03-18-2013, 01:51 PM
#646
Originally Posted by AKmoney
I have a silly / stupid question about Bilstein 5100s. I thought ride height was determined (more or less) by what kind of springs you run. How is the shock absorber able to change this setting? Also, how many ride height settings are available and what (approximate) lift amounts do they correspond to?
They adjust the height of the collar that the spring sits on increasing the height of the spring relative to the lower control arm. They have 4 settings. 0, .85", 1.75", 2.5"
-2006 T4R Limited
Light Racing UCA's, FJ coils, Bilstein 5100's (front at 2.5"), Daystar rear 1.5" spacer, Spidertrax 1.25" wheels spacers, General Grabber AT2 275/65/18
03-18-2013, 02:16 PM
#647
Thanks... Do these settings correspond with actual (or expected) suspension lift? Is the 0 setting the same offset as a stock shock?
03-18-2013, 02:19 PM
#648
They seem to be pretty darn close. Yes, the zero setting would be the same height as a factory replacement.
-2006 T4R Limited
03-20-2013, 12:45 AM
#649
Not enough clearance, Clarence...
Having bashed up my original skid plate not too long ago I took the opportunity to upgrade it to an RCI. This also made it easy to measure the minimum ground clearance:
It's a little hard to see but I measured approximately 7 3/8". I'm a little perplexed at this considering the 4WD 4Runner was spec'd as having 9.1" of clearance. Could the stock suspension have really sagged that much over the nine year lifespan of my 4Runner? My tires are stock-sized (265/65-17) and are inflated to 35psi.
I would like to get this clearance measurement back up to the 9.1" that Toyota originally claimed it would be. I have a set of low-mileage FJ springs ready to go; I'm thinking maybe these plus a set of Bilstein 5100s set at 0.85" may do the trick? Thoughts?
03-26-2013, 08:36 PM
#650
Real Name: Jake
Real Name: Jake
Would Front FJ springs with 5100's all around front set at max with Toytec Superflex in the rear work? And if not, would buying new FJ coils from Moog or Raybestos off RockAuto be a good or bad idea compared to buying used from someone over at the FJ forums? If that worked it would come out between 2.5-3"?
My Old Build
03-27-2013, 08:25 AM
#651
That'd work very well and put you at 3" front and 2" rear (approximately). Pretty much everyone buys used, I would think the others would work though.
2003 Limited V8 - sold - Build Thread | JL Audio amp/sub | Icon stage 2 | 1/2" Body Lift | 265/70/18 Nitto TG G2's | 18" Limited wheels | Spidertrax | Clazzio's
2016 Trail Premium - Bilstein 5100 | Airlift 1000 | 285/70/17 Cooper AT3 4S | XenonDepot HID | RAV4 Blindspot Mirrors | Kicker Subaru Tweeter Upgrade | Lock'er Down Console Safe | Sprint Booster
03-27-2013, 08:40 AM
#652
Real Name: Jake
Real Name: Jake
Sweet I've been lurking around the FJ forums for a while looking for low mileage ones, and for the prices I've seen for used its almost worth it to just buy new as long as the quality is just as good.
My Old Build
03-27-2013, 09:27 AM
#653
You're probably going to have better luck posting in the WTB section over there than waiting for a set to pop up for sale at a reasonable price. You're right though, buying a new aftermarket set may be the way to go, IF quality is good. I have no experience with them so can't say one way or another.
03-27-2013, 09:35 PM
#654
Real Name: Jake
Real Name: Jake
Did a little reading up on Aftermarket Moog coils. From what I read, everyone either hated them and removed quickly, or replaced them after a year when they were too saggy and needed replacing. Looks like I'll be putting up a WTB over on FJForums.
My Old Build
03-27-2013, 09:40 PM
#655
Wow that's very good to know. I was considering those actually..
2006 T4R SR5 v8 4wd: Napa Ultra Premium Rotors; Weather Tech liners; AVS Ventshades; Westin Bull Bar; Hydrocarbon Delete; Blackhoused Headlights; Fog Light Mod; Sulfer TSB; Magnaflow 22" Muffler (#12586); Front: Bilstein 5100's set at .85" + Toytec 1" Net "Top1-T" Spacer = 2" total Front Lift; Rear: Cornfed 1" + Air Lift 1000; Plasti-Dip center grill + rear Toyota Emblem; JVC Bluetooth + HD Radio HDR81BT
http://www.toyota-4runner.org/new-me...purchased.html
03-27-2013, 09:44 PM
#656
Real Name: Jake
Real Name: Jake
I didn't really find anything about the Raybesto coils from RockAuto, but I don't know how much I trust them being that they don't even reference the fact that they make coils on their own website.
My Old Build
03-27-2013, 10:46 PM
#657
FJ coils
If you can afford it buy new , just me but found mine @ carsontoyota.com pretty good prices & they beat partznet by a good bit ! Just punched n 07-09 fj off to the races . I like to err on the safe side , most people are ok but .....
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
03-27-2013, 10:53 PM
#658
Real Name: Jake
Real Name: Jake
How much did you find them for?
My Old Build
03-27-2013, 11:46 PM
#659
Wow, that's good to know. Another suggestion, log on to the Tacoma forums and see if you can find a set from a 05-? Tacoma. The coils are beefier than the FJ's, give about double the lift, but still ride very well. I was running Tacoma shocks/coils on the front of mine for a few weeks until my new parts came in, I was very impressed. Since the Tacoma swap isn't a popular upgrade (yet), maybe you can find a set for cheap/free.
03-28-2013, 12:27 AM
#660
Just looked their right @ 78$ for fronts & some change, rears bout 90 per .
