03-10-2013, 06:15 PM
#631
Originally Posted by whte4r
Greatly appreciated! Last question, will upgrading from 265/65/17 to 285/70/17s play a part with the UCAs at all? Hes putting those tires on when he does the alignment, so I guess we'll find out. Thanks a lot.
You will need wheel spacers or aftermarket wheels to push the tire out away from the UCA. I doubt the UCAs would provide any benefit here.
2003 Limited V8 - sold - Build Thread | JL Audio amp/sub | Icon stage 2 | 1/2" Body Lift | 265/70/18 Nitto TG G2's | 18" Limited wheels | Spidertrax | Clazzio's
2016 Trail Premium - Bilstein 5100 | Airlift 1000 | 285/70/17 Cooper AT3 4S | XenonDepot HID | RAV4 Blindspot Mirrors | Kicker Subaru Tweeter Upgrade | Lock'er Down Console Safe | Sprint Booster
03-11-2013, 12:37 AM
#632
I know the info is probably in here somewhere but I thought someone could help me find what I am looking for. I am wanting to put a 1 inch body lift on my t4r. Any advise on what to buy, where to buy it, or anything else I should know? I will most likely be paying a shop to do it because the task seems pretty overwhelming to me.
2007 SR5 4wd - 35% front tint - Remote start system - 12inch kicker sub - crunch 500w amp - 265/70/17 Cooper Discoverer AT3 - Plasti-dip grille - Cobra 19 DX CB radio - 100w PA speaker - TRD Off Road stickers - 6K LED license plate lights - HCF delete - Husky all weather mats - Satoshi grille mod - OME 885 front coils - Toytec superflex rear coils - Bilstein 5100 shocks - Light Racing UCA's - SCS Stealth 6 wheels - LED Reverse lights - *ordered BAMF sliders and LCA skids*
Build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
03-11-2013, 01:01 AM
#633
You going to toss on some bigger tires to go with all that lift? Don't get me wrong, your ride is awesome, but the 265-70-17's are already looking a tad small with all the lift you already have - right? (Just curious).
2006 T4R SR5 v8 4wd: Napa Ultra Premium Rotors; Weather Tech liners; AVS Ventshades; Westin Bull Bar; Hydrocarbon Delete; Blackhoused Headlights; Fog Light Mod; Sulfer TSB; Magnaflow 22" Muffler (#12586); Front: Bilstein 5100's set at .85" + Toytec 1" Net "Top1-T" Spacer = 2" total Front Lift; Rear: Cornfed 1" + Air Lift 1000; Plasti-Dip center grill + rear Toyota Emblem; JVC Bluetooth + HD Radio HDR81BT
http://www.toyota-4runner.org/new-me...purchased.html
03-11-2013, 12:58 PM
#634
Yes, 285's will be coming this summer and I would like to do a body lift with them to make sure it fits perfectly.
03-11-2013, 06:05 PM
#635
Awesome. I look forward to seeing it!
03-11-2013, 06:16 PM
#636
Real Name: Chris
Real Name: Chris
Toytec 1".
2007 SE V8
HID's, interior LED mod, sweet floor mats, awesome tunes and some more stuff...
...more stuff
03-11-2013, 06:36 PM
#637
Toytec or 4crawler. At 1" the steering spacer is optional. I'd suggest getting quotes on install before going to far on it, I got a few quotes locally and they were insanely high.
03-11-2013, 06:43 PM
#638
Okay I will look into the price of doing it. Where can I buy them online though?
03-11-2013, 07:12 PM
#639
on the tire/lift fitment guide.. when it states (except bfg at) on stock suspension, does that mean that it does not require some trimming or what.. lil confused..
actually im leaning toward the cooper discover atp 265/70/17.. will this fit stock till i lift.
2007 Driftwood Pearl SR5 V6 4x4 /MB Wheels TKO 17x8.5 -6mm/ Hankook dynapro mt2 285/70/17 / bilstein 5100s -1.5 daystar rear spacer lift on moog fj coils / 1" Toytec body lift / ddm hids / interior leds / reverse light led / vsc - atrac disable mod / limo-30% tint/ rear diff breather mod / rola vortex roof rack / hanma 30" LED lightbar / kenwood ddx373bt w backup camera / ppi p900.4 / sundown sax1200d sa8d4v1.5 / diamond audio d6 comps / SPPC black halos
03-11-2013, 09:00 PM
#640
Toytec
4crawler
Install write-up
If you'll notice, 4crawler lists the typical 1" kit as options D+RAD. You don't have to have the steering spacer, but also wouldn't hurt to add it either.
You should be fine with 265/70/17 at stock height with those tires. As long as you are running stock wheels and are not running wheel spacers, they shouldn't rub or require trimming. BFG AT's have a very square profile and have more rubbing that most tires in the same size, which is the reason for the note.
03-11-2013, 09:09 PM
#641
thanks ... now i can get my tires first.. then save for lift and spacers..
03-12-2013, 12:09 AM
#642
Real Name: Mike Davies
I got my OME full suspension lift put on yesterday, and I had the LR UCAs to put on with it. When I went to pick it up, my mechanic (who works at toyota dealership but works for me on the side for cash) said I didnt need new UCAs. I tried searching before I ordered them, and thought I came to the conclusion that it was better to just get em and have em on so I didnt run into problems later...
So, my question to all of you even though I know its been talked about numerous times is....what should I do? Put on the new UCAs or leave the old ones on. He is doing the alignment Monday so we'll see if there are problems there but he insisted on returning them.
The more lift, the less caster you will have. After market UCAs have the upper ball joint (or uniball) positioned farther back in the arm. The reason for this is the axis on which the UCA pivots compared to the lower control arm. Take a look, you will notice that it makes the upper end of the spindle move forward as the arm moves down. This has a negative effect on caster. I just had mine aligned today, 3" lift spacers with FJ springs. It sits a good deal higher that stock, about four inches. Toe is easy to make work, camber I had them set to zero, caster however, is out of spec. The only way I will get it back is to either hack up my UCAs and weld them back together in an altered state, or buy after market UCAs. So far it seems to drive just fine, so I think I'll just let it be although I am seriously considering getting a set of stockers, relocating the upper ball joint more rearward (and outward) with compensation for my new static angle, and using a bolt-on ball joint from a Gen2 4Runner. It sounds like a fun engineering anyway!
03-12-2013, 01:43 PM
#643
@ ARK_SWAMP_RIDER
What did you end up doing for your body lift? Install yourself?
03-12-2013, 01:58 PM
#644
@ ARK_SWAMP_RIDER
Yea, I did the install myself. It took me a while, but wasn't really difficult. The front two mounts were the most time consuming, but I took it slow and got it done.
03-18-2013, 01:47 PM
#645
I have a silly / stupid question about Bilstein 5100s. I thought ride height was determined (more or less) by what kind of springs you run. How is the shock absorber able to change this setting? Also, how many ride height settings are available and what (approximate) lift amounts do they correspond to?
