Old 01-22-2012, 01:45 AM #1
92879 92879 is offline
Real Name: Sandman
92879 is an unknown quantity at this point
Real Name: Sandman
Found Rust on the Sunroof Frame
Has anybody found rust on the front of the sun/moon roof frame? I have a 2005 Limited. Along the black leading edge of the frame.
2015 4runner TRD Pro, 2017 Tacoma 4WD,
1983 HiLux 4WD
92879 is offline   Reply With QuoteReply With Quote
Old 01-22-2012, 02:37 AM #2
jimithing jimithing is offline
jimithing is on a distinguished road
Yup.
2007 Shadow Mica Sport Edition V6 4x4
jimithing is offline   Reply With QuoteReply With Quote
Old 01-22-2012, 09:36 AM #3
zerowkul98's Avatar
zerowkul98 zerowkul98 is offline
zerowkul98 is on a distinguished road
zerowkul98's Avatar
A couple people in here have. I dont think there is a TSB or recall on it, so if youre going to remedy it youre going to have to do it on your own. EIther have it fixed, replaced, or do it youself. Ive taken care of a couple "spots" or decay on my 03. I just broke out the brass bristeled brush, rubbed it down until it was nice n shiney metal, wiped it down with alcohol then immediately put 3 coats of primer, 3 coats of touch-up paint, 3 coats clearcoat.
Good luck!
2003 Sport Edition V8 (sold)
2008 Sport Edition V8 (sold)
2016 Trail - Classic Silver Metallic - 17" Black TRD Wheels w/ BFG All-Terrains
zerowkul98 is offline   Reply With QuoteReply With Quote
Old 01-23-2012, 02:10 AM #4
Real Name: Sandman
Real Name: Sandman
Thanks for the information.
Good luck!
1983 HiLux 4WD
Old 01-23-2012, 11:11 AM #5
Sungod Sungod is offline
Sungod is on a distinguished road
Good luck!
I have two small spots on mine. Is it surface rust? If so, I can deal with that, but mine which looks like the pictures in the other link look to be rusting through from the inside. There are no marks or scratches on the paint that would have allowed it to rust.
Sungod is offline   Reply With QuoteReply With Quote
Old 01-23-2012, 01:08 PM #6
08medic4x4's Avatar
08medic4x4 08medic4x4 is offline
08medic4x4 is on a distinguished road
08medic4x4's Avatar
I tried local Toyotas x 4, and corporate Toyota, and they told me it was more or less and isolated incident, and they don't have a record of it being a wide spread problem. I can honestly say I will probably never buy or use Toyota again, not for warranty work, or anything, from my experiences with them it's all about $, not doing the right thing. too many horror stories from too many people, and seeing first hand how they lie and intimidate the elderly. it's a real shame.
08medic4x4 is offline   Reply With QuoteReply With Quote
Old 01-23-2012, 05:47 PM #7
Considering this is the only real issue I have seen with mine being 9 years old now, I don't think it is the end of the world. Obviously there is a design flaw, but I think it is impossible to design a vehicle that is 100% perfect. I guess my main issue is that it is a dealer only part that is very expensive and not easy to replace. I wouldn't have as much of a problem if I could replace it for around $100, but $600 just for the part is a little much. It isn't like a fender that you can neglect. Once that rusts through, you have a leak to deal with.
Old 01-23-2012, 08:11 PM #8
Burt Burt is offline
Burt is on a distinguished road
Don't they all lie, cheat and steal ???, not just toyota.
Burt
2008 SR5 V6 4WD
1984 1/2 GT350 Mustang
2005 F250 SuperDuty 6.0PSD FX4 Lariat
Burt is offline   Reply With QuoteReply With Quote
Old 01-24-2012, 12:22 AM #9
Real Name: Sandman
Real Name: Sandman
How many incidents does it take to become a TSB/Recall... You're right the parts are too expensive to replace even if I do the labor myself...
1983 HiLux 4WD
Old 08-02-2014, 11:27 PM #10
Russman30 Russman30 is offline
Russman30 is on a distinguished road
Thumbs down Rust on Frame of Sunroof x2
I have a 2003 4Runner Limited. I discovered rust on the frame in June 2012. The thing was totally rusted out and crumbling. I was lucky it did not leak. I took it to the local Toyota dealer in Hawaii and they said the same thing - not a common problem. They referred me to a local repair shop who repaired in for around $1200.
Now it is Jul 2014, not even two years later and I have the same problem. Obviously there is some sort of problem with the vehicle that has caused this twice.
I will take it back to Toyota, but I am sure I know what their answer will be.
"Suck it."
