Originally Posted by BReardon21
That's so disappointing, this is exactly what I was looking for. I may just buy and fab some type of mount up. For $140 shipped it may be worth milling and welding a proper mount. Just haven't decided if its even worth the hassle. I want to look again in the morning to get a better idea of mount points and clearance. Do you have a v6 or v8? Think that might make a difference?
Well I think I indeed did it wrong, those L brackets hang down from the outside of the frames, not inside.
I realized this after measuring the spacing between the frames(less than 80 cm) and the spacing on the push bar(about 92 cm).
Actually the holes for bolts on the frame are not at the dead center so they might fit.
However I still can't figure out how to drop the brackets into their positions especially on the driver's side, there's a small radiator with its pipes there and leaves virtually no space for the bracket to go in from above. Tried from underneath as well but bumper itself blocked the way.
