06-09-2013, 04:49 PM
#781
Originally Posted by JohnnyT
If I have a stock 07 V8 Sport x/Xreas and I want to keep XREAS and get a little bit of lift overall and removal of some, but not all, of the rake, does it make sense to get a spacer kit that is either.....
1" front, 1" back - giving me 2" front and 1" back
or
1.5" front, 1.5" back - giving me 3" front and 1.5" back
....and so on depending on what I want.
Does this makes sense as I'm a total novice and don't understand all the terminology but read this thread?
I want something modest but noticeable.
I agree with the above, the Daystar 2.5/1.5 would probably be the best IMO. There aren't really any 1" spacers available so the 2" front 1" rear option would be hard to do. Also, not many 1.5" front spacers available, so again, hard to do.
2003 Limited V8 - sold - Build Thread | JL Audio amp/sub | Icon stage 2 | 1/2" Body Lift | 265/70/18 Nitto TG G2's | 18" Limited wheels | Spidertrax | Clazzio's
2016 Trail Premium - Bilstein 5100 | Airlift 1000 | 285/70/17 Cooper AT3 4S | XenonDepot HID | RAV4 Blindspot Mirrors | Kicker Subaru Tweeter Upgrade | Lock'er Down Console Safe | Sprint Booster
06-09-2013, 05:42 PM
#782
As a follow up to the above posts, does anyone know the actual lift folks are getting in the front from the 2.5 easy-install (all top mount) Daystar lift? Is it actually 2.5", or closer to 3"? Just curious, does anyone know the actual thickness of the 2.5 spacer?
06-09-2013, 06:01 PM
#783
Thanks guys. I did continue to read other posts and perhaps the Daystar Budget boost (1" in the front) and a 1.5" Daystar in the back is another way to go. Any downsides to this?
Most important to me is to retain the ride I currently have with XREAS so I don't want any "risky" installations that might compromise that. I'd prefer to do nothing rather than risk a botched install.
Are either the 2.5/1.5 or the one I mention in this post at all difficult or challenging to install given I have XREAS?
2007 Sport 4x4 V8, Magnetic Gray - stock
06-09-2013, 07:21 PM
#784
The 1" in front is the "budget boost" and requires disassembly of the front strut/spring because it is a "pre-load" spacer, the 2.5 front goes on top of the strut/spring so it is a much easier install, and easier to undo. If I'm not mistaken, total lift on the budget boost isn't much less than it is on the 2.5. You will have to work in the wheel well either way because the concensus is that disconnecting the lines for XREAS from the shock isn't a good idea because the check valves may fail and leak fluid which means you will have to replace that loop on the system. That is why the spring compression is a big deal as it is harder to do all that in the wheel well than it is if you can take the assembly out and work on it. Hope this helps..
2005 Limited V8 | 5100s at 2.5" Front | FJ Coils F/B | Daystar 1.5" back | Level 8 Mk6 | Dynapro ATM 265/70/17
06-09-2013, 07:38 PM
#785
I just measured the actual spacer, (I have the 2.5/1.5 kit but I am only going to use the rear 1.5 after much deliberation). It is 1.5" thick for the front but it nets more than that for some complicated reason... Explained here, by Ark Swamp Rider, who is the man when it comes to these matters by the way:
"With the 4runner front suspension (this ONLY applies to the front), you gain approximately double the spacer thickness. A 1" spacer yields 2" of lift. As spacer size increases, the ratio goes down slightly. You'd still be looking at about a 1.25" thick spacer, or possibly 1.5" thick. I can't say exactly how much because I've not installed anything over a 1/2" thick spacer.
The rear is simply the spacer thickness. A 1" spacer gives 1" lift."
On a side note, thanks to Ark for all his hard work getting all the FJ/Bilstein etc. info together, it helped me out a LOT.
06-09-2013, 08:21 PM
#786
I think you and I are looking to do the same thing, my friend. I want to keep XREAS, and I want something relatively uncomplicated to install. I am considering one of the following options from Daystar:
1. Budget boost 1" front spacers (2" net) by itself. No rear lift.
2. Budget boost 1" front spacers and 1.5" rear spacers. This would be a 2" front and 1.5" rear lift.
3. 2.5/1.5 lift kit. I'm still trying to determine how much actual lift this would achieve in the front. Many have reported 3", but I'm not sure if that was from the older design, or the newer easy install design, or both. Can anyone confirm?
