03-05-2012, 03:24 PM
6'10" height limit
I have a height limit of 6'10", I have '06 V6 sport. What suspension and wheel options do I have? I would like to also have a low profile rack but this isn't critical.
03-05-2012, 04:54 PM
What is the stock height of your Runner? If it's is 6'5 I'd say you should go with 4" or less of lift (1" of insurance). Simple math really, just give us a starting point to work with and you'll receive many bias lift options, haha.
03-05-2012, 05:10 PM
I used to live in a condo complex with underground parking, height limit was 6'7". My truck has a 3" toytec kit on 33" tires, and a rola rack on top of the stock rack, which is at least 2-3". I cleared the 6'7" bar by about 1.5". I'm pretty sure you'll be fine with any lift + rack at a 6'10" clearance. Just Do It!!!
2007 4Runner SR5 4.7L 4WD, Toytec Ultimate kit, 285/75-16 BFG KM2's, TRD rims, UrbanRunner rack, SE hood, couple other little things here and there
03-05-2012, 05:28 PM
Yeah - measure the runner, its actually quite short. I forget exactly, but I thinkbits only like 69-72'' or something stock (depending on Limited/SR5/Sport). This puts it at only like 6' stock, giving you 9'' to work with on suspension + tires (again with 1'' insurance). Should be PLENTY. If you go higher than that, I'd be very surprised.
- Sent via Tapatalk for Android
2006 T4R SR5 v8 4wd: Napa Ultra Premium Rotors; Weather Tech liners; AVS Ventshades; Westin Bull Bar; Hydrocarbon Delete; Blackhoused Headlights; Fog Light Mod; Sulfer TSB; Magnaflow 22" Muffler (#12586); Front: Bilstein 5100's set at .85" + Toytec 1" Net "Top1-T" Spacer = 2" total Front Lift; Rear: Cornfed 1" + Air Lift 1000; Plasti-Dip center grill + rear Toyota Emblem; JVC Bluetooth + HD Radio HDR81BT
http://www.toyota-4runner.org/new-me...purchased.html
03-05-2012, 05:44 PM
I'm 6'3 and I can see over my 05 SR5 4runner. I'd be surprised if it's over 6'.
03-05-2012, 07:36 PM
I'm at about 7" lift (including tires) from stock.
I can clear a 7' garage door depending on the shape of the upper crest. If its flat then yes, arched then no.
Can't fit in my garage at home though unless i air down the tires
But its a good thing ;]
6" Lift| Icon LT Front & Rear Shocks | All Pro 3.5 rear springs| SPC front UCA's | All Pro rear LCA's| MetalTech rear UCA's| Extended end links| RB body lift | Bump stop drop | Diff Drop | 4.88's | K&N CAI| Flowmaster Catback exhaust | Tranny cooler | Holley Fuel injection System | Bored out Cylinders | Doug Thorley Headers | NGK Irridium Plugs | 35x12.50/20 Toyo MT's | 20x9 Raceline Raptors | Extended Brake lines| 8k H.I.D's headlights/fogs| 100wtt PA system| 2 12" JBL subs | Alpine Deck| Alpine speakers | De-Badged | 10% tinted windows| High-lift jack| All LED Conversion | Royal Purple guts|
03-05-2012, 08:57 PM
Edmunds.com shows 71.3" or just under 6' for the SE. That's a lot of room to play with.
2007 SportEdition V6 4WD Galactic Gray
Found on the trails of the Colorado front range
Daystar 2.5/1.5, Rear Diff Breather Mod, TRD Brake Pads, Full Synthetic 90w-135 Gear Lube, 265/70/17 Duratracs, Cobra 75, 3' Firestik, Refrigerated Console
Toyota Expert Tech/Lexus Certified Tech/ASE Master Tech
03-06-2012, 11:13 AM
i see on edmunds 71.6" that measure its to the roof or to the roof rack?
03-06-2012, 11:17 AM
That's the rack height.
03-06-2012, 11:37 AM
so i can take out the rack and have more room to lift?
03-06-2012, 11:42 AM
The only way to know for sure is to measure.
Lay a board across the roof/rack and measure to the ground. Do this in a few places on the roof.
Remember that if there is a dip or a hump near the low opening, you will need extra space.
2000 4runner Sport, SAS/4wheel Underground 3 link, Diamond axle, 14" Radflo coilovers, double locked, Custom rear 3 link, 12" Fox shocks, full armor Gerdo's Build Thread
Real Fuel Tank Skidplates for sale Lil' Skip's OffRoad
Rear control arm mount skids and Hi-Lift adapter for sale Lotus Development
03-06-2012, 11:43 AM
i ask for the rack measure because have low low clereance in my house...
03-06-2012, 01:29 PM
On mine I think the spoiler is the highest spot fyi.
03-06-2012, 02:03 PM
spoiler highter than roof rack? thats weir.. or dont have the rack ? ahahhaha
03-06-2012, 08:48 PM
Ha yeah, spoiler sticks up if you look at it.. If I remember it was very close between the spoiler and the highest part of the SR5 rack.
I was measuring because I only have so much garage clearance, and am deciding on a lift..
