Thread Tools Rating: Thread Rating: 41 votes, 4.93 average. Display Modes
Old 07-03-2019, 03:46 PM #3376
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Originally Posted by epicchaos View Post
Hey guys. I reached out to a lift website with questions on if I should go with Toytec superflex for the back since the stiffness is so much closer to stock versus the 895e and I got this reply.
Well,
Actually Bilstein shocks and OME springs are a bad combination, the
reason why is because Bilstein shocks use a digressive valve system
which means "the faster you go, the softer they get" and OME springs are
designed to carry weight.
So if you mix a "stiffer" spring with a "softer shock it will be like
mixing water and oil and at that point the shock won't perform as
designed and the spring won't hold the weight properly.
ARB, OME, Bilstein and some other companies DO NOT recommend that
combination at all and all warranties will be voided from both
manufacturers
Whats your thoughts because there's tons of people on these forums that have mix matched. Furthermore would y'all recommend OME 884 for front and Superflex for the back? Since my back won't have much added weight except when traveling to camp I figured the additional weight scales wasn't needed. Thanks for help on this stuff.
They don't even know what digressive valving means. Or how springs work.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 07-03-2019, 05:03 PM #3377
JShipps JShipps is offline
JShipps is on a distinguished road
[QUOTE=RancidMartian;3299029]
Originally Posted by JShipps View Post
I did the 3” package, the rear springs are rated for medium load since we off road a lot but rarely pack heavy
Also, did you have to do the UCA kit or did you keep the original?
4Runner Noob
2007 SR5 V6
JShipps is offline   Reply With QuoteReply With Quote
Old 07-04-2019, 08:50 PM #3378
Kid4runner Kid4runner is offline
Kid4runner is on a distinguished road
Ok, just looking for suggestions and there is just too many options/combos. Here is what I have: 06 4 runner sport that I will be deleting the Xreas system. It is a v6 2wd. It has daystar 2.5/1.5 that I would like to remove but keep the height at 2.75 all the way around. I do have a bit of driver lean. I am running 275/65r18 duratracs. I rarely off road but do pull a boat at about 2800-3000lbs. The truck has 175k on everything original except the LCA/UCA/Stabilizer/sway bars up front. Would like to replace shocks springs that will give me a good ride while towing and give like 2.75 lift. Thoughts?
Kid4runner is offline   Reply With QuoteReply With Quote
Old 07-05-2019, 06:28 PM #3379
Dustin1 Dustin1 is offline
Real Name: Slim Shady
Dustin1 is on a distinguished road
Oops. Thanks for catching that and for the info.
Dustin1 is offline   Reply With QuoteReply With Quote
Old 07-07-2019, 01:38 PM #3380
Niffnorf Niffnorf is offline
Niffnorf is on a distinguished road
Need advise on levelling kit
2003 4Runner LTD V8 with RAS
XREAS removed bilstien HD installed
Looking at 2.5 levelling kit and bfg ko2 265/70/17
Anything I need to watch for?
Thanks ahead !!
Niffnorf is offline   Reply With QuoteReply With Quote
Old 07-07-2019, 03:09 PM #3381
Jason B's Avatar
Jason B Jason B is offline
Official Vendor
Jason B is just really nice Jason B is just really nice Jason B is just really nice Jason B is just really nice
Official Vendor
Jason B's Avatar
Thanks ahead !!
I can make you any size kit you want. Below you will see some options. The 2/1 and 3/2 are most popular but I can do a 2.5/1.5 for ya too. Let me kno. Call or text 717-319-2100 or order here
Burtman Industries lift and leveling kits for 4th gen, on sale
For 4Runner/SUV Accessories, please visit www.burtmanindustries.com
My 4Runner website
https://www.youtube.com/user/burtmanindustries, New YouTube channel! please subscribe and I'll make more videos!
[email protected]
DO NOT PM - text/call 717-319-2100 (24/7)
Jason B is offline   Reply With QuoteReply With Quote
Old 07-08-2019, 01:35 PM #3382
Conley's4runner Conley's4runner is offline
Conley's4runner is on a distinguished road
Tires rubbing on sway bar
I just installed a toytech 3inch lift kit and SPC UCAs on my 04 and when I turn the wheel to full lock I can feel them rubbing significantly on the front sway bar. I am currently running 265/70 BFG ko2, I had these before I installed the lift and O never experienced any issues with rubbing on the sway bar. I haven't had an alignment yet and i'm wondering if any one else has had this issue and if I need spacers to fix the problem.
Conley's4runner is offline   Reply With QuoteReply With Quote
Old 07-09-2019, 11:52 AM #3383
jrm's Avatar
jrm jrm is offline
jrm will become famous soon enough
jrm jrm is offline
jrm's Avatar
Ill try..but i have more of an understanding of suspension from MTBs and Motos then cars/trucks but i think the fundamental bits are applicable in theory.
