04-26-2016, 03:45 PM
#1696
I would recommend against purchasing coils with 100k miles on them. If they're $20 each then maybe, otherwise you simply won't be getting value for money. They are probably not performing as good as you are hoping for.
04-26-2016, 03:49 PM
#1697
Real Name: Tony
Real Name: Tony
Originally Posted by iicky
After reading through countless threads I think I have finally gathered enough information to make a decision on my suspension lift. I drive a 2003 2WD 4Runner SR5 and really like mauidivers setup so I have chosen to go with the FJ coils and bilstein 5100. I have located some FJ Coils from an 07 FJ Cruiser that have 100k miles on them. So my question is how used is too used when it comes to the FJ coils and would these be a good investment to install having 100k miles on them. Sorry for my ignorance as I am very new to this and don't want to buy something that I might need to replace after a couple years when I could have purchased new.
Another question I have is what is the part # for the specific bilstein 5100 adjustable shocks that everybody uses? I have done a few different searches and feel like I am finding different options for my 03 4Runner. Are people using the FJ Cruiser setup for the bilstein 5100 or just searching for the shocks that would fit their specific vehicle, in my case a 2003 2wd SR5.
Thanks in advance for your time.
Go to Down South Motorsports and put in your info. Cheapest place, great customer service.
2005 Toyota 4Runner, Sport Edition, V8, K&N filter, Doug Thorley headers, custom dual exhaust, Bilstein 5100 W/ Tacoma TRD coils in front, FJ Cruiser coils, Daystar 1.5" spacer W/ Doetsch Tech 8000 10" shocks in rear, 2.5" 4crawler Body Lift, removed Sway-Bars, removed mud flaps, removed running boards, chopped body mount, 315/70-R17 Hankook Dynapro MT
Build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
04-26-2016, 03:52 PM
#1698
FJ Cruiser - Old Man Emu OME 895 Coil Rear Springs
Thanks techno, thankfully I had a plan B as well. I found some brand new FJ Cruiser - Old Man Emu OME 895 Coil Rear Springs on craigslist that say they provide a 2in rear lift, which I believe other drivers have used along with the bilstein 5100 in this forum. Is that safe to say you can pair these 2 together? The seller wants 200$ for the rear pair, is that a good deal?
iicky
- 2003 4Runner 2WD V6 SR5
- 1976 Chevy C10 Stepside
04-26-2016, 04:01 PM
#1699
895 coils are good, but they stiffen up the ride since they are designed for carrying constant heavy loads. Not a bad thing, just be aware, some people want lift and stock feel. Yes, you can run them with billies.
$200 on CL is a ripoff. $150 max assuming you'd pick them up.
or pay for shipping from somewhere like this
http://wheelersoffroad.com/product/t...rear-coil-set/
04-26-2016, 04:09 PM
#1700
New the OME 895's are $168 or thereabouts - some places have free shipping. If you are in Phoenix, check out SierraExpeditions. No affiliation, I used to wheel with the guy who runs it and he has good prices.
04-26-2016, 04:22 PM
#1701
FJ Coils
Thanks guys! They don't have to be OME but I am having a difficult time finding stock coils online in my area that are worth purchasing. I found some decently priced FJ coils online just by searching. What are your thoughts on the Moog coil springs? I have read that they do not fit sometimes. But any suggestions are welcome for FJ coil springs I just need to make sure they will work on my 03. The moogs I found were between 50-70$ and I am not planning on doing heavy offroading since I have a 2wd so I am mainly doing fj coils for a little added lift and nicer ride than stock.
iicky
04-26-2016, 04:30 PM
#1702
Real Name: John
Real Name: John
@ iicky
You have a 2wd and live in Arizona, you could pre-runner it out with front lift spindles and long travel rear for some desert fun.
2004 V6 2wd Sport - BFG Mud T/A KM 255/75/17, Bilstein 5100’s: front FJ coils, 4" lift spindles set @ .85, rear Metal Tech LT MD coils, SS brake lines, Uniball UCAs, Spidertrax; K&N air filter w/ HCF delete, WeatherTech Liners, dual batteries w/ isolator, inverter w/ 110v outlets, on-board air, satellite radio, custom grill emblem and roof rack; Mods: auto headlights, aux remote reverse LED pods and GY6.35 50w reverse bulbs, rear camera, interior LEDs, VSC, 12v w/ added outlets and windows always on, DRL on/off w/ always on mode, fog/map light, key reminder, TPMS bypass, front wheel liner relocate; de-badged, mud flaps, running boards, resonator, Xreas, front/rear sway bar removed
04-27-2016, 02:06 PM
#1703
Xreas questions
I'm planning on removing my xreas system from my 04 Sport Edition v6 2wd. Is the process simple, as in a pull out the old and plug in new? Is there any associated hardware I will need to purchase get it done? Any advice would be greatly appreciated!
04-27-2016, 08:54 PM
#1704
Real Name: Tony
Real Name: Tony
It's very simple, but you have to do all 4 shocks at once when losing the XREAS because they are connected with a hydraulic house, a brake line really. I just cut mine off after unbolting the shocks since it was junk at that point.
04-27-2016, 10:07 PM
#1705
lifted
full album here: Lift complete - Album on Imgur
Bilsteins 5100 all around, 2 inch in front, Old Man Emu 885 coils in front, fj coils in rear with 1.25 in spacer. Just need bigger tires now.
04-28-2016, 03:44 PM
#1706
Real Name: Christian
Will 255/75r17 tires be okay on a 9 inch wide rim? will it look funny?
04-28-2016, 07:58 PM
#1707
Real Name: Neil
Real Name: Neil
I've got some stock OEM coils I pulled off my 04 V8 with about 110,000. I'm asking $40 for all 4 if interested. I didn't read entire thread so if this way off base I apologize.
1st was an 87, 2nd was a 95 and 4th gen is a 04 V8 Sport. OME 885/Toytec RCC2.0HD, SPC UCA's, RCI Sliders with top tread, Airlift 1000, and BFG ATKO2's - 265/70/17's. Tekonsha brake controller, EBay interior LED's, and Kenwood DDX 594 radio. Yakima roof rack for all seasons up top.
04-29-2016, 10:56 AM
#1708
My take on the compatibility issue is
that the 5100s are under dampened for the spring rate of the 895s. Maybe this changes over time..and i hope it does b/c the 5100/895 ride could be better. I've read that the OE 5th gen rear coils result in 1.5 to 2.0" rear lift and the rides better..
05-02-2016, 05:06 PM
#1709
Can you tell suspension options by Vin?
Looking into buying a nice 2003 V8 Limited but the current owner is clueless as to what type of rear suspension it has. I don't want to drive all the way out there to realize it has RAS... does anyone know if there's anyway to look up the vehicle by Vin # to see what factory suspension it came with? Already checked CarFax with no dice!
05-03-2016, 03:28 PM
#1710
Where can I find a 4 inch leveling kit for my 2wd 2004 4Runner
4 or higher please. Thanks
