Thread Tools Rating: Thread Rating: 41 votes, 4.93 average. Display Modes
Old 11-20-2011, 11:21 AM #16
Desert Fox's Avatar
Desert Fox Desert Fox is offline
Real Name: Bill
Desert Fox is on a distinguished road
Desert Fox's Avatar
Real Name: Bill
[QUOTE=ARK_SWAMP_RIDER;912075]
Spacer lifts:
Spacer lifts are designed to work with your factory suspension components. This type of lift is great for those looking to keep the stock XREAS. Spacer lifts provide added clearance for off road, but they provide no other benefits. If you spend a lot of time off road, or even occasional off road that’s at a moderate level, this probably isn’t the best option for you. Spacer lifts are not made to handle added weight, such as front/rear bumpers. Spacer lifts have very little effect on ride quality. All spacer lifts are essentially created equal. About the only difference between them is the material they’re made of, all end up with the ame results.
Lift amounts range from ½” to 3”. With spacer lifts, it’s important to determine you want. Some people use these to simply get rid of the factory rake. This is accomplished by raising the front 1”-1.5” (most common, some have used different amounts). Others choose to lift both the front and rear. It is common for the kits to be sold in unequal sizes. The front is typically 1” higher than the rear, which also helps to get rid of the factory rake. It is important to note that you will gain double the spacer thickness in lift in the front ONLY. For example, a 1” thick spacer will provide 2” lift. A 1.5” rear spacer would net 1.5” lift.
This is very good, I was getting ready to do a search regarding tire sizes and lifts.
There are 2 additions to this that should be added by more knowledgable people.
There is a major difference in the types of spacer lifts- Top Load and Pre Load. The difference is in installation but also the amount of shock travel which impacts articulation.
The other item to add is the lift from using FJ shocks and coils. I dont know much about that but I see several people doing it.
Thanks again for taking the time to post this.
I pledge allegiance to the flag of the United States of America, and to the republic for which it stands, one nation under God, indivisible, with liberty and justice for all.
Desert Fox is offline   Reply With QuoteReply With Quote
Old 11-20-2011, 11:26 AM #17
gaterose's Avatar
gaterose gaterose is offline
Real Name: Matt
gaterose will become famous soon enough gaterose will become famous soon enough
gaterose's Avatar
Real Name: Matt
Originally Posted by ARK_SWAMP_RIDER View Post
I've thought of one more thing I'd like to add. I'd like to gather a list of helpful installation guides to include in the original post. Do any of you guys have links that you found useful? If so, post them up and I'll add to the first post for easy reference. Thanks!
I really think the best installation guides are the ones you listed in your first FJ lift thread. I personally used those and didn't have any problems.
2017 Tacoma TRD OR - His
2014 4Runner Limited - Hers
'13 Silverado Z71 - Sold
'03 4Runner UnLimited - Sold
gaterose is offline   Reply With QuoteReply With Quote
Old 11-20-2011, 11:34 AM #18
snowbrdr033's Avatar
snowbrdr033 snowbrdr033 is offline
snowbrdr033 is on a distinguished road
I believe 120 has some really good instruction threads for lift kit installs!
'05 Black Limited V8 with XREAS / LED Interior & Exterior Swap / Custom LED Ground Lighting Strips Mounted Below Running Boards / HCF Delete / AFE Air Filter (Dry) / Optima YellowTop / DDM Tuning 35W 5000K HID Fogs / Weathertech Digital Floor Liners & Cargo Mat / 20" Enkei Wheels / Tacoma Skidplate / Built In Headrest DVD Monitors with Custom Covers / iPod Adapter / Pioneer AVIC-D3 HU with Navigation / PassPort 9500xi, Hardwired / 50% Tint / Custom White/Blue LED Gauges & HVAC /
Coming Soon: Lift, UCAs, 1.25" Spidertrax (have 'em, just waiting on install)
snowbrdr033 is offline   Reply With QuoteReply With Quote
Old 11-20-2011, 01:27 PM #19
ARK_SWAMP_RIDER's Avatar
ARK_SWAMP_RIDER ARK_SWAMP_RIDER is offline
ARK_SWAMP_RIDER will become famous soon enough ARK_SWAMP_RIDER will become famous soon enough
I'll post a few of those threads up later, then add as stuff comes along.
Desert Fox,
IMO the preload vs topout spacer discussion is a thing of the past. most lifts now are 2" or under are topout. Those over use a combination. In the past, there were smaller spacers offered in a preload, buy I don't see that much anymore. If you think it'll be beneficial, I'll add that in. as for lift amounts with the fj setup, I have another thread with that info. There's a link to it in my original post in this thread. Its titled 4th gen: for all who've done the fj swap.
Let me know if there are any other questions or suggestions.
