I looked into modifying the switches at one time too, but quickly gave up.
The Auto Up-Down is in the switch, it's controlled by a relay on the switch circuit board. The relay latches when you push the switch all the way down, and unlatches when it senses the amperage draw of the motor spike. (i.e. when it hits the top or bottom.)
The problem is, the panel is not made up of individual switches, the toggles just actuate switches that are on a common control board. You would have to try to figure out a way to add a relay to the control board for each switch that you wanted to add this feature to.
I have some digital pictures if you want to see what the board looks like without taking your door panel apart.
--Mike
2004 4Runner SR5 4WD V8
Stratosphere Mica
- Canadian hood guard
- Homelink
- Scion/Pioneer CD/MP3 stereo
- AUX-BOX Aux input
- TRD Dual Exhaust