So what their saying is that the bilstein is digressive meaning its valved to become softer as the shock progresses thru its stroke. The OME springs/struts is linear or progressively sprung/valved meaning it gets harder as they progress thru their stroke in order to carry additional weight beyond OE amounts for bumpers and such.
So by combining a digressive strut with a linear/progressive spring you're going in opposite directions when you want to pair digressive with digressive and linear with linear so the rebound/compression/frequencies are similar throughout the struts/shocks stroke and the coils travel.
If your set on going the bilstein route pair them with digressive coil springs. You might have to check with the dealer/manufacturer to find out if the springs are digressive or not though. Other wise you might look at OME or Dobinson linear struts/shocks. Not sure if this helps ....
jrm is offline   Reply With QuoteReply With Quote
Old 07-09-2019, 01:44 PM #3384
montijo505's Avatar
montijo505's Avatar
You probably need a sway bar relocate. Can be found on toytec website
Old 07-11-2019, 07:35 PM #3385
Ace1204 Ace1204 is offline
Ace1204 is on a distinguished road
Ive read hundreds of posts here with mixed answers and all slightly different lift results.
I was wondering if someone could give me some advice here.
I just purchased a 2005 4Runner Sport v8 with 59k miles.
It has Xreas currently so i opted for the toytec 2.5” spacer in the front and 1.5” lift in the rear
Front hub center to fender is measuring 21.25”
Rear Hub center to fender is measuring 22.25”
My question is this.
Planning on getting the SCS Ray 10 in 17x8.5 with -10 offset so i was curious what size tires i could fit without tons of rubbing issues
275/70/17 in the BFGoodrich KO2 is only offered in E rating so I’d like to step up to the 285/70/17 C rated Duratrac if possible but not if its going to require a body mount chop.
Also Would there be an advantage for me to go to the -38 offset wheels?
Thank you
2005 4runner V8 60k miles currently
Ace1204 is offline   Reply With QuoteReply With Quote
Old 07-12-2019, 02:01 AM #3386
montijo505's Avatar
montijo505's Avatar
4th Gen Suspension Options/FAQ
Thank you
With that mild of a lift and -10 with 285’s you’re gonna have to chop the mount. It sounds like a bigger deal than it is. Any shop that isn’t trying to gouge you should only charge about $30 to do it. If you’re unwilling then consider smaller tires, I’m not sure if 275’s will fit as I’ve never run them. I have the Ray 10’s in the -38 and 285 AT3W’s and they took quite a bit of work to make them fit.
Bonus pic 4th Gen Suspension Options/FAQ-img_1646-jpg
Old 07-12-2019, 11:19 AM #3387
ManhstuhT4R ManhstuhT4R is offline
ManhstuhT4R is on a distinguished road
I would just do a OME lift kit with soft valving shocks for a nice daily! Let me know if you have any questions! Anthony at Toyteclifts here and we always have special deals for forum members!
ManhstuhT4R is offline   Reply With QuoteReply With Quote
Old 07-13-2019, 01:44 PM #3388
Should have mentioned that this is more of a weekend utility ride. Ride quality is important but more so when pulling. Would this change your recommendation? Thanks for sharing your knowledge.
Old 07-20-2019, 01:43 AM #3389
drew360 drew360 is offline
drew360 is on a distinguished road
What 2.5" suspension lift kit combination should I get while retaining quality ride for my 08 SR5 and to fit 265/70R17 tires without rubbing issues?
Will it require sway bar relocation kit?
Will it require longer sway bar link if not installing sway bar relocation kit?
Expert advice please!
Thank you and more power...
drew360 is offline   Reply With QuoteReply With Quote
Old 07-20-2019, 11:10 AM #3390
wtcnbrwndo4u wtcnbrwndo4u is offline
wtcnbrwndo4u is on a distinguished road
You can fit 265/70/17 without a lift BTW and you won't have rubbing issues. Did you mean 285s?
General recommendations are the Toytec/Boss lift, yes get a sway bar relocate, longer sway bar links or disconnectable sway bar links are far more expensive than a relocate.
2003 4Runner Limited 4x4 V8, Volant CAI w/ LC100 snorkel, modified C4Fab hybrid bumper with wings, Superwinch Tiger 9500, RSG Angled Sliders, 5100s/885/RCC2.0, TRD Wheels, Duratrac 285s, 1.25" Spacers, RIGd Ultraswing
wtcnbrwndo4u is offline   Reply With QuoteReply With Quote
'90 Suspension Options brettniles Classic T4Rs 11 05-29-2013 03:41 PM
Suspension Options/FAQ Alex T4R 5th gen T4Rs 9 03-10-2013 12:48 AM
Options for Upgrading Non-KDSS Suspension on a TE jerlane 5th gen T4Rs 10 04-19-2012 06:47 PM
Suspension Options mckinley 5th gen T4Rs 0 01-16-2011 12:57 PM
Suspension Options thread? trd_4runnin 3rd gen T4Rs 8 02-02-2010 06:01 PM
