Old 08-20-2019, 09:22 PM #16
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
Originally Posted by BigBlackVenom View Post
I recently bought 2005 4Runner V8 Limited with XREAS disabled and factory RAS is still working with non-XREAS shock. I checked by looking at top of shock with no tube going into and can see tube is disabled and tied, then I looked under body and saw oil cylinder where it is controlled the XREAS. My question is if I go ahead with Bilstein 5100 for all four corners and will the height control still work? I need to keep RAS working because I have 4500 lbs boat to tow around.
The RAS and XREAS are two independent systems that don't require each other to function.
Changing your shocks won't effect the RAS.
Keros is offline   Reply With QuoteReply With Quote
Old 08-21-2019, 09:34 AM #17
BigBlackVenom BigBlackVenom is offline
BigBlackVenom is on a distinguished road
I am looking for no lift and replaced with Bilstein shock with front stock coils. Should I go for 0.85 lift in front and no lift in the rear? I want to make sure that the shocks I ordered are correct for 2005 4Runner limited v8.
2 x B8 5100 Series Height Adj 0-2.5" Front
2 x B8 5100 Series 0-2" Lift Rear excludes x-reas
Thanks!
BigBlackVenom is offline   Reply With QuoteReply With Quote
Old 08-22-2019, 01:24 AM #18
Thanks!
Ok, a few caveats here:
1. I did all this research 2 years ago
2. I'm not a parts cross reference system
3. Information was attained through informal sources
That said, I will attempt to recall what I remember.
Bilstein changed several elements about how they list "lift" values for various kits (around 2017, when I was doing this research for my 6112 kit). Now for whatever reason (I don't recall), the parts themselves did not change, nor the part number; just the entries in the parts catalogue.
So I managed to find somewhere the listing for the 5160 rear shocks' extended length and compressed length. And fortunately someone here on 4Runner forums had posted the same two values for the OEM XREAS shock (I later measured mine after I removed them and the posted value was very accurate).
Anyway, prior to the lift value change, the 5160 had been listed as 0-2" lift... and after it was listed as 0.5-2" of lift. I cannot explain why this change happened (I'm sure some research will turn it up though), but the parts themselves did not change and obviously the extended and compressed lengths remained.
So you'll want to independently verify the compressed and extended length of the 33-187174 and compare that to the XREAS shock's value to ensure you won't ram the valving into the top of the tube on full compression.
Something to note though is that without RAS, the stock ride height on springs allows the rear axle to easily ram the [extended RAS] bump stops. I think the RAS bags provide a non-linear spring rate and thus decelerate the axle prior to hitting the bump stops. If you ever choose to switch to coils it may be prudent to acquire some cushy bump stops; you'll certainly need to ditch the extended bump stops that come with the RAS equipped trucks for the non-RAS truck bumpstops, or get a set of superbumps (which I did).
At my current ride height I have about 50mm of uptravel on the rear before it contacts the superbumps. It's something to be aware of if your RAS ever craps the sheets.
Or... just lift it...
Old 07-28-2020, 02:00 PM #19
Adeadwallnut Adeadwallnut is offline
Adeadwallnut is on a distinguished road
Thanks!
Hey! I know this thread is older but I was wondering if you got this done. If so, did it work out. Were you able to do the installation yourself?
Adeadwallnut is offline   Reply With QuoteReply With Quote
rear suspension help 4runninSD 4th Gen T4Rs 2 09-27-2011 10:27 AM
What kind of rear suspension does the 4Runner V8 Limited in the rear? BigK75 4th Gen T4Rs 8 10-24-2009 01:13 PM
Rear suspension on the 5th Gen? PolkManiac 5th gen T4Rs 4 10-20-2009 06:49 PM
Cornfed 1.5" rear spacer Cheap.. & stock rear suspension whoosh Classifieds - buy & sell (no commercial ads please) 1 08-05-2009 11:22 PM
Rear Suspension Question...REAR SWAY BAR LINK? sjr13 Maintenance/Detailing 1 02-25-2009 09:55 AM
