Thread Tools Rating: Thread Rating: 41 votes, 4.93 average. Display Modes
Old 03-07-2021, 12:20 PM #3916
BrianSully12 BrianSully12 is offline
BrianSully12 is on a distinguished road
Originally Posted by AuSeeker View Post
Those are a type of "locking nut" the extra tension from the notches keep the nuts from backing off/coming loose, which you don't want to happen.
Much appreciated!
BrianSully12 is offline   Reply With QuoteReply With Quote
Old 03-08-2021, 11:10 PM #3917
Recove Recove is offline
Recove is on a distinguished road
Which one is the cheaper option for a 2” lift? Im looking for a suspension kit, no spacer, no fj springs
Recove is offline   Reply With QuoteReply With Quote
Old 03-10-2021, 01:15 PM #3918
andreylights's Avatar
andreylights andreylights is offline
andreylights will become famous soon enough
eibach
07 SE V6, Front: Dobinsons LT GS59-220 + C59-302 w/ ICON UCAs;
Rear: GS59-575 + C59-677V w/ ICON Trailing Arms; PCK;
Coastal-Offroad bumper and sliders; ASFIR aluminum skids;
255/80r17 Falken AT3W on Toyota Trail edition wheels;
andreylights is offline   Reply With QuoteReply With Quote
Old 03-11-2021, 02:51 AM #3919
pokohucu pokohucu is offline
pokohucu is on a distinguished road
Hello.
V8 - Lined up crank pulley mark to peg to right on 0. Looked at marks on camshafts. All lined up properly. Replaced everything without moving anything. Lined up marks on new belt to marks on cams. Installed tensioner. Rotated crank pulley 360. No marks on cam sprockets of course. Rotated crank another 360. Marks on cam sprockets lined up on left, but looked like off one tooth on right. Also reference lines on belt were missing.
Long story shot. I screwed things up. I don't know where I'm at. What is the best way to get everything lined up in the correct sequence again? I don't know if cams are 360 off or not.
Having trouble finding free porn? We have collected the best for you here 👌 BestFreePornSites.pro – brings you the best porn sites that we can find
What have I gotten myself into and how to correct it?
pokohucu is offline   Reply With QuoteReply With Quote
Old 03-13-2021, 03:13 PM #3920
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous has a spectacular aura about Tironeous has a spectacular aura about Tironeous has a spectacular aura about
Tironeous's Avatar
Real Name: Joe
4th Gen Suspension Options/FAQ
The first post recommends a 3/2 lift to fit 275/70/17 tires. I’m not sure I’m going to end up with 3” up front. Prob more like 2.25” - 2.5”. It’s going to be hard to tell how much actual lift over stock I’ve gained because my truck is on original non-XREAS suspension. My current hub to fender measurements are roughly 19” front and 20.5” rear. I haven’t installed my lift yet due to shipping delays. I’m sure when I do I’ll have gained 3” but I’m not sure that will be 3” over stock.
Below are details on what I have, expect the tires. The tires are where I need help.
- 6112 with 650lb spring to handle the added weight from the V8
- Total Chaos UCAs
- 5160s with Icon 2” rear spring
- Trail wheels (17x7.5 +15 offset)
- BFG 275/70/17 KO2s
I’m wondering how well this is all going to fit. I’m fine pushing the fender liner forward, trimming the bumper, and removing the mud flaps. I’m am trying to avoid a BMC. Anyone have a similar setup?
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Instagram | My "Build" Thread | Bilsten 6112 with 650lb spring | Total Chaos UCAs | Bilsten 5160 with OME 895 | Stealth Custom Series GEN5 Wheels | Dirtcom Trail Swing | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
Old 03-13-2021, 10:29 PM #3921
PronouncedJIF PronouncedJIF is offline
PronouncedJIF is on a distinguished road
Got the 5100 lift kit from bilsteinlifts.com with the 1.75" B12 rear coils but I think I'm going to try staying with stock front coils. Thinking about setting the front 5100s to 1.75" to keep the front close to level or small rake. Any thoughts on this?
PronouncedJIF is offline   Reply With QuoteReply With Quote
Old 03-15-2021, 03:47 AM #3922
Ahnsan Ahnsan is offline
Ahnsan is on a distinguished road
any suggestions for a basic street suspension combo?
Ahnsan is offline   Reply With QuoteReply With Quote
Old 03-15-2021, 01:17 PM #3923
Tironeous's Avatar
Real Name: Joe
Tironeous's Avatar
Real Name: Joe
Eibach pro truck kit
Old 03-15-2021, 02:04 PM #3924
Tironeous's Avatar
Real Name: Joe
Tironeous's Avatar
Real Name: Joe
Should end up with slight rake once it settles
Old 03-16-2021, 06:55 PM #3925
blakkbox blakkbox is offline
blakkbox is on a distinguished road
Postin this in a couple areas to get advice before I can make my own thread. Any advice appreciated!
