you are on the right track...the access port is where you get into the latch...problem is, you cannot see what you need to do..you have to cut the plastic film and then find a way to pull the latch lever. here is a picture
the circled part is the lever, the other red part is the latch....NOTE..this picture is sideways the right side is the bottom.
hope this helps..
