Originally Posted by orstevenson
The 6107s don't have the bolt bracket required for the top of the liftgate. How would you take the bracket off the original strut to get it to fit on the insertion joint of the new strut? More generally, How do you remove the old,/original struts from the balls? I"ve broken one 12mm wrench and burned some paint around the ball with a torch trying to get this thing off. Any help? or link to a video on youtube? I can find very few things for my 2004 4Runnner.
Does anyone else have a 4th gen 4runner and find parts that fit 03 or 05 but not 04?
Sorry, just now seeing this.
When the rain stops, I'll take a look at how things are mounted. Don't remember it being that big of a deal. Hardest part is finding a brace you trust to hold up the liftgate while you're swapping parts.
Don't recall transferring any hardware from original strut to the replacement. The OE balls should have a retaining clip, that once released, will let the ball pop off with maybe a little persuasion if there's any corrosion or dirt in the ball socket.
Pretty sure part fitment for the 4th Gen is consistent for all years...nothing special about 2004.
This guy has a video of a Strong Arm 6107 replacement on an '05...admittedly, I didn't watch every second of it, but skipping through seems pretty straightforward...except when he gets out a torch. I definitely didn't need heat or even Liquid Wrench to remove the body side ball posts, assuming they had to be replaced...maybe that's a regional environmental issue, but I do live in a salt air climate.
Toyota Lift Gate Piston Replacement - YouTube
As you can see in the video and on the
Lift Support Depot 6107 Product Page, it does include the liftgate mounting bracket already attached to the strut.