Russman30 is offline   Reply With QuoteReply With Quote
Old 08-10-2014, 04:07 PM #11
Baxter386 Baxter386 is offline
Baxter386 is on a distinguished road
Rust on Frame of Sunroof x3
I have a 2003 4Runner Limited also with rust along the leading edge of the sunroof frame. I found it when I tried to clear the drains to prevent the leaking I have been getting inside the cabin. It is so advanced that rusted metal has fallen away and the little pieces are clogging the drains. This is my first major issue with this 12-year old vehicle so it's hard to whine about it but I would really like to get it fixed well enough to get another 5+ years out of it. Has anyone else had experienced and had this repaired? I see that Russman30 has done this in Hawaii but I was hoping for a less expensive solution.
Baxter386 is offline   Reply With QuoteReply With Quote
Old 08-10-2014, 07:55 PM #12
toyo's Avatar
toyo toyo is offline
Real Name: Steven
toyo is on a distinguished road
toyo's Avatar
Real Name: Steven
A Toyota TSB has several different purposes.
1. They will issue a TSB when they discover a "better" way for the technician to diagnose, repair, etc a certain component on a vehicle.
2. How to properly perform updates to ECM's, PROMS, radios, etc with the updated firmware versions.
3. When they have redesigned a certain part that is not performing as designed. They will give the technician instructions on how diagnose and determine if this TSB applies. The new part#, procedure to replace part if needing replaced. The warranty coverage period, the OP codes if covered, etc.
99% of the TSB's that they release are only valid on that particular vehicle for the remainder of the 3/36 warranty period. Of course it depends whether it's the drivetrain or such as those warranties are longer.
There's many other reasons for a TSB, but I think you get the idea. A recall on a sunroof that has rust is not gonna happen in a million years. A recall is for safety issues for the most part.
2008 4R LTD V8 4WD, ICON Stage 3, TRD Pro Wheels, GOBI Rack, TRS HID Swap along with too many other mods to list here!
toyo is offline   Reply With QuoteReply With Quote
Old 05-06-2016, 04:03 PM #13
n4cer0423 n4cer0423 is offline
n4cer0423 is on a distinguished road
I have rust on my 2008 ForeRunner SR5 and even had the sunroof replaced once. The rust has come right back. I asked the dealer where they put it in at to replace it for free but they would not do it. They did offer to knock down the price from $800 to $425 and I said "No". My service advisor then told to me to call Toyota Customer Care directly. I have a case open with them right now and I am waiting for a reply.
n4cer0423 is offline   Reply With QuoteReply With Quote
Old 12-31-2016, 01:15 PM #14
CCDave CCDave is offline
CCDave is on a distinguished road
Picked up a 2008 SR5 Sport this week and there was rust on the forward (leading edge) portion of the moonroof glass frame and a portion of the L and R sides. Looks like it started in the forward L and R corners, then spread from there. Rear frame corners, rail and rear portion of the side rails were fine. Picked up a used assembly and just used the glass from it. Now I have an extra assembly and motor if I ever need one.
Based on the drain layout within the assembly I have 2 theories about how this might have happened. 1) Both forward drains became clogged at one time causing the water to pool in the forward corners OR 2) The previous owner regularly backed the vehicle in on a sloped parking space, such as a driveway, putting the T4R at an angle that interfered with the function of the drain system enough to cause rain water to pool towards the front. I'm leaning towards #2 because it seems the odds would be high that both front drains were clogged at the same time for such a long time to result in rust.
CCDave is offline   Reply With QuoteReply With Quote
Old 12-31-2016, 01:54 PM #15
DEF4Runner's Avatar
DEF4Runner DEF4Runner is offline
DEF4Runner is on a distinguished road
DEF4Runner's Avatar
Any pictures of the rust? I can't see any around my moonroof but I'd sure like to be proactive if it's somewhere I'm just not seeing.
SOLD 2008 V6 SR5 4X4 @ 165K: 265/70/17 Falken Wildpeak | SPC Racing UCAs | Method NV wheels | Wheeler's T1/T12 springs| Bilstein 5100
2020 Off Road 4X4: 265/70/17 Falken Wildpeak | OME 883/ Wheeler's T13 | Bilstein 5100 | Sprint Booster
DEF4Runner is offline   Reply With QuoteReply With Quote
sun moon roof
Frame Rust Buckaroo 3rd gen T4Rs 15 01-19-2016 04:15 PM
To all with frame rot and rust through T4Rscott 3rd gen T4Rs 46 05-25-2014 04:52 PM
Rust on frame and undercarriage eliask08 4th Gen T4Rs 5 08-02-2009 03:30 PM
Frame rust TopRunner 3rd gen T4Rs 0 07-26-2008 11:47 AM
How would I check for frame rust?? perfectmax Classic T4Rs 2 11-22-2005 10:48 PM
