Thread Tools Rating: Thread Rating: 41 votes, 4.93 average. Display Modes
Old 09-04-2020, 04:12 PM #3781
hkombrink hkombrink is offline
Real Name: Hayden
hkombrink is on a distinguished road
Real Name: Hayden
Originally Posted by PNWLivin View Post
I'd like to see the pics. I'm thinking about getting the Eibach stage 1 kit.
Sorry for the delayed response. Here are the pics I took. Plan on getting larger tires very soon to fill the wheel well a little more. And like I said before I have retained a little forward rake by a little less than an inch. I plan on replacing the rear springs in the future as well, I currently have the FJ springs with 1.5 daystar spacers in the rear.
4th Gen Suspension Options/FAQ-capture1-jpg  4th Gen Suspension Options/FAQ-capture2-jpg  4th Gen Suspension Options/FAQ-capture-jpg
hkombrink is offline   Reply With QuoteReply With Quote
Old 09-30-2020, 02:00 PM #3782
ericss42 ericss42 is offline
ericss42 is on a distinguished road
Question about buying an older 4th gen with 100k+ miles... if I'm planning on lifting the car anyways, is it worth paying the extra money for a Sport/Limited?
The audio upgrades are something I can easily do myself (and better) for ~$300.
I hate to say it, but I love the look of the hood scoop.
Heated/leather seats would definitely be nice, but not essential.
Keyless entry would be really nice.
Am I better off buying a cheap SR5 and upgrading parts that will likely need replacing anyways? Or are the suspension components more durable than I'm giving them credit for?
ericss42 is offline   Reply With QuoteReply With Quote
Old 09-30-2020, 03:09 PM #3783
andreylights's Avatar
andreylights andreylights is offline
andreylights will become famous soon enough
Sport is better IMO over SR5 cos it will have bigger brakes (but you will have to run 17" rims, which could be argued as a disadvantage) / hood scoop / painted roof rails / dark interior / electric seat adjustment / buttons on the steering. Suspension wise -- they are the same plus you are gonna replace it anyways so dont bother.
07 SE V6, Front: Dobinsons LT GS59-220 + C59-302 w/ ICON UCAs;
Rear: GS59-575 + C59-677V w/ ICON Trailing Arms; PCK;
Coastal-Offroad bumper and sliders; ASFIR aluminum skids;
255/80r17 Falken AT3W on Toyota Trail edition wheels;
andreylights is offline   Reply With QuoteReply With Quote
Old 10-03-2020, 10:30 AM #3784
snucka snucka is offline
snucka is on a distinguished road
anyone with the toytec ultimate 3" lift running 285/75/17's? what all did you have to trim to make them fit? also did you do the UCA as well?
snucka is offline   Reply With QuoteReply With Quote
Old 10-06-2020, 09:53 AM #3785
Currie_1's Avatar
Currie_1 Currie_1 is offline
Currie_1 is on a distinguished road
Currie_1's Avatar
Im planning on doing this size with an Icon 3'' set up and all the research and advice I have gotten is for sure a BMC and a lot of trimming in the front wheel wells as well as a pinch weld mod. I did a 1'' toy tech body lift to make sure I got good clearance. good luck.
2005 Sport / v6 / Icon stage 2 / toytech 1'' body / DO Front / 285/75/17 BF Goodrich KO2s / Fifteen52 Turbomac HD / Prinsu Full Length / Baja Designs & Factor 55 Goodies / Overland Custom Designs Links
Currie_1 is offline   Reply With QuoteReply With Quote
Old 10-06-2020, 10:13 AM #3786
man really? Im currently running 275/75/17's and barely had to trim the front bumper when i changed the tires from the stock wheel to a pro comp wheel. I feel like I still have enough room where I would just need to do some more light trimming of the bumper and wheel well plastic.
Old 10-06-2020, 08:17 PM #3787
Currie_1's Avatar
Currie_1's Avatar
@theforgotten_4r on Instagram is running this size and he isnt running a stock bumper but neither am I, we both have a DO front bumper. if you feel like you could squeeze them in there then go for it. I think your issue is going to be with the body mount if anything. What offset are you running and do you have spacers?