2003 Limited V8 - sold - Build Thread | JL Audio amp/sub | Icon stage 2 | 1/2" Body Lift | 265/70/18 Nitto TG G2's | 18" Limited wheels | Spidertrax | Clazzio's
2016 Trail Premium - Bilstein 5100 | Airlift 1000 | 285/70/17 Cooper AT3 4S | XenonDepot HID | RAV4 Blindspot Mirrors | Kicker Subaru Tweeter Upgrade | Lock'er Down Console Safe | Sprint Booster
ARK_SWAMP_RIDER is offline   Reply With QuoteReply With Quote
Old 11-21-2011, 10:52 PM #20
4Runner4.7's Avatar
4Runner4.7 4Runner4.7 is offline
4Runner4.7 is on a distinguished road
4Runner4.7's Avatar
Amazing break-down of suspension options. Thank you
06 Limited V8
4Runner4.7 is offline   Reply With QuoteReply With Quote
Old 11-22-2011, 10:23 PM #21
Dividers have been added to hopefully make the long post easier to read. I also added links to several install write-ups that I've used/referenced. If there are any others you'd like to see included, or any info you would like added, let me know and I'll do what I can.
Old 11-23-2011, 03:17 AM #22
Overland Warehouse Overland Warehouse is offline
Overland Warehouse is on a distinguished road
For instal instructions on front coilovers and rear shocks with pictures and torque specs, please feel free to use our link Overland Warehouse LLC Installation Instructions
We have had hundreds of people instal their own suspension following these instructions.
Regards
Mark
Overland Warehouse is offline   Reply With QuoteReply With Quote
Old 11-23-2011, 06:17 PM #23
Thanks for the info Mark, I've added that to the OP.
Old 11-24-2011, 01:11 AM #24
Just as a notice of warning for many who instal lift kits on 4th and 5th Gens...
Please be aware that when lifting your rig in the back you can stretch the rear brake line if you are not careful.
Check by raising your truck off the ground and allowing full droop. Check your brake line where it changes from hard line to rubber line (look for it roughly the left side of the rear axle as it comes down from the body).
Now you also need to confirm that your are at full flex! Get someone to stand on the left tire to make sure.
At Overland Warehouse we include a brakeline extension bracket with our extended travel kits to alleviate this problem. You can also change to longer braided lines buit then, beyond the cost of the lines, you also have to drain and bleed the brake system.
Just a heads up. You dont want to be breaking a brake line while offroading!
Regards
Mark
Old 11-24-2011, 10:29 AM #25
Again, thanks for the info Mark. I've added that info to the original post.
Old 11-26-2011, 06:06 PM #26
momo.75's Avatar
momo.75 momo.75 is offline
Registered User
Real Name: Morris
momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of
Registered User
momo.75's Avatar
Real Name: Morris
Great info!
momo.75 is offline   Reply With QuoteReply With Quote
Old 12-05-2011, 05:32 PM #27
jaybird93000's Avatar
jaybird93000 jaybird93000 is offline
jaybird93000 is on a distinguished road
so i know i may be beating a dead horse here, but you listed the tire sizes to fit each lift. So any 275 in an 18 isn't going to fit? I currently have 265/60/18 Firestone Destinations, and want to put on 275/65 Duratracs... Will it take lifting both front and rear to manage this?
2017 TRD Offroad Premium "2CRAYC"
OG: Galactic Gray 2K6 Limited "CRAYC"
Build:http://www.toyota-4runner.org/4th-ge...ld-thread.html
jaybird93000 is offline   Reply With QuoteReply With Quote
Old 12-05-2011, 07:51 PM #28
The tire size is width/heigh/wheel. Some 275's will fit, all depends on the height. A 275/65/18, especially the Duratrac, will require a lift. You'll need to lift the front 2.5-3", so to keep the vehicle level you'll want to raise the rear as well (not sure if it's technically required for fitment, but is for aesthetics). Even with a 3/2 lift, so minor trimming might be required with those tires (mainly moving the fender liner forward).
That's in stock form. I see you have Spidertrax, they'll definitely rub. You'll need to plan on moving the fender liner forward, removing front mud flaps, and possibly trimming the front bumper slightly (even with a 3/2 lift).
Old 12-05-2011, 07:57 PM #29
momo.75's Avatar
Registered User
Real Name: Morris
Registered User
momo.75's Avatar
Real Name: Morris
Just got my DS 2.5/1.5 in and was hopefully going to install it this coming weekend. As far as tires i am leaning towards the BFG Rugged Terrain A/T's in 265/70 18. I should be good with the fit, right? I already have Spidertrax on.
Old 12-05-2011, 08:16 PM #30
The 265/70/18 measures 32.6" tall. You can use that as a reference in the original post. That's not a common size, so I can't say for sure. I don't think the body mount will be an issue, but I'd expect to do similar trimming as with the 285/70/17's. The only person I'm aware of running that size is yellowssm, but he's running 5100's and OME. He might be able to give you some feedback on the size and what's required.
Lift is in w PICS!!! OME, Superflex, 5100's, Daystar, and Michelin 265/70/18's!!!
'90 Suspension Options brettniles Classic T4Rs 11 05-29-2013 03:41 PM
Suspension Options/FAQ Alex T4R 5th gen T4Rs 9 03-10-2013 12:48 AM
Options for Upgrading Non-KDSS Suspension on a TE jerlane 5th gen T4Rs 10 04-19-2012 06:47 PM
Suspension Options mckinley 5th gen T4Rs 0 01-16-2011 12:57 PM
Suspension Options thread? trd_4runnin 3rd gen T4Rs 8 02-02-2010 06:01 PM
