are heat shields necessary?
I had a bad grinding noise that sounded like the brake dust shield hittin the rotor. turns out the aluminum heat shield above the muffler fell off and was hitting the drive shaft.
Question is do i really need this heat shield? or can i run without? its a pretty light weight one, not like the one above the cat.
any thoughts?
2003 T4R limited V8 4x4, Bilstein 5100's x4, (2.5F/1.25R lift) jacked rear air suspension, BFG AT TA KO 265/70R17, K&N, Sport Brake Upgrade, Husky Cargo Liner, Hawk Pads, Fog Light on Mod, HC Filter Delete, White LED Cluster and Hvac LED swap, USA-Spec Aux/iPod in, 4500k HID Fogs, HIR Highs/Low Beams, Bel rx-75 plus Shifting Radar, 2xHella Rallye 4000Xi, 2x 4x4LED lights, VSC ATRAC ABS off mod, Defiant Light Mountin Bar, Weathertec floor mats, Map Light Mod, Pacesetter Replacement Headers.
