Old 06-10-2009, 12:12 PM #1
TC4Rnr's Avatar
TC4Rnr TC4Rnr is offline
TC4Rnr is on a distinguished road
TC4Rnr's Avatar
what is the proper way to do coolant flush?
the coolant flush is long over due(120k miles), so I went ahead bought
two jugs of pink Toyota OEM longlife coolant. they are pre-mixed it says on the label "pre-diluted, do not add water".
if I just drain the radiator, there is still plenty of old coolant in the engine block. my question is, how do I get them out?
normally I would just be sticking a water hose in the radiator to flush out them out and put new fluid in. but with the Toyota OEM longlife coolant, there's no way i could do it without further dilute the pre-diluted coolant.
is there an engine block drain hole?
99 SR5 4WD, eLkr(i wish) 3.4V6 5spd.
2019 TRDOR.
2019 Taco ORP 6MT
TC4Rnr is offline   Reply With QuoteReply With Quote
Old 06-10-2009, 01:12 PM #2
kimboy kimboy is offline
kimboy is on a distinguished road
Park on a decline.
Use an empty gallon milk jug and buy some 1/4" tubing from the hardware store.
Attach tubing to the drain valve at the edge of the radiator, and open. (Might want to dip one end of the tubing in warm water for a few seconds to allow for easy fit on the drain valve)
Remove 1 gallon of old coolant, and refill with one of the gallon coolant jugs you have.
Repeat the process the following weekend and you should be good for another 60K miles.
(assuming you have a '03+)
kimboy is offline   Reply With QuoteReply With Quote
Old 06-10-2009, 01:46 PM #3
jeober's Avatar
jeober jeober is offline
jeober is on a distinguished road
jeober's Avatar
Here's a method: Drain the radiator (about 1 gallon); add 1 gallon fresh water, let it heat up and circulate; drain out another gallon.
Repeat this 3 or 4 times until you have mostly clear water in the system. Drain and the last 1 gallon fill should be 100% antifreeze. Since the system is approx 2 gallons, you'll end up with about a 50/50 mix.
You could drain fluid from each side of the block through drain plugs but this is real work.
Clarke
'05 4x2
jeober is offline   Reply With QuoteReply With Quote
Old 06-10-2009, 05:31 PM #4
EH007 EH007 is offline
Banned
EH007 is on a distinguished road
Banned
You should never put plain tap water into your radiator because of the minerals present in it.
Since you already have the pre-mixed Toyota coolant, youl would have to drain and refill several times (after running the engine each time) to ensure that all of the "old" coolant was removed from the cooling system. If you bring your vehicle to the dealer, they'll use a machine that flushes the old stuff out quickly and very efficiently. Either way, it's up to you.
EH007 is offline   Reply With QuoteReply With Quote
Old 06-10-2009, 06:15 PM #5
Kmvreter's Avatar
Kmvreter Kmvreter is offline
Kmvreter will become famous soon enough Kmvreter will become famous soon enough
Kmvreter's Avatar
Beside the concern with using tap water, this method would actually further dilute the already 50/50 mix. I don't think you can get the OEM Super Long Life (SLL pink) as straight coolant, just premixed.
Do as others suggest with a partial change. Check your owner's manual for the actual volume depending on your engine (more than 2 gallons). I change out 1 jug per year as a refresh.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
`(o)_---(o)_--)_)`.........
Kmvreter is offline   Reply With QuoteReply With Quote
Old 06-10-2009, 10:39 PM #6
TC4Rnr's Avatar
TC4Rnr's Avatar
Problem is, when I bought it, owner's manual didn't come with it.
2019 TRDOR.
2019 Taco ORP 6MT
Old 06-11-2009, 11:26 AM #7
jeober's Avatar
jeober's Avatar
Tap water is OK in the radiator.
I don't want any replies to this - I have 28 years of automotive engineering experience, along with 30+ patents in the field -- just consider this as my advice.
