Thread Tools Rating: Thread Rating: 41 votes, 4.93 average. Display Modes
Old 06-10-2013, 06:59 AM #796
JohnnyT's Avatar
JohnnyT JohnnyT is offline
JohnnyT is on a distinguished road
JohnnyT's Avatar
Originally Posted by ARK_SWAMP_RIDER View Post
Look like you guys are on the right track. I've installed the 2.5/1.5 and also the budget boost, install is the same (unless you get the 2.5/1.5 kit from Wheeler's that still used the preload spacer). 2.5/1.5 or Budgest boost front/1.5 rear would be the same difficulty to install, I can't say one is better than the other. It's purely up the the individual and how much rake they want left. When I did the 2.5/1.5, the results were very close to 2.5/1.5.
With the design of these kits, the install is very easy. The only problem is that for you guys up north, rust can be a real issue. I'd read through the write-ups and find every bolt you'll need to touch, then start soaking it in penetrating oil (WD-40 or similar) every day for at least a week. Any shop that does suspension or lift installs can do it. If they are not familiar with XREAS, just be sure they don't disconnect the lines and it'll be fine. It's not a hard install if you decide to do it yourself.
Thanks
Anyone have the part # of the easier kit.? I was looking at this one.....
Daystar Lift Kits for Toyota 4Runner -Wheeler's Off-Road, Inc-
2007 Sport 4x4 V8, Magnetic Gray - stock
JohnnyT is offline   Reply With QuoteReply With Quote
Old 06-10-2013, 08:27 AM #797
ARK_SWAMP_RIDER's Avatar
ARK_SWAMP_RIDER ARK_SWAMP_RIDER is offline
ARK_SWAMP_RIDER will become famous soon enough ARK_SWAMP_RIDER will become famous soon enough
Originally Posted by JohnnyT View Post
Thanks
Wheeler's sells the old style that uses a preload spacer and is more difficult to install. Anyone else should be selling the newer version. To my knowledge part numbers are all the same. For the 2.5/1.5 it's KT09115BK.
2003 Limited V8 - sold - Build Thread | JL Audio amp/sub | Icon stage 2 | 1/2" Body Lift | 265/70/18 Nitto TG G2's | 18" Limited wheels | Spidertrax | Clazzio's
2016 Trail Premium - Bilstein 5100 | Airlift 1000 | 285/70/17 Cooper AT3 4S | XenonDepot HID | RAV4 Blindspot Mirrors | Kicker Subaru Tweeter Upgrade | Lock'er Down Console Safe | Sprint Booster
ARK_SWAMP_RIDER is offline   Reply With QuoteReply With Quote
Old 06-10-2013, 08:35 AM #798
JohnnyT's Avatar
JohnnyT's Avatar
Thanks. Do these look like the newer kit?....... Just want to ensure I'm getting the right kit.....
2003-2009 Toyota 4Runner Lift Kits - Daystar KT09115BK - Daystar Comfort Ride Lift Kits
Or
Daystar Part KT09115BK - 2.5 Inch Lift Kit
Or
http://www.summitracing.com/parts/dys-kt09115bk
Daystar KT09115BK Comfort Ride 2.5" Strut and Coil Spring Spacer Kit : Amazon.com : Automotive
Old 06-10-2013, 08:51 AM #799
jconusn's Avatar
jconusn jconusn is offline
jconusn is on a distinguished road
jconusn's Avatar
The one at auto anything looks to be correct, the one at 4-Wheel parts looks odd, nothing like the one I have. I would go with auto anything or Amazon.
2005 Limited V8 | 5100s at 2.5" Front | FJ Coils F/B | Daystar 1.5" back | Level 8 Mk6 | Dynapro ATM 265/70/17
jconusn is offline   Reply With QuoteReply With Quote
Old 06-21-2013, 10:36 PM #800
HLinn23's Avatar
HLinn23 HLinn23 is offline
Real Name: Hunter Linn
HLinn23 is on a distinguished road
HLinn23's Avatar
What would happen if I put the fj springs with daystar 2.5, and added the 1/4 (1/2) topout spacer?
05 4runner Daystar 2.5/1.5, Topout spacer, FJ Springs 1/2" BL, 33x12.50r17 nitto mud grapplers, Rockstar wheels, Curt roofrack,led light bars, Window tint all the way around, 6000k Hids, Led swap, Vent visors, Push bar, Body Mount Chop, Blacked out headlight
HLinn23 is offline   Reply With QuoteReply With Quote
Old 06-22-2013, 07:36 PM #801
Ukraine Train's Avatar
Ukraine Train Ukraine Train is offline
Ukraine Train is on a distinguished road
Can you guys tell me if 255/70/18's will clear with FJ springs and maybe a 1/4" front spacer? These are the same 32" height as 255/75/17, which are supposed to fit according to this thread, but I saw someone mention in another thread that they had rubbing with 255/70/18's on FJ springs and a 1" spacer. If it does rub, would it be minimal and just need the liner pushed out? I'm looking at getting Vision Warrior wheels which are 18x8.5 with a +25mm offset, which should push the tire outboard a bit also. Thanks!
