Old 03-02-2012, 03:34 PM #1
Nuke's Avatar
Nuke Nuke is offline
Nuke will become famous soon enough
Nuke's Avatar
VSC Off, Check Engine light and the traction control squiggly thing again...
I left my gas cap off the other day when I filled up and then drove to work the next morning. After work, the darned lights came on. I had these same lights once before about 30k miles ago and the dealership couldn't find any problem and said it was likely that I hadn't tightened the gas cap and they reset the code/lights. I recall being able to reset codes by pulling the EFI fuse in my 3rd gen. Anyone know how to clear the code/lights on the 4th?
Rick
'90 T4R - sold at 205,000 miles
'00 T4R - sold at 152,000 miles
'08 Sport - 178,000 miles & still going strong
'19 ORP - just over 6,000 mi. (garage queen, like my '07 Mustang)
Nuke is offline   Reply With QuoteReply With Quote
Old 03-02-2012, 03:37 PM #2
DC runner DC runner is offline
DC runner is on a distinguished road
It takes a certain time and it will go off on its own. Give it a couple days.
DC runner is offline   Reply With QuoteReply With Quote
Old 03-02-2012, 03:41 PM #3
paquitox's Avatar
paquitox paquitox is offline
paquitox is on a distinguished road
paquitox's Avatar
Had the same issue a week after I bought it, scare the ****t out of me. Took it to the dealer and they clear it plus some pressure loss on m tires.
05 SR5 V6 4x4 | DS 2.5/1.5 | BFG KO 265/70/R17 | Spidertrax 1.25" | BAMF rock sliders | Plastidip wheels/grill | LED interior swap | More to come
paquitox is offline   Reply With QuoteReply With Quote
Old 03-02-2012, 03:56 PM #4
sonerick's Avatar
sonerick sonerick is offline
Real Name: Nick
sonerick is on a distinguished road
sonerick's Avatar
Real Name: Nick
disconnect the battery for a few mins to clear the codes. if they come back on, then get them scanned at Autozone or something.
sonerick is offline   Reply With QuoteReply With Quote
Old 03-02-2012, 03:58 PM #5
Morals Morals is offline
Morals is on a distinguished road
+1
Just had to do this after getting a new gas cap.
I waited about 4 days and the code wasn't clearing. I didn't wanna disconnect it because I had my stereo head unit (aftermarket) adjusted just how I wanted it, but duh, no biggie, I just wrote down the settings and reprogrammed.
It's been about a week and no codes. *knocks on wood*
Morals is offline   Reply With QuoteReply With Quote
Old 03-02-2012, 04:06 PM #6
Nuke's Avatar
Nuke's Avatar
Yeah, I figured it would clear on its own eventually but there HAS to be some way for the owner to clear it manually. At least I know now that pulling the EFI fuse on the 4th gen doesn't work...
Rick
Old 03-02-2012, 04:13 PM #7
mrpanic7's Avatar
mrpanic7 mrpanic7 is offline
mrpanic7 is on a distinguished road
mrpanic7's Avatar
Can anyone confirm if this is the same as what happens when shops use OBD scanners and reset the "0" point setting for VSC?
mrpanic7 is offline   Reply With QuoteReply With Quote
Old 03-02-2012, 04:27 PM #8
mrpanic7's Avatar
mrpanic7's Avatar
Here is what you need
http://www.toyota-4runner.org/proble...libration.html
Old 03-02-2012, 04:30 PM #9
mbraider808 mbraider808 is offline
mbraider808 is on a distinguished road
The zero point calibration could be a possibility if an aftermarket obd2 scanner was used. I had all three lights come on before too. But mine was cause my O2 sensor was bad. But i had to do a zero point calibration due to my use of the scanner and the fact that only the check engine light turned off after the change. But if its jist the gass cap just give it a little time with driving and start ups. Should go off on its own.
mbraider808 is offline   Reply With QuoteReply With Quote
Old 03-02-2012, 04:58 PM #10
Nuke's Avatar
Nuke's Avatar
Originally Posted by mbraider808 View Post
... if its jist the gass cap just give it a little time with driving and start ups. Should go off on its own.
That's what I'm banking on at this point.
Rick
Old 03-02-2012, 05:10 PM #11
Well if not. Let me know i cam walk you through a zero loint calibration as well. Easy to do and dont cost more than a few dollars
Old 03-02-2012, 05:17 PM #12
core212 core212 is offline
core212 is on a distinguished road
I can tell you from personal experience just this week! I live in NY and had to take my car in for inspection. It didn't pass because I had used an OBDII scanner to reset the codes.
After that happens, you have to run the car through a series of drive cycles and check with the scanner again to see if they're good. This is the case whenever you reset anything using an OBDII on a Toyota.
After about 50 miles or so, everything checked out and went back for the inspection.
My case was the same, three EVAP codes all because of a faulty gas cap. I confirmed that the cap was faulty because it didn't have any spring tension when taking it off. It should have a little kickback to it and it didn't. I ordered another one on ebay for $15 and good as new.
core212 is offline   Reply With QuoteReply With Quote
Old 03-02-2012, 07:25 PM #13
sonerick's Avatar
Real Name: Nick
sonerick's Avatar
Real Name: Nick
a zero point calibration has nothing to do with resetting evap CEL codes thrown by a loose gas cap. this link does not belong in this thread. a zero point calibration is used to tell your skid control computer that the yaw sensors are at 0.
Nuke, just pull the negative terminal on the battery for a few seconds. It'll clear the codes and won't even throw off your head unit's presets. I had to do it several times while I was troubleshooting my gas cap issue.
Old 03-03-2012, 12:35 AM #14
Undo battery, doesn't cost anything.
Old 03-04-2012, 09:30 PM #15
Nuke's Avatar
Nuke's Avatar
Update
After approximately 150 miles in about 3 days time, the lights have reset as I had hoped. Thanks for all the input.
Rick
Check Engine + VSC OFF + VSC Traction lights all came on?! Bamboozler 3rd gen T4Rs 6 01-24-2017 04:40 PM
vsc, vsc off, traction control light, check engine lights Dunk50 General Discussions 1 10-26-2011 06:22 PM
Maint light and traction control? A_HuL 4th Gen T4Rs 2 08-31-2011 01:46 PM
'08 4Runner check engine/vsc/traction control lights Ant3_16 4th Gen T4Rs 2 03-11-2009 12:32 AM
VSC and Traction Control both de-throttle engine.. JB. 4th Gen T4Rs 16 12-23-2007 11:59 AM