Old 10-07-2020, 11:18 AM #3788
My offset is -6, no spacers and I’m actually planning on putting on the Shrockworks bumper when I upgrade wheels. I do see where they might hit the frame. If I put on spacers I wonder if that would clear it enough?
Old 10-07-2020, 04:18 PM #3789
Currie_1's Avatar
Currie_1's Avatar
I would go ahead and get some spacers just in case, they will resell fast especially if not used. If you are planning on running a front bumper then you shouldn't have any issues if you can get your caster right. (-2 to -4) should give you enough froward movement in the wheel well. I not fimiluar with how much room the Shrockworks has vs an oem bumper but I know a lot of people have been satified with them. Might wanna check the lead times on them though because it could take a while to get to ya.
Old 10-10-2020, 02:38 PM #3790
Sausage_gut Sausage_gut is offline
Sausage_gut is on a distinguished road
I just posted is in the lift and tire thread but this one seems more appropriate
My buddy just upgraded his 5th gen to some kings and he offered these to me for a 100. It will come with the matching rear springs as well. I did some research and it seems like the front will fit but the rear needs modification to get the rears to work. My 4Runner will have an rtt and rack pretty much full time. Has anyone here performed a similar swap (aftermarket 5th gen installed in a 4th gen)? I’m trying to see if it’s worth it to install or just go with a kit designed for the 4th gen.
Sausage_gut is offline   Reply With QuoteReply With Quote
Old 10-13-2020, 03:38 PM #3791
Heffernan's Avatar
Heffernan Heffernan is offline
Heffernan will become famous soon enough
Heffernan's Avatar
Not very familiar with 5th gen stuff but thats an absolute steal for $100. If the front fit, rear springs aren't very expensive, you could just get 4th gen springs and still be in the black. If all else fails, sell the kit and use the money to buy a new 4th gen kit. Win win.
2008 Toyota 4Runner Sport V6
5100s / front 4x4 FJ springs / OEM stock rear springs
ToyTec 1/4" topout spacer & OME 10mm trim packer (both driver side)
General Grabber AT2 tires
Heffernan is offline   Reply With QuoteReply With Quote
Old 10-22-2020, 01:34 AM #3792
ayarsee ayarsee is offline
ayarsee is on a distinguished road
I have a 2005 V8 4wd. Currently on stock suspension but have been running slightly bigger 265/70/17 tires for a while. I’m looking to add maybe 1-2 inches up front, however much is necessary to eliminate the factory rake. I came from a newer Tacoma so I don’t know much about the suspension of these 4runners. I’ve heard that spacers are easy, but that bilsteins and OME’s are the better way to go. I ran the bilsteins and OME’s on my Tacoma and liked them, but I don’t want to spend a whole lot if I can help it. From what I understand, spacers are cheaper, but how do they affect ride quality? I like the way the stock suspension rides and don’t want to compromise that. Any kind of advice or guidance would be appreciated being the newbie that I am.
ayarsee is offline   Reply With QuoteReply With Quote
Old 10-27-2020, 12:39 AM #3793
The-Wood The-Wood is offline
The-Wood is on a distinguished road
Buy a 1/2" top spacer for the front. Gives about 1" lift up front to level. I did that to my 2005 v8. Worked perfect. I happen to have a set for sale after I endeed up lifting the whole truck more. DM me if you want them.
The-Wood is offline   Reply With QuoteReply With Quote
Old 10-27-2020, 12:57 AM #3794
Not able to DM for some reason. Probably operator error on my end.
Old 10-27-2020, 01:17 AM #3795
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
You'll need like 5-10 posts in order to send a DM. Its just there to make sure people are legit before they're able to DM people. A good way to get post count up is to post pics of your rig and projects in their respective threads, or help someone else out with an issue that you've solved before.
y=mx+b is offline   Reply With QuoteReply With Quote
'90 Suspension Options brettniles Classic T4Rs 11 05-29-2013 03:41 PM
Suspension Options/FAQ Alex T4R 5th gen T4Rs 9 03-10-2013 12:48 AM
Options for Upgrading Non-KDSS Suspension on a TE jerlane 5th gen T4Rs 10 04-19-2012 06:47 PM
Suspension Options mckinley 5th gen T4Rs 0 01-16-2011 12:57 PM
Suspension Options thread? trd_4runnin 3rd gen T4Rs 8 02-02-2010 06:01 PM
