Old 09-14-2017, 04:30 PM #106
Rodtheviking's Avatar
Rodtheviking Rodtheviking is offline
Real Name: Chris
Rodtheviking will become famous soon enough
Real Name: Chris
Originally Posted by mightyduck View Post
Alright guys...super noob question. I was just looking at the fuse box but I had no idea what was what....I was expecting things to be labeled but it didnt seem like the were.
Is there some master diagram in the manual that you are all referencing or something?
Inside the lid.
2005 V8 Limited. ARB Bumper, ARB Touring rack, Bilstein 5100 with Toytec 3" Tacoma springs, OME 2895's, 255/80 Cooper ST Maxx. TG spacers. JBA UCA.
Rodtheviking is offline   Reply With QuoteReply With Quote
Old 09-15-2017, 01:01 AM #107
mightyduck mightyduck is offline
mightyduck is on a distinguished road
Originally Posted by Rodtheviking View Post
Inside the lid.
cheers dude...I feel like an idiot for not seeing that...
2006 Sport v6 4x4 - 5100/5160 w/ FJ, K&N air filter, XenonDepot 4300k HID, Lamin-x yellow fogs, WeatherTech mats/rain guards, Yakima Whispbar, Plasti Dip badges/grill
mightyduck is offline   Reply With QuoteReply With Quote
Old 09-15-2017, 02:10 PM #108
BADCUDA1 BADCUDA1 is offline
BADCUDA1 is on a distinguished road
There's your sign!
BADCUDA1 is offline   Reply With QuoteReply With Quote
Old 10-15-2017, 04:55 PM #109
MT4runnerEW MT4runnerEW is offline
MT4runnerEW is on a distinguished road
where to tap
I have 04 limited and everything is set for this mod, except there is no room to use the 25A seat header fuse with an add a tap, as the wire hits the closest relay so there is not room. Searched every other fuse that has enough room and they are ALL constant on, not ingition activated. Any other spots within that fuse box, or is there another add a circuit that has the wire in a different direction?
Anyone use the seat fuse with a limited?
MT4runnerEW is offline   Reply With QuoteReply With Quote
Old 10-16-2017, 12:32 AM #110
Ruthven13 Ruthven13 is offline
Ruthven13 is on a distinguished road
I did on on my '03 Limited and yes it was a very tight fit. Just a little creative routing and just brute force i got it to fit just fine. I was afraid I was going to break something but so far it has held up fine. Sorry but I am still a moron and can't figure out how to post pics yet...
2003 galactic grey mica Limited 4x4 V8 X-REAS and rear factory air suspension.
Ruthven13 is offline   Reply With QuoteReply With Quote
Old 10-16-2017, 10:38 AM #111
Thanks Ruthven. I followed your advice and decided to add some force. REALLY tight fit and the wire right at the block is now bent a hard 90 degrees, but it went in and works, so nothing broke. Thanks again. Headlights are nearly useless in heavy snowfall trying to get off a mountain (don't ask how I know). Fogs only should work great.
Old 10-16-2017, 01:05 PM #112
I would just keep an eye on it (I do). I was nervous at first that it wouldn't work just like you but I figured hey, how much can go wrong. The parts are cheap enough to replace if they broke. I just wouldn't move them unless I hd to just in case. Glad it worked out for you. Wish it ws a little neater but ya gotta go what you gotta do. Did you do the stage two of the mod? That part is really simple. I forget if you need a male blade connector for that or not. I noticed if it is loose if you give the end a very slight bend it fits nice and tightly...
Old 04-25-2018, 04:33 PM #113
SaltCity_T4R SaltCity_T4R is offline
Real Name: Brian
SaltCity_T4R is on a distinguished road
Real Name: Brian
So another noob here especially when it comes to electrical but for a limited and taping into 25amp seat heater fuse could I just use a mini fuse tap like this: https://www.superbrightleds.com/more...rcuit-tap/545/ or am I far off and just need to use the taps and gauge wire?
Thanks in advance and sorry for bringing this thread back from the dead.
2003 Limited V8
Last edited by SaltCity_T4R; 04-25-2018 at 04:34 PM. Reason: Picture wouldnt load, put a link in its place
SaltCity_T4R is offline   Reply With QuoteReply With Quote
Old 07-31-2018, 11:07 PM #114
Maxie Maxie is offline
Maxie is on a distinguished road
I just did this on my 04 Limited. On my first try, the prong broke off the relay when I bent it. So, $19 later from Autozone, I tried again. Works great.
I used a "Add a fuse" from Amazon into the seat heater fuse. It was a tight squeeze, but it just about works.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2004 Limited Fog Light Mod by blkwrxwag, on Flickr
Maxie is offline   Reply With QuoteReply With Quote
Old 11-19-2018, 02:46 AM #115
CNI-Steve's Avatar
CNI-Steve CNI-Steve is offline
CNI-Steve is on a distinguished road
CNI-Steve's Avatar
Just did it to mine. Works awesome.