What I really want is 2" front and 1" back, but Daystar does not have that combo. I also want easy install, top-mount design.
06-09-2013, 08:24 PM
#787
Thanks all. I think the Daystar 2.5/1.5 is definitely the way to go for me.
This is what I want...the pic at the top of this page......
Lift and Tire Central (pics)... Post 'em Up!
06-09-2013, 08:30 PM
#788
Actually the 1" budget boost is a top mount spacer. The one shown on their website requires strut disassembly only because you have to swap out the studs for longer ones.
However, I think the info on their website may be old, and they have now swapped out the design with a true easy install design, see this thread:
Daystar Budget 1" Spacer Install
I sent an email to Daystar before I found that thread, so I will see what they say.
06-09-2013, 08:39 PM
#789
Thanks for the info! If that front spacer is actually 1.5" thick, then folks should be getting 3" of lift. I really don't want more than 2.5" of front lift with 1.5" in the rear. I guess I will keep searching the forum to see if anyone else has reported actual lift heights...
06-09-2013, 08:55 PM
#790
I think that is old info, the new one has studs with it that screw on top of the old ones (female one end, male other) that lengthen the factory studs eliminating the need to disassemble
06-09-2013, 09:02 PM
#791
This thread might shed insight: I don't think people are seeing a full 3" as it goes down numerically as you increase spacer size, ie..1" will give you 2" and 2" will give you 3.75" (pure estimations).
How to make a daystar 2.5/1.5 perfectly level
06-09-2013, 09:07 PM
#792
Then you are good to go my friend! Easiest way to go, and no downsides, keep XREAS, and improve looks/tire options!
06-09-2013, 09:39 PM
#793
Anyone know of a good reliable shop,in NJ that has experience installing the Daystar spacers with XREAS?
06-09-2013, 10:30 PM
#794
Look like you guys are on the right track. I've installed the 2.5/1.5 and also the budget boost, install is the same (unless you get the 2.5/1.5 kit from Wheeler's that still used the preload spacer). 2.5/1.5 or Budgest boost front/1.5 rear would be the same difficulty to install, I can't say one is better than the other. It's purely up the the individual and how much rake they want left. When I did the 2.5/1.5, the results were very close to 2.5/1.5.
With the design of these kits, the install is very easy. The only problem is that for you guys up north, rust can be a real issue. I'd read through the write-ups and find every bolt you'll need to touch, then start soaking it in penetrating oil (WD-40 or similar) every day for at least a week. Any shop that does suspension or lift installs can do it. If they are not familiar with XREAS, just be sure they don't disconnect the lines and it'll be fine. It's not a hard install if you decide to do it yourself.
06-10-2013, 12:37 AM
#795
I think I'm literally the only one to do the following. Probably because people can just put the Bilsteins on the 3rd setting to get a similar lift... I just didn't want too much preload or topout, and went for a little bit of both:
- Bilstein 5100's fronts set at 0.85" (1" lift, although they call it 0.85). This essentially have me 1" lift from preloading, which is what the 5100's do to achieve the lift.
- Also front = Toytec 1/2 (topout spacer) which installs like the Daystar. I forget the part #... Like "Top-1T" or something like that.
The above essentially nets out to 2" front lift, by getting 1" from the billies (preload) and 1" from the topout. Had this on for a year + and love it and very happy with my choice.
- Rear = Cornfed 1" rear spacer (for 1" rear lift)
2/1 overall and quite happy! Be forewarned, once you start lifting though - you might find you want to be "even higher"... Lol. Thus the Daystar is cheap and frankly, gets you a little higher, and could be a good choice.
2006 T4R SR5 v8 4wd: Napa Ultra Premium Rotors; Weather Tech liners; AVS Ventshades; Westin Bull Bar; Hydrocarbon Delete; Blackhoused Headlights; Fog Light Mod; Sulfer TSB; Magnaflow 22" Muffler (#12586); Front: Bilstein 5100's set at .85" + Toytec 1" Net "Top1-T" Spacer = 2" total Front Lift; Rear: Cornfed 1" + Air Lift 1000; Plasti-Dip center grill + rear Toyota Emblem; JVC Bluetooth + HD Radio HDR81BT
http://www.toyota-4runner.org/new-me...purchased.html
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
