Originally Posted by stevec5000
That's way too complicated! All you need to do is unplug the cable from the TPMS receiver, stick a piece of wire into the connector to disable the warning lamp and ground the other end to the chassis. Then tape up the end and you are done!
I used your idea and another members to simply remove the module altogether. I have a 08' so the wiring is slightly different, black/pink wire and black/maroon, but used a jumper wire at the end of the connector and taped it up. No more annoying warning light.
Many thanks for the numerous ideas.
