txt4r
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 04-20-2019, 10:38 PM #316
evbiz evbiz is offline
evbiz is on a distinguished road
I did exactly this on my 06 4Runner v8 Ltd and worked as described. TPMS light was glowing solid and now does not. I have always checked my TP on a regular basis so I do not need to worry about this annoying warning TPMS light in my face.
evbiz is offline   Reply With QuoteReply With Quote
Old 04-30-2019, 08:42 PM #317
PotatoDelta's Avatar
PotatoDelta PotatoDelta is offline
Real Name: David
PotatoDelta is on a distinguished road
Real Name: David
I may do this eventually but at the moment it doesn't really bother me
2004 4Runner Limited, V8 4x4
Resonator Delete
PotatoDelta is offline   Reply With QuoteReply With Quote
Old 06-25-2019, 03:41 PM #318
bspurs bspurs is offline
bspurs is on a distinguished road
Easy!
Finally remembered to do this on my 07 Sport. Only took 5 minutes. I chose to use a small paperclip to jump the 2 wires in case I/future owner ever want to reverse it.
- Did not need to disconnect the battery
- Unplugged yellow-taped harness (no need to cut the tape)
- Located pink/black and white/black wire
- Inserted end of paperclip into the tiny holes that correspond with the pink/black and white/black wire.
- Covered fully in electrical tape just to be sure.
- Left unplugged.
Solid TPMS dash light is OFF!
Current: 2007 4Runner Sport 4x4 V6 - 120,000 miles - stock for now...
Former: 1998 4Runner Limited 4x4 - 118,000 miles - TRD Tundra/5100 front, OME 906/5100 rear - Plastidipped exterior emblems - Black painted interior woodgrain
bspurs is offline   Reply With QuoteReply With Quote
Old 09-10-2019, 01:14 PM #319
MDPensFan MDPensFan is offline
MDPensFan is on a distinguished road
This was sooo easy! Thanks OP. No more flashing TPMS light for me.
MDPensFan is offline   Reply With QuoteReply With Quote
Old 09-11-2019, 09:05 AM #320
Billynath1988's Avatar
Billynath1988 Billynath1988 is offline
Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about
After 5 years I finally did this.. in the 30 seconds it took me to do it.. im pretty mad I waited 5 years..
1 screw under glove box.. unwrap yellow tape... unwrap black wire cover.. splice white/black stripe and pink/black stripe with wire merge clip.. reinstall screw.. done..
2005 4Runner SE V8
http://www.toyota-4runner.org/4th-ge...-v8-build.html
Billynath1988 is offline   Reply With QuoteReply With Quote
Old 10-14-2019, 08:06 PM #321
originalg00kster's Avatar
originalg00kster originalg00kster is offline
originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough
Woo, wish I would've done this a year ago!
07 SR5 4x4
originalg00kster is offline   Reply With QuoteReply With Quote
Old 12-16-2019, 01:43 AM #322
Aquila105 Aquila105 is offline
Aquila105 is on a distinguished road
Thank you
Thank you!
Aquila105 is offline   Reply With QuoteReply With Quote
Old 01-13-2020, 11:08 AM #323
GoBucks! GoBucks! is offline
GoBucks! is on a distinguished road
- Left unplugged.
I tried to do this (except with the pink/black and black/red wires) with my '08 V8 Limited and couldn't get it to work. I even tried it with the pink/black and white/black wires just to be sure.
A couple of ideas:
1) Will the TPMS light be off immediately when starting the vehicle, or does it take a while for it to reset after this operation?
2) I couldn't get the paperclip (any of them) to go in and engage/grab in the harness, even with a lot of force. They just went in a bit and kind of just sat there, so it felt like I wasn't making proper electrical contact. I even tried safety pins to get a sharp entrance point and got the same result. Maybe the gauge is too big on a paper clip?
What gives? Thanks!
2008 4Runner Limited V8
GoBucks! is offline   Reply With QuoteReply With Quote
Old 01-13-2020, 06:17 PM #324
MRpink's Avatar
MRpink MRpink is offline
MRpink is on a distinguished road
MRpink's Avatar
Finally got around to doing this. I followed another member’s recommendation and used a piece of CAT 5 as a jumper wire. Jumped from the back of the connecter and kept everything plugged in. Super simple job and easily reversible.
2007 Limited 4WD V6 | Bilstein 5100 | Wheeler's T1/T12 Springs | FJ Wheels | BFG KO2 | Build Thread
MRpink is offline   Reply With QuoteReply With Quote
Old 03-03-2020, 05:15 PM #325
oh24runner oh24runner is offline
oh24runner is on a distinguished road
This worked perfect, couldn't have been easier.
oh24runner is offline   Reply With QuoteReply With Quote
Old 07-14-2020, 06:17 PM #326
804Hokie's Avatar
804Hokie 804Hokie is offline
804Hokie is on a distinguished road
804Hokie's Avatar
I decided to run the bypass on my ‘08. I just didn’t see any reason to spend a chunk of change on 2 defective sensors. My tire gauge works just fine, and drivers have been using them for decades.
804Hokie is offline   Reply With QuoteReply With Quote
Old 07-16-2020, 09:48 AM #327
804Hokie's Avatar
804Hokie's Avatar
So it seemed to do the trick the past 2 days. But now the light comes on sporadically.
Old 07-16-2020, 01:50 PM #328
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
Sounds like a bad contact on your bypass somewhere...
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 07-16-2020, 02:11 PM #329
804Hokie's Avatar
804Hokie's Avatar
I’m going to look it over again. It seems prone to coming on more frequently at highway speeds
Old 09-06-2020, 05:18 PM #330
Meticode Meticode is offline
Meticode is on a distinguished road
I have a 2007 Toyota 4Runner Limited (V6). I can confirm that this bypass works exactly as described. I went to Ace Hardware and bought this wire splice connector tap...
https://www.acehardware.com/departme...uit/lugs/34567
...followed the directions and the pictures looked exactly like what I saw when I dropped the black panel down to see the control modules. I unplugged the module (didn't unplug the battery), peeled back the yellow tap, cut off that once I had it peeled back far enough to work with the wires, I pushed back the black insulation around the wires and cut off the extra insulation with some multi-tool scissors, used that splice connector (make sure both wires are fully in each channel, used pliers to push that splicer down to cut the wires, pushed the plastic snap fastern down until it clicked to lock it on, plugged back in the wires into the module, buttoned everything back up and the light is gone once I started the truck.
It's so nice now since I had my OEM rims sandblasted and refinished with two coats of gloss black and 1 coat of gloss clear coat. I put regular rubber valve stems back in so I don't have to worry about those stupid sensors anymore.
Meticode is offline   Reply With QuoteReply With Quote
TPMS light bypass switch Kmvreter 4th Gen T4Rs 84 07-28-2023 07:31 PM
TPMS Disable 05Rrunner 4th Gen T4Rs 13 06-13-2011 06:48 AM
TPMS Disable for 5th Gens Tgrds 5th gen T4Rs 0 04-26-2010 10:38 PM
Disable TPMS, mybenje 4th Gen T4Rs 8 02-19-2009 10:41 PM
TPMS Disable dheeter 4th Gen T4Rs 0 11-18-2008 01:50 PM
