to level out the stance and occasionally drive rutted unpaved roads.
note: All suspension currently stock and rides very nicely.
Question: What setting do I need to to use on the front Bilsteins to achieve this level stance?
Future plans: TRD 17" wheels and 285 70 tires
04-23-2016, 07:49 PM
#1692
Hey guys,
I'm having a shop replace all 4 front control arms and I'm going to be buying the cam adjusters assuming they're all siezed (Canada).
Is the part that usually gets stuck only p/n 48409D? Does the bolt get stuck inside the cam sleeve or does the cam sleeve get stuck to the bushing sleeve? Looking to reuse the bolt, nut and one cam if possible.
Can I get away with only replacing this item?
THanks
2003 V6 Limited
04-24-2016, 12:13 PM
#1693
Tacoma TRD spring part numbers?
just the front left and rights. TRD progressive not linear sports? TIA
04-24-2016, 02:42 PM
#1694
04-26-2016, 03:38 PM
#1695
FJ Coils and bilstein 5100s
After reading through countless threads I think I have finally gathered enough information to make a decision on my suspension lift. I drive a 2003 2WD 4Runner SR5 and really like mauidivers setup so I have chosen to go with the FJ coils and bilstein 5100. I have located some FJ Coils from an 07 FJ Cruiser that have 100k miles on them. So my question is how used is too used when it comes to the FJ coils and would these be a good investment to install having 100k miles on them. Sorry for my ignorance as I am very new to this and don't want to buy something that I might need to replace after a couple years when I could have purchased new.
Another question I have is what is the part # for the specific bilstein 5100 adjustable shocks that everybody uses? I have done a few different searches and feel like I am finding different options for my 03 4Runner. Are people using the FJ Cruiser setup for the bilstein 5100 or just searching for the shocks that would fit their specific vehicle, in my case a 2003 2wd SR5.
Thanks in advance for your time.
iicky
- 2003 4Runner 2WD V6 SR5
- 1976 Chevy C10 Stepside