Problem: Getting bad rubbing during turns on rear of front wheel well and on body mounts. Want to clear rubbing and make this thing at least somewhat capable on and offroad. Red area in pic.
Setup:
2006 4Runner V8 Limited 4WD
Coastal Steel front bumper (~120lbs I think)
Bilstein 5100's front (2.5" lift) and rear (unsure of lift setting)
Bilstein coils / springs in the back (B12 heavy springs)
OEM coils / springs up front
285/70/17 tires (32.8" diameter)
FJ 17" Wheels with 1.25" Spidertrax spacers
JBA High Caster Upper Control Arms
Questions: What can fix this?
Would OME 886 coils in front on 0" Bilsteins achieve more lift to help this? I went to alignment shop and asked for as close to 4° caster as they could give me but they basically lowered them both I'm at 3.3°L/2.77°R and getting pretty bad rubbing. Was hoping to make this thing at least somewhat capable offroad, and at least driveable on the road lol. What else can I do, or do I just need new / smaller tires?
4th Gen Suspension Options/FAQ-img_9520_2-jpg
blakkbox is offline   Reply With QuoteReply With Quote
Old 03-16-2021, 06:55 PM #3926
timbird1219's Avatar
timbird1219 timbird1219 is offline
Real Name: Tim
timbird1219 is on a distinguished road
Real Name: Tim
Got the Bilstien 5100s with OME 855 2” Medium coils, if I set the shocks to the highest setting at 2.5” and still pair them with the coils will it mess up my suspension?
timbird1219 is offline   Reply With QuoteReply With Quote
Old 03-19-2021, 01:48 PM #3927
mysticz's Avatar
mysticz mysticz is offline
mysticz has a spectacular aura about mysticz has a spectacular aura about
mysticz's Avatar
Setup:
I doubt changing any coils will fix the rubbing and you already did the casters setting so I would say your best option is a BMC.
I ran 285's for years with no rubbing running with a 0 offset wheel but once I changed over to a -10 offset it rub at the same area at full turns so I had a SPC specialty alignment shop set my casters and it helped but stilled need s a BMC to be fully capable off road.
2005 T4R Silver SR5 V6 4wd with Mods.
mysticz is offline   Reply With QuoteReply With Quote
Old 03-19-2021, 02:53 PM #3928
Heffernan's Avatar
Heffernan Heffernan is offline
Heffernan will become famous soon enough
Heffernan's Avatar
Setup:
Body mount chop is probably your only option.
2008 Toyota 4Runner Sport V6
5100s / front 4x4 FJ springs / OEM stock rear springs
ToyTec 1/4" topout spacer & OME 10mm trim packer (both driver side)
General Grabber AT2 tires
Heffernan is offline   Reply With QuoteReply With Quote
Old 03-20-2021, 10:22 AM #3929
gibbons gibbons is offline
gibbons is on a distinguished road
2003 Limited Suspension - What should I buy?
Hey, I have a 2003 v8 limited 4.7L with the xreas system. Because of the xreas, my normal mechanic is afraid to mess with the suspension even though I've suggested they could just remove it and replace the suspension like a normal truck. I've called around and another shop was spooked by the xreas too.
They seem to feel better about me buying the suspension parts and coming in just asking for them installed. I don't know what I'm doing, but I want to buy the right stuff. I do a fair amount of offroading, but I also do a lot of towing a 16 foot trailer so I don't want to lift the 4runner and affect towing. I'd like to do this as cheaply as possible, so I don't need the fanciest option.
I've heard Bilstein 5100s could be a good option, although I called Bilstein and told them I had the xreas and they said they don't recommend their products then!
Anyway, has anyone replaced the suspension recently who has or knows my setup? Could you post links to what I should buy? Everybody talks about FJ coils in the back, but would that raise it?
Sorry for asking a question that maybe has been asked too much, but I appreciate any help I can get!
gibbons is offline   Reply With QuoteReply With Quote
Old 03-20-2021, 06:38 PM #3930
Real Name: Tim
Real Name: Tim
Finally put my lift on my 2003 4Runner, used Bilstein 5100s on the front an rear, used 5th gen coils on the rear and stock 4th gen coils on the front with the bilsteins set to 2.5” I’ll reply to the post with an after picture.
'90 Suspension Options brettniles Classic T4Rs 11 05-29-2013 03:41 PM
Suspension Options/FAQ Alex T4R 5th gen T4Rs 9 03-10-2013 12:48 AM
Options for Upgrading Non-KDSS Suspension on a TE jerlane 5th gen T4Rs 10 04-19-2012 06:47 PM
Suspension Options mckinley 5th gen T4Rs 0 01-16-2011 12:57 PM
Suspension Options thread? trd_4runnin 3rd gen T4Rs 8 02-02-2010 06:01 PM