Ukraine Train is offline   Reply With QuoteReply With Quote
Old 06-23-2013, 09:06 AM #802
HHIRunner's Avatar
HHIRunner HHIRunner is offline
Real Name: Jake
HHIRunner is on a distinguished road
HHIRunner's Avatar
Real Name: Jake
A positive offset in the rims I believe would actually bring the wheels further in. To push them out from stock people get either 0 or -12 offset rims. And I don't know about the tires with that setup.
My Old Build
HHIRunner is offline   Reply With QuoteReply With Quote
Old 06-23-2013, 09:22 AM #803
I wouldn't suggest doing that. With that you'll be at 3.5-4" lift which will cause cause issues getting the alignment back into spec. This will also put a lot of stress on the front end, CV's in particular.
I ran the 255/75/17's with just a 1.5" lift in the front and had no rubbing issues at all. Later on I added wheel spacers to push the tires out, and had quite a bit of rubbing then. The guy in that link doesn't appear to be running spacers, I would not have expected any rubbing.
Once you get the wheels on, you'll need to trim the front bumper and either trim or remove the front mud flaps.
Old 06-23-2013, 02:23 PM #804
Perfect, thanks. I think I will stay with 265/65/18's then... it's only a 1/4" ground clearance difference.
Old 06-24-2013, 10:07 PM #805
wnelax04sr5's Avatar
wnelax04sr5 wnelax04sr5 is offline
Real Name: Ethan
wnelax04sr5 is on a distinguished road
Real Name: Ethan
realistic tire options
ive worn my geolanders down to nothing, and its time to replace. i want to go with either destination at's or terra grapplers, in either a 265/70 or 285/70. my concern is that i have a 3/2 spacer, that has settled to about 2 and 3/4 and 1 and 3/4. my ground to fender with 265/65's is about 35.5. im not worried too much about the rear, but is it possible to run 285/70's without totally ripping apart my bumper? i have spidertrax too btw
A lot of stuff I didn't need...
My Build
Originally Posted by kfitz77555 View Post
oh my god the erection I have from this thread is unreal.
wnelax04sr5 is offline   Reply With QuoteReply With Quote
Old 06-26-2013, 12:43 AM #806
BaconTaco BaconTaco is offline
BaconTaco is on a distinguished road
Sub'd
BaconTaco is offline   Reply With QuoteReply With Quote
Old 06-26-2013, 06:13 PM #807
Sorry, just now seeing this. Since those are mild all terrain tires, your rubbing may not be quite so bad. The rubbing it typically minimal on the bumper, about five minutes with a sharp knife/razor will easily take care of that. It's the rear part of the front fenderwell that has caused issues for me. You'll need to remove the mud flaps and possibly trim some plastic behind them. If you're not really flexing off road you will probably be fine with the trimming mentioned above.
Old 06-26-2013, 09:29 PM #808
Real Name: Ethan
Real Name: Ethan
thanks ark!
My Build
Old 07-07-2013, 11:22 AM #809
rfuree11's Avatar
rfuree11 rfuree11 is offline
rfuree11 is on a distinguished road
rfuree11's Avatar
I'm ducking indoors to enjoy the AC for a few minutes- I'm in the middle of adjusting my Toytec coilovers (the ultimates). Here's a protip not in the Toytec instructions: unbolt your swaybar endlink from the knuckle, move it out of the way and twist your swaybar up. Lash it to the UCA with a zip tie or something similar. I went from getting 1/8 of a rotation on the collar to almost a full half spin.
2007 SR5- Toytec Ultimate, rear Superflex coils, 265/70/17 Duratracs, man-a-fre front skid
rfuree11 is offline   Reply With QuoteReply With Quote
Old 07-07-2013, 02:59 PM #810
stanleybb50's Avatar
stanleybb50 stanleybb50 is offline
stanleybb50 is on a distinguished road
^^^How cool would it be if we could adjust 5100's this way! I would love to move mine up another notch, but don't feel like pulling everything apart again... Plus nine are all corroded, so I don't know if I trust the next level snap ring setting any longer..
2006 T4R SR5 v8 4wd: Napa Ultra Premium Rotors; Weather Tech liners; AVS Ventshades; Westin Bull Bar; Hydrocarbon Delete; Blackhoused Headlights; Fog Light Mod; Sulfer TSB; Magnaflow 22" Muffler (#12586); Front: Bilstein 5100's set at .85" + Toytec 1" Net "Top1-T" Spacer = 2" total Front Lift; Rear: Cornfed 1" + Air Lift 1000; Plasti-Dip center grill + rear Toyota Emblem; JVC Bluetooth + HD Radio HDR81BT
http://www.toyota-4runner.org/new-me...purchased.html
stanleybb50 is offline   Reply With QuoteReply With Quote
'90 Suspension Options brettniles Classic T4Rs 11 05-29-2013 03:41 PM
Suspension Options/FAQ Alex T4R 5th gen T4Rs 9 03-10-2013 12:48 AM
Options for Upgrading Non-KDSS Suspension on a TE jerlane 5th gen T4Rs 10 04-19-2012 06:47 PM
Suspension Options mckinley 5th gen T4Rs 0 01-16-2011 12:57 PM
Suspension Options thread? trd_4runnin 3rd gen T4Rs 8 02-02-2010 06:01 PM
