03-16-2013, 11:25 PM
#31
Headlight auto
they stay on until the default time (mine is 30 seconds)
03-17-2013, 04:49 AM
#32
That is correct.
If you want to shut them off instantly, just double press the lock button on the remote.
2004 4Runner SR5 SR5 - V6, 4X4, Moonroof , JBL, Leather, Stratosphere Mica
Installed Mods: Spoiler, HIR bulbs, Kenwood DNX6960 Nav, Back Window Up with Remote Mod, Rear Camera, LED Tails, Key Reminder Disable, OEM Automatic Headlights, Rear USB Ports, Seat Heaters, Aftermarket Third Row, Heated Side View Mirror
Locations: VA
03-17-2013, 11:38 AM
#33
Real Name: John
Real Name: John
Thanks for the info!!!
09-19-2013, 08:05 AM
#34
Just completed this mod! I was lucky enough to find a used light sensor on ebay for $33 shipped, and then I just ended up buying both the headlight switch and wiring harness from ToyotaPartsZone.com for another $130 shipped. Many thanks for the great write-up, which made things go smoothly.
Current: 2006 Toyota 4Runner Sport V6 | White | 2WD | HIDs | Auto Headlight mod | Homelink Mirror mod | Maplight mod | Stock Airbox mod
Previous: 2006 Nissan Titan LE CC | Smoke | 2WD | HIDs | 20" Pro Comps | Nitto Terra Grappler | JBA Catback
Previous: 2004 Infniti FX35 | Graphite | RWD | Sport | 20" EXE Konkave | Yoko Parada Spec-X | Clear Tails | S/S Brake Lines | Strong Strut STB
10-24-2013, 11:52 AM
#35
You rock, OP!
I've been wanting auto headlights for some time now, but then when I realized that I got both the auto function and a new turn stalk I knew this was for me. My '04 SR5 V8 has almost 100k miles on it and when I use my blinker it doesn't always register due to wear, but the new one is perfect!
Also, the HVAC and light sensor were a total pain to install. That part definitely took the longest and tried my patience the worst, but in the end it's totally worth it.
For others thinking about doing this, you may also want to replace the odometer screen at the same time since that thing ends up scratching so easily over time. I replaced mine about a year ago, but may do it again soon due to all the scratches.
01-01-2014, 02:55 PM
#36
Thanks for the write-up. Mod done, $6 sensor from eBay, stalk and harness for $107 from Camel Back Toyota.
2008 SR5: Sony XAV-701HD ● 4300K HID ● Map Light Mod ● TPMS Mod ● +HomeLink Console ● +Auto Headlights
03-20-2014, 10:06 AM
#37
What a great write-up. I am really interested in seeing if anyone has done this on a 5th gen? That is the only thing I miss from my Sequoia and as well spec'd as the '14 SR5 is I am kind of surprised it doesn't have it from the factory.
09-16-2014, 10:52 AM
#38
It's a great write-up. I am really interested in seeing if anyone has done this on a 5 th gen. 4runner trail 2014
09-16-2014, 10:54 AM
#39
This might not be the answer you are looking for, but I have just decided to leave my lights on all the time. If you haven't tried they do turn themselves off after you turn the engine off.
10-20-2014, 12:00 PM
#40
Great write-up
I did this mod yesterday on my Sport Edition. The only real trouble I had was in removing the existing solar sensor (for the climate control). I used the suggestion from a other member and purchased the limited harness which replaces the existing harness. This gives you a factory look without the need for splicing any wires. I got the harness for around $9.00 and a used auto headlamp sensor for $75. The most expensive part is the headlamp dimmer which was about $100. It seems like a lot of money but I am very pleased with the results. I love mods where everything just plugs in. Now if only there was a write up on upgrading from the stock sound system to the JBL. A friend of mine has the JBL in her '05 Limited and it sounds pretty darn good compared to mine.
10-20-2014, 12:28 PM
#41
Real Name: Scott
Real Name: Scott
I'm sure it should be obvious, but I can be slow sometimes. Does anyone have a picture of where the light sensor plugs in? I know there's a blank you remove to plug it in, but I'm staring at my dash scratching my head . . .
-Semper Fi-
2006 4Runner Sport Edition 4WD V6/Suspension/Armor/Lights/Wheels and tires/Drawers/Camping things/Surfboards/Rhodesian Ridgebacks . . .
BUILD AND ADVENTURE THREAD
10-07-2015, 10:22 PM
#42
Real Name: Lance
Real Name: Lance
Did you buy the $6 sensor used on eBay? If not, do you have the eBay seller/store you purchased it from?
2004 Sport Titanium Metallic, Black WeatherTech Mats, J.A.'s Map Light Mod, 2014 Scion Pioneer Bespoke touchscreen w/ Back Up Camera, Arc Audio xdi805 amp, Handsfree phone/bluetooth steering wheel controls, 06-09 OEM LED tail lights, Interior LED Swap, Gentex 177 AutoDimming Mirror w/ Amber Compass, Sunvisor GPS mod, Avitol 4003 Remote Start w/ factory keyfob, J.A.'s DRL Mod, Back Window Up Hack, OEM 115v AC inverter install, Smokers Kit
10-08-2015, 04:43 PM
#43
Real Name: Lance
Real Name: Lance
Originally Posted by iBison
It looks like the light sensor is the same on these vehicles. You should be able to pick one up at a junkyard for a few bucks,
Toyota
2008+ RAV4
1997+ corola
2002+ Matrix
2000+ Highlander
1998+ Camry
1998+ Solara
1999+ Celica
2000+ Sequoia
2003+ 4Runner
2003+ Prius
Lexus
2000+ IS300
1998+ RX300
1997+ GS300
1997+ GS400
1997+ GS430
I went to Crazy Rays junkyard in Hawkins Point today and was able to find the light sensor from a 2003 Lexus GS300. I grabbed the headlight switch as well but I do not think its the same connector on the bottom. Does anybody know of other Toyota or Lexus or Scion vehicles that would use the same auto headlight switch? Thanks in advance.
05-03-2016, 07:19 PM
#44
If somebody is interested in this modifications please let me know
I sold my 4Runner and I have al the part
Thanks
05-04-2016, 12:17 PM
#45
Thanks
are you saying you "have all the parts"? I might be interested in most of the parts.
