12-18-2011, 09:35 PM
Headlight inside moisture
Last January I had my left headlight replaced under warranty due to moisture getting inside. Moisture was on the inside of the lense near the top. The new one was fine until recently, same headlight now has moisture inside and warranty is expired. Any suggestions on where it's getting in and how to seal it up?
Thanks,
Bob
2008 4R Limited Salsa Red Pearl 3Q3
AVS Bugflector, Coastal Lockpick 2, Super Z V1 Radar Detector Mount
Please, no more Hope & Change!
12-18-2011, 11:30 PM
I have the same problem with my left head light..the moisture comes and goes. It used to drive me nuts. Thought it was the seals that go around the bulb sockets, but they appear fine. I just live with it now. Would like to fix it if possible though.
JD
2003 v6, 2.5 1.5 daystar,1.25" spidertrax, 265 75 r16 BFG at, K&N air filter
12-18-2011, 11:51 PM
happened to me too. that's what made my decision to get a new set of headlights. that, and the fact that one headlight was yellow and the other had moisture. these aftermarket headlights i have now allow air to get in, so when it rains or i wash the truck, they get a little foggy temporarily. they were designed to do this so water never stays in them.
2006 Toyota 4Runner SR5 V8 4x4-Nautical Blue Metallic
1986 Toyota MR2 AW11 NA 5 Speed
NJshadow93's 2006 SR5 Build
12-19-2011, 12:52 AM
Real Name: Allen
Real Name: Allen
Same thing, but on my left reflector on the bumper (03 with cladding)
2003 Toyota 4Runner SR5 iForce 4.7L V8 2WD Natural White With Plastic Bumper Cladding, Everything Completely Stock.
Owned since 10/3/11
90,000 Miles and counting!
12-19-2011, 01:17 AM
bake it open and black it out, other wise just bake the headlights for 10 mins at 260 and then squeeze the outter edges together some more till dry.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
12-19-2011, 05:05 PM
JD
Does this seem legit??
Amazon.com: Toyota 4Runner Replacement Headlight Assembly - 1-Pair: Automotive
12-19-2011, 05:47 PM
toyota OEM cost more, those are just replacements. to OP, my oven is too small to fit the headlight in so i dried it out & ran a bead of silicone around the edges. http://www.amazon.com/Permatex-85913...pd_sbs_auto_38
12-20-2011, 09:44 AM
Had a good amount of water in my drivers side head light about a month ago. My lenses are less than a year old thanks to the lovely deer that took them out. I wanted to black them out but didn't have the time.
I removed the drivers side headlight and brought it inside and dumped as much of the water out of it as I could get. Next I took a hairdryer and had it blowing in one bulb hole and exhausting out the other. Took about 30min to dry everything up. I put a coat of Vaseline on all of the rubber bulb grommets. Next I put a thin strip of black silicone around the entire lenses. I reinstalled the headlight and so far over a month later with no moisture inside. Honestly I think the Vaseline is what worked.
03 Toyota 4Runner 4x4 V8
96 Toyota T100 4x4 150k miles (traded)
97 Toyota Corolla CE 167k miles (totaled)
94 Toyota p/u 4x4 150k miles (traded)
87 Toyota p/u 270k miles (sold)
12-21-2011, 02:56 PM
(I am the OP)
I dont think the headlight is leaking, the moisture is on the inside about 7% of the way up the lens and it hasnt rained. I think its condensation so there must be an airleak somewhere.
Bob
12-21-2011, 03:13 PM
My driver side headlight housing allows moisture to get inside too. Enough to actually start dripping down the front interior clear plastic part. I figured I'll take them apart when it gets warmer and do the Black headlight mod.
Current Ride: 2004 Toyota 4Runner Sport V8 4x4
11-27-2021, 03:41 PM
To dry out housing I removed both bulbs and let a vacuum cleaner hose set in one or the other holes for bulb and let it pull air thru to dry out. The housing may need to be resealed.
11-27-2021, 06:32 PM
I'm thinking that in the 10 years since the last post here, his headlights probably dried out all by themselves.
11-28-2021, 01:42 AM
Hahaha
Sent from my SM-T220 using Tapatalk
07 SR5 4x4
