08-06-2012, 09:08 PM
#16
scotchlock connectors make this ridiculously easy. good mod
2004 sr5 v8 4wd 4runner, leather,
I AM THE SEARCH POLICE!!! USE THE SEARCH BAR FIRST!!!!!!
follow my build at
http://www.toyota-4runner.org/4th-ge...t117-mods.html
08-06-2012, 09:22 PM
#17
thanks
Originally Posted by ChaosStarter
Couldn't you just pull the bulb in the cluster if you didn't want to look at it and not use the system?
The bulb is way too hard to get too - besides I think it is led. This is a very easy fix - just be careful to follow the instructions. Make sure you get the proper wires.
gw
08-06-2012, 09:35 PM
#18
That will work just fine.
Allow plenty of time for the mod.
was: 2005 2wd V8 Limited, one owner (me), 155K miles
now: 2019 Kia Sorento SXL V6
08-06-2012, 10:33 PM
#19
Late update, I tried this mod a few months ago on my 09 V6 TE and the wires are not the same. The pink and black is there but there is no white and black, only grey an black. I tried the scotchlock connector on these wires and my tachometer read zero at idle and fluctuated when revved. Not sure if 09 specific or 4th Gen TE specific. I'd love to lose the tpms light but not at the expense of my tach.
2009 4runner Trail V6, Icon 2.5 Ext travel front CO, Icon 2.0 remote resi rear shock w/ Icon springs, TC UCA, Custom Sway-bar End Links, 1.25" 4crawler BL w/ radiator drop, Cooper Disco AT3 285/70r17, ProComp 7098's, KurtFab diff bracket, Hayden tranny cooler, side-routed exhaust mod, Shrockworks Sliders, Full RCI Metal Works skid plates, Dual-Batteries, Kenwood TS-480HX HF radio, Kenwood TM-D710 VHF/UHF/APRS radio, Husky floor mats.
KJ6QDJ
11-11-2012, 12:14 PM
#20
Measured the current between the wires..
Current was 7 mA - good to go here; and this worked for me. These are small wires so be sure your Scotchlok is able to slice through to the copper core. Mine didn't at first try but I went to plan B.
Thanks
Clarke
'05 4x2
01-23-2013, 01:51 AM
#21
Originally Posted by blk-4runner
Did it on my 07, and it works! Thanks.
Glad to hear it works on the 07! Ill be doing this mod shortly, as I no longer have the stock wheels or tires on...
bump for being super helpful! maybe sticky???
01-23-2013, 12:28 PM
#22
nicee
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto...... sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
01-24-2013, 07:08 PM
#23
Real Name: Chris
Real Name: Chris
Finally did this today, thanks. No Scotchlock for me, just short the wires mentioned.
Chris - '07 SR5
‘05 Limited - sold
02-08-2013, 11:15 AM
#24
Knocked this out using a blue ScotchLock - works like a charm.
Took me all of 15 minutes and no more annoying TPMS light!
2016 Trail Premium - Icon Stage 3 Lift, SSO Sliders, RCI Skids, SSO Slimline Bumper with High Clearance Add-ons (awaiting install), Ryder RR01 wheels (awaiting install), BFG KO2's 285/70/17, Morimoto XB Headlights, and more to come...
SOLD: 04T4R Limited V6 4WD
02-08-2013, 12:45 PM
#25
Tpms
[QUOTE=...... I have been checking my air pressure for 35 years without an ECM telling me I am low, so why start now.]
I to have checked my pressures manually a long time before TPMS. However, one time the light came on while driving and probably saved me from buying a new tire. Sure wish replacements were less expensive.
02-08-2013, 01:01 PM
#26
That's way too complicated! All you need to do is unplug the cable from the TPMS receiver, stick a piece of wire into the connector to disable the warning lamp and ground the other end to the chassis. Then tape up the end and you are done!
04-14-2013, 10:44 AM
#27
Real Name: Mike Davies
That was a ridiculously easy mod to get rid of something that bugged the crap out me. Thanks!
If ignorance is bliss, why aren't more people happy?
04-14-2013, 03:39 PM
#28
Real Name: Leonard
Real Name: Leonard
On the 08 and newer, doesn't have the white/black wire as stated above. So I tried the pink/black wire and taped it to straight ground, no go on this mod. If any one has found the color codes or straight ground please post.
Having fun's build
04-17-2013, 03:41 PM
#29
Real Name: Leonard
Real Name: Leonard
Didn't work, took awile for the light to come back on, still working on it. 08 t4r.
Edit: This did work on the 08, the connector moved around and didn't make a good contact. I moved it around and light went off, moved again and light came back on. SO good to go.
PINK W/ BLACK STRIP AND BLACK W/ RED STRIP WIRES.
Having fun's build
04-24-2013, 04:23 PM
#30
Just did this today. First time since I purchased the vehicle that I haven't had the light on my dash. Dealership I bought it from installed all new sensors, but was still throwing a light on. I have checked my tire pressure for years, so this light is useless to me. Thanks for this!
-2013 T4R SR5-MYSALSA-KO2's
-(SOLD)2006 T4R SR5. Nautical Blue Metallic. 255/70/17 General AT2. LED Interior Swap. Toytec Ultimate 3inch lift/Icon 2.0s Rear, SHROCKWORKS Front Bumper, OEM FJ wheels, WM Roofrack, slowly working it up. My Build thread HERE
-(SOLD)2005 Subaru Impreza WRX STi. BMW Mica Blue paint job. Cobb stage 2 tuning. Other modifications.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
