Originally Posted by sr3tlaw
So here I have the heater relay that im to use to the mini fuse tap as described J.A.'s excellent writeup.
Since I have the limted where does the mini fuse tap go? To my understanding, and I quote "if you have a Limited and therefore an IG relay, you can obtain ignition activated 12V+ power at the 25amp seat heater fuse. Just substitute a mini fuse tap for the male disconnect" [B]the two male ends of the fuse tap goes in where? In place of heater relay as I read?[ /B]
First of all with a Limited you are still going to do this...
"Remove the fog light relay located in the engine room relay box and bend prong #2 so that it no longer inserts into its usual location."
BUT since you have a limited and therefore you have a relay in the IG socket you will not be running the other end of the wire to the IG socket or relay to obtain ignition activated 12V+.
Instead you will put the mini fuse tap onto the seat heater fuse. Put it onto the top most leg of the fuse.
Then crimp on a female disconnect to the wire coming off the fog light relay. then simply plug the female disconnect into the male side of the mini fuse tap sticking up out of the seat heater fuse.
Let us know how it goes.
