01-22-2012, 01:45 AM
Real Name: Sandman
Real Name: Sandman
Found Rust on the Sunroof Frame
Has anybody found rust on the front of the sun/moon roof frame? I have a 2005 Limited. Along the black leading edge of the frame.
2015 4runner TRD Pro, 2017 Tacoma 4WD,
1983 HiLux 4WD
01-22-2012, 02:37 AM
2007 Shadow Mica Sport Edition V6 4x4
01-22-2012, 09:36 AM
A couple people in here have. I dont think there is a TSB or recall on it, so if youre going to remedy it youre going to have to do it on your own. EIther have it fixed, replaced, or do it youself. Ive taken care of a couple "spots" or decay on my 03. I just broke out the brass bristeled brush, rubbed it down until it was nice n shiney metal, wiped it down with alcohol then immediately put 3 coats of primer, 3 coats of touch-up paint, 3 coats clearcoat.
Good luck!
2003 Sport Edition V8 (sold)
2008 Sport Edition V8 (sold)
2016 Trail - Classic Silver Metallic - 17" Black TRD Wheels w/ BFG All-Terrains
01-23-2012, 02:10 AM
Real Name: Sandman
Real Name: Sandman
Thanks for the information.
Good luck!
1983 HiLux 4WD
01-23-2012, 11:11 AM
Good luck!
I have two small spots on mine. Is it surface rust? If so, I can deal with that, but mine which looks like the pictures in the other link look to be rusting through from the inside. There are no marks or scratches on the paint that would have allowed it to rust.
01-23-2012, 01:08 PM
I tried local Toyotas x 4, and corporate Toyota, and they told me it was more or less and isolated incident, and they don't have a record of it being a wide spread problem. I can honestly say I will probably never buy or use Toyota again, not for warranty work, or anything, from my experiences with them it's all about $, not doing the right thing. too many horror stories from too many people, and seeing first hand how they lie and intimidate the elderly. it's a real shame.
01-23-2012, 05:47 PM
Considering this is the only real issue I have seen with mine being 9 years old now, I don't think it is the end of the world. Obviously there is a design flaw, but I think it is impossible to design a vehicle that is 100% perfect. I guess my main issue is that it is a dealer only part that is very expensive and not easy to replace. I wouldn't have as much of a problem if I could replace it for around $100, but $600 just for the part is a little much. It isn't like a fender that you can neglect. Once that rusts through, you have a leak to deal with.
01-23-2012, 08:11 PM
Don't they all lie, cheat and steal ???, not just toyota.
Burt
2008 SR5 V6 4WD
1984 1/2 GT350 Mustang
2019 F250 SuperDuty
01-24-2012, 12:22 AM
Real Name: Sandman
Real Name: Sandman
How many incidents does it take to become a TSB/Recall... You're right the parts are too expensive to replace even if I do the labor myself...
1983 HiLux 4WD
08-02-2014, 11:27 PM
Rust on Frame of Sunroof x2
I have a 2003 4Runner Limited. I discovered rust on the frame in June 2012. The thing was totally rusted out and crumbling. I was lucky it did not leak. I took it to the local Toyota dealer in Hawaii and they said the same thing - not a common problem. They referred me to a local repair shop who repaired in for around $1200.
Now it is Jul 2014, not even two years later and I have the same problem. Obviously there is some sort of problem with the vehicle that has caused this twice.
I will take it back to Toyota, but I am sure I know what their answer will be.
"Suck it."
08-10-2014, 04:07 PM
Rust on Frame of Sunroof x3
I have a 2003 4Runner Limited also with rust along the leading edge of the sunroof frame. I found it when I tried to clear the drains to prevent the leaking I have been getting inside the cabin. It is so advanced that rusted metal has fallen away and the little pieces are clogging the drains. This is my first major issue with this 12-year old vehicle so it's hard to whine about it but I would really like to get it fixed well enough to get another 5+ years out of it. Has anyone else had experienced and had this repaired? I see that Russman30 has done this in Hawaii but I was hoping for a less expensive solution.
08-10-2014, 07:55 PM
Real Name: Steven
Real Name: Steven
A Toyota TSB has several different purposes.
1. They will issue a TSB when they discover a "better" way for the technician to diagnose, repair, etc a certain component on a vehicle.
2. How to properly perform updates to ECM's, PROMS, radios, etc with the updated firmware versions.
3. When they have redesigned a certain part that is not performing as designed. They will give the technician instructions on how diagnose and determine if this TSB applies. The new part#, procedure to replace part if needing replaced. The warranty coverage period, the OP codes if covered, etc.
99% of the TSB's that they release are only valid on that particular vehicle for the remainder of the 3/36 warranty period. Of course it depends whether it's the drivetrain or such as those warranties are longer.
There's many other reasons for a TSB, but I think you get the idea. A recall on a sunroof that has rust is not gonna happen in a million years. A recall is for safety issues for the most part.
2008 4R LTD V8 4WD, ICON Stage 3, TRD Pro Wheels, GOBI Rack, TRS HID Swap along with too many other mods to list here!
05-06-2016, 04:03 PM
I have rust on my 2008 ForeRunner SR5 and even had the sunroof replaced once. The rust has come right back. I asked the dealer where they put it in at to replace it for free but they would not do it. They did offer to knock down the price from $800 to $425 and I said "No". My service advisor then told to me to call Toyota Customer Care directly. I have a case open with them right now and I am waiting for a reply.
12-31-2016, 01:15 PM
Picked up a 2008 SR5 Sport this week and there was rust on the forward (leading edge) portion of the moonroof glass frame and a portion of the L and R sides. Looks like it started in the forward L and R corners, then spread from there. Rear frame corners, rail and rear portion of the side rails were fine. Picked up a used assembly and just used the glass from it. Now I have an extra assembly and motor if I ever need one.
Based on the drain layout within the assembly I have 2 theories about how this might have happened. 1) Both forward drains became clogged at one time causing the water to pool in the forward corners OR 2) The previous owner regularly backed the vehicle in on a sloped parking space, such as a driveway, putting the T4R at an angle that interfered with the function of the drain system enough to cause rain water to pool towards the front. I'm leaning towards #2 because it seems the odds would be high that both front drains were clogged at the same time for such a long time to result in rust.
12-31-2016, 01:54 PM
Any pictures of the rust? I can't see any around my moonroof but I'd sure like to be proactive if it's somewhere I'm just not seeing.
SOLD 2008 V6 SR5 4X4 @ 165K: 265/70/17 Falken Wildpeak | SPC Racing UCAs | Method NV wheels | Wheeler's T1/T12 springs| Bilstein 5100
2020 Off Road 4X4: 265/70/17 Falken Wildpeak | OME 883/ Wheeler's T13 | Bilstein 5100 | Sprint Booster