CNI-Steve is offline   Reply With QuoteReply With Quote
Old 12-27-2018, 09:55 PM #116
mugenrios2k mugenrios2k is offline
mugenrios2k is on a distinguished road
ok fog light mod experts....
check my logic here
2019 Electrical schematic attached
Looking at the 2019 diagram we can see that there is still an AND gate that only allows the fog light to receive power when
1) ECU PIN14 is at ground closing the TAIL relay
(AKA ECU senses that the Parking light or Headlights are powered on and then puts pin 14 at ground)
AND
2) ECU PIN 13 is at ground
AKA ECU senses that the fog light switch is the closed position.
Option 1)
Wire the pin on the FR FOG relay Coil that original goes to ECU PIN13 directly to the Fog light switch on the Switched ground side.
By using a relay tap on the relay pin and running a single wire through the main grommet on the fire wall to the fog light switch.
This would
Still allow one to control fog light on or off when the head lights are on likewise fogs would stay on even in hibeam mode.
You would still loose dash light indicator of fog light on/off
Option 2 the simplest MOD...MAYBE)
Wire FR FOG relay coil pin 13 directly to TAIL relay coil pin 14.
This would.
1) Have Fog lights come on and stay on if PARKING lights/or head lights are on regardless of hi/low beam position
2) believe this would result in a situation if you are running AUTO lights that DRLs would still work with Fogs being off while in DRL mode
3) fogs would auto illuminate if in AUTO the ECU decides to turn on headlights.
4) fog light switch would not control fog lights AKA fogs are controlled by headlight switch.
PROBLEM is ( motor off so one can hear relays close)
Sounds like the the tail relay ( TOWING TAIL marked relay) is in the under the hood fuse box; which would make sense since diagram shows 12+power coming in off of a junction connected to the alternator.
AND THE FRFOG RELAY is located behind the DASH....
Independent use of Fog Light Mod-2019-fog-light-jpg
mugenrios2k is offline   Reply With QuoteReply With Quote
Old 06-12-2020, 10:11 PM #117
There is the diagram of the wire setup to make this work to have independent fog lights /retain dash indicator/ retain auto lights/ retain auto off...
Reminder this setup requires that at least the parking lights to be switched to on
This is NOT FOG light on at any time.
To find the correct wires I used a test probe to find the +12V switched coming from the dimmer dial. ( blue doubled dashed line)
and the same probe to figure out the wire coming out of the ECU that is the power supply to the fog lights ( dashed red line)
Independent use of Fog Light Mod-4runner-fog-light-mod-jpg
Old 06-17-2020, 06:42 PM #118
cpwilliams cpwilliams is offline
cpwilliams is on a distinguished road
Unhappy I guess I’m a moron too
Hey guys,
I’m struggling with part 2 of this mod. I didn’t do part one as I just want these for Off road usage while the lights are on. I made a mess of the wiring and clipped wires when I should t have and now am in a jam... my headlights and turn signals work but not my fogs and my headlights don’t auto shutoff now.... any help would be much appreciated.
I’m at a loss as where to go from here...
-CW
Independent use of Fog Light Mod-298471fb-4062-4998-8994-5933b83e129e-jpeg  Independent use of Fog Light Mod-835208ed-dd35-4975-847d-f0fd4d0ece2a-jpeg  Independent use of Fog Light Mod-c8acec3a-ea90-48cc-a63b-96021d4982e0-jpeg
cpwilliams is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 06:44 PM #119
I had to add the blue wire as my red/green wire got too short.
Old 08-02-2020, 05:37 PM #120
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
I did this fog light mod a couple of years ago, but never took pics.
More recently, I added a second (third?) set of fog lights where ditch lights usually go.
The first pic shows all the lights on, DRLs off. The second pic shows just the OEM fogs and the DRLs on, low/high beams both off. My two sets of aftermarket fogs are wired together, and only work when the headlights are on. The PIAA offroad/white driving lights on the roof aren’t connected yet, but I have all the wiring/switches ready to go. That’s my next project after I get rid of all the surface rust on the chassis/undercarriage.
Independent use of Fog Light Mod-a52de2e6-b342-4193-baf3-79ae53210c30-jpg  Independent use of Fog Light Mod-2e1447e2-3516-4199-87d5-5022510a586b-jpg
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Finally! Independent Fog-Light MOD = done. Antman 5th gen T4Rs 31 01-11-2017 09:27 AM
Independent shop @ Lancaster PA slayman 3rd gen T4Rs 6 03-13-2011 08:38 PM
Nissan Independent Suspension swimmer2361 Off Topic 3 11-22-2007 07:24 PM
Independent Suspension crimsonking32 Classic T4Rs 7 05-12-2007 11:22 AM
Independent rear suspension mike4runner 4th Gen T4Rs 3 09-28-2004 06:17 PM