Clarke
'05 4x2
Old 06-14-2009, 03:53 AM #8
BlairB's Avatar
BlairB BlairB is offline
Real Name: Blair
BlairB will become famous soon enough
BlairB's Avatar
Real Name: Blair
2008 4Runner Sport Edition 4WD V6- Long Travel, Camping Rig Build Thread
2023 Lexus LX600 F Sport- Daily Driver
2023 Highlander Hybrid Limited- Wife Daily Driver
BlairB is offline   Reply With QuoteReply With Quote
Old 11-24-2016, 10:20 AM #9
Ru44er20 Ru44er20 is offline
Ru44er20 is on a distinguished road
Sorry for bringing up an old thread, but I was planning on doing a coolant flush on my 02 since I just bought it. But like the poster above said, if I run distilled water through the system until its only distilled water and then drain it, will there not be a gallon of distilled left in the system, if so I would be correct in only adding back a gallon of full concentrate toyota red correct?
Ru44er20 is offline   Reply With QuoteReply With Quote
Old 11-24-2016, 10:28 AM #10
Morphyne Morphyne is offline
Morphyne will become famous soon enough
Yes. That is whzt you sant to do. Except for the whole distilled water thing. That is just stupid. There is a reason thzt idiot got banned.
Morphyne is offline   Reply With QuoteReply With Quote
Old 11-24-2016, 04:18 PM #11
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Best way to do it is to simply drain the radiator and the block, then add new coolant and burp the bubbles out.
There's no need to get it "Squeaky" clean as it's a closed system (unless you or the previous owner buggered that up and added anything other than SLLC).
The point here is to drain as much of the old coolant out and put fresh coolant in, it's not about getting every last drop out, but rather getting as much fresh coolant with fresh additives into the system. This is the same thing with transmission fluid, yes it's nice to have it all shiny and fresh, but the idea is to replenish the additives in the fluid which do the majority of the work rather than "clean it all out spotlessly."
There is some truth to avoiding distilled water these days, I am still not entirely convinced yet; but there's some data to show that with how very specific coolants are these days and how much stuff is missing from them on purpose (i.e. silicates bromines, ect) that distilled water flushing can cause an oddball metallurgical reaction that causes accelerated wear/damage if used for flushing in these systems.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 11-24-2016, 07:05 PM #12
07V8's Avatar
07V8 07V8 is offline
07V8 is on a distinguished road
07V8's Avatar
How easy are the block valves on the V8 to get to? Any special adapters needed or will a regular wrench/socket get to them?
2007 V8 Sport Edition: Definitely Not Stock
2014 LX 570: Stock
07V8 is offline   Reply With QuoteReply With Quote
Old 11-24-2016, 08:59 PM #13
jfry008's Avatar
jfry008 jfry008 is offline
jfry008 is on a distinguished road
jfry008's Avatar
You can probably get better feedback in the 3rd gen forum
08' 4Runner SR5 4WD V6 Level 8 MK6 wheels//Kenwood DDX9903s//JL 10W3v3 on 500/1//LEDs//ICON Ext Coilovers FR//Metaltech LT Rear Springs w/ Dobinson LT Shocks//JBA UCAs//spidertrax//5th gen brakes in front//295/70/17 Cooper Maxx//SS brake lines//http://www.toyota-4runner.org/4th-ge...ld-thread.html
jfry008 is offline   Reply With QuoteReply With Quote
Old 11-25-2016, 01:04 AM #14
Shouldn't be too bad to get to, you should be able to access them from the sides if you turn the wheel and pull the rubber splash shields out of the way.
They take a 10mm socket or wrench to loosen (you'll see a spigot looking fixture with a nut on top, you only need to loosen not remove to get it flowing) and a small hose to lead the coolant to a drain pan.
They look like this:
That one is on the Passenger side, the other one will be around the same spot on the driver's side. You can see the hose I have connected to it to help guide the coolant.
Old 05-02-2018, 12:29 PM #15
jamesewells jamesewells is offline
Real Name: Jimmy
jamesewells is on a distinguished road
Real Name: Jimmy
I'm ok with refilling the radiator, but where does the overflow tank fit into the process? Do you fill the overflow container after you have re-filled the radiator? Sorry if this is s dumb question. Gonna change my radiator this weekend...
2003 SR5 V8 2WD, Borla Exhaust, Volante Intake
Stebel Truck Horn, All LED Conversion, Map Light Mod
2014 Scion Touch Screen Radio, Lexus Steering Wheel
Lexus Shift Knob
jamesewells is offline   Reply With QuoteReply With Quote
