Old 03-09-2012, 02:58 PM #1
michaelreed's Avatar
michaelreed michaelreed is offline
michaelreed is on a distinguished road
Michael's Build Thread
On the lot:
Current:
Tires! Finally!
Suspension
OME 3" lift
Tires/Wheels
17" sr5 wheels
Goodyear Duratrac LT285/70/17
All pro 1.5" spacers
Offroad
Shrockworks front bumper (coming in a month or two if I don't buy any toys between now and then...)
Outfitting/Electronics
Cobra 75 wx st
Diamond k400 antenna mount
Firestik 4' antenna
Additional 12v outlet added to dash
Pioneer avic f90bt
Axe and Shovel mounted on rear hatch
Blacked out emblems and grille
Well it's nothing fancy yet.. Should look pretty mean after I get my tires and bumper though!
Edit: tires are on! Spacers tomorrow.
michaelreed is offline   Reply With QuoteReply With Quote
Old 03-09-2012, 04:43 PM #2
Runner27's Avatar
Runner27 Runner27 is offline
Runner27 is on a distinguished road
Runner27's Avatar
Originally Posted by michaelreed View Post
I like your blackout grille and emblem.
I'm planning on painting the tailgate garnish next weekend. Going to remove it from the car, sand, prime, enamel black paint, and enamel clear coat.
Is it easy to remove the tailgate panel and the garnish?
Runner27 is offline   Reply With QuoteReply With Quote
Old 03-09-2012, 04:58 PM #3
Fairly easy. Remove both access panels. Unscrew tailgate lanyard. Carefully pry the pins out all the way around. Slide the trim forward off the window. Start to pull the yellow water barrier and then cut through the rtv with a razor blade (you can reuse it, it will heal itself back together. Remove 4 nuts on the panel and 2 for the lock. Unplug the only wiring harness. After that it should just pop off.
Old 03-09-2012, 05:08 PM #4
Runner27's Avatar
Runner27's Avatar
thanks for the info. you were still able to close the tailgate while the piece was removed right?
Old 03-09-2012, 05:21 PM #5
superman3043's Avatar
superman3043 superman3043 is offline
Real Name: PD
superman3043 will become famous soon enough superman3043 will become famous soon enough
Real Name: PD
DO NOT close the tailgate while your harness is unplugged....
Trust me ;)
-PD
2005 V8 SR5 4WD Natural White
My Build Thread
My "Rally Rocket" 2017 WRX
superman3043 is offline   Reply With QuoteReply With Quote
Old 03-09-2012, 05:30 PM #6
What he said ^^ I just put a towel between the lock to make it look like it was closed while the plasti dip dried.
Old 04-24-2012, 03:40 PM #7
rsingh rsingh is offline
rsingh is on a distinguished road
Looks like you have the stock tires on with the lift. Do you think it the tires look too small or does it like fine? I just got a 3/2 lift but I won't be able to afford tires for a long time. Just wondering should I even bother putting the lift on with stock 265/65/17 tires on my rig or does it look weird?
2004 4runner V6 SR5- Slowly adding these parts ...Bilstein 5100's, OME 886/895, All Pro 1.5 inch wheel spacers, Spec D Chrome HID projector headlights, 6000K DDM HID kit, Fog light Mod, 3000k Hid Fogs, Hella 500ff Offroad lights, Get rid of Orange Color gauge and cluster for whit and blue, Rola Rack, Sport Hood, Satoshi Grille, 06+ taillights, Shrockworks Rock Sliders, Darkest window tint possible.
rsingh is offline   Reply With QuoteReply With Quote
Old 04-24-2012, 03:59 PM #8
Red's Avatar
Red Red is offline
Real Name: Ryan
Red is on a distinguished road
Red Red is offline
Red's Avatar
Real Name: Ryan
Just wondering why you bothered to remove the pieces that you plasti-dip'd? The whole reason people use plasti-dip is it requires very little prep work, all you had to do was mask off a rectangle around the parts you wanted black and just layer on the plasti-dip then peel off what you didnt want to be black.
if you were painting it then I'd understand going through all that extra work.
2007 Toyota 4Runner Limited V8 4x4
|Goodyear Duratrac 275/65R18|Daystar 2.5F RAS Adjusted Rear|1.25" Spidertrax|BM Chop|WeatherTech Floor Liners|28% Tint|LED Interior/Exterior Swap|4300k HID's|"Black Series" Projector Lenses|Jet Yellow Fogs|Pioneer AVH-P8400BH|Airaid Synthamax|HCF Delete|
Red is offline   Reply With QuoteReply With Quote
Old 04-24-2012, 05:14 PM #9
I'll be getting 33s in a month or so, but no I don't think it looks weird. Still looks better than stock imo.
My Build Thread
OME 3" lift - LED swap - Cobra CB and Firestik Antenna - Plastidipped Grill
Old 04-24-2012, 05:16 PM #10
Because that panel is easy to get off, and I didn't want to get plasti dip in the lock mechanism. Didn't really feel like dealing with overspray either. If I was doing the emblems or something where its hard to take of and put back on, then yeah I would just mask and peel.
My Build Thread
Old 05-05-2012, 10:14 PM #11
gaterose's Avatar
gaterose gaterose is offline
Real Name: Matt
gaterose will become famous soon enough gaterose will become famous soon enough
gaterose's Avatar
Real Name: Matt
The new tires look great!
2017 Tacoma TRD OR - His
2014 4Runner Limited - Hers
'13 Silverado Z71 - Sold
'03 4Runner UnLimited - Sold
gaterose is offline   Reply With QuoteReply With Quote
Old 05-05-2012, 10:49 PM #12
Thanks man! I think it's filled out so much better.
My Build Thread
Old 05-14-2012, 02:50 AM #13
darkie3495's Avatar
darkie3495 darkie3495 is offline
Moderator
darkie3495 will become famous soon enough
Moderator
darkie3495's Avatar
Here are a few pics from our latest outing.
Photo courtesy of Tony LT1:
Kevin's 2008 4x4 Build Thread
Perkins Performance | Shrockworks | Demello | BudBuilt | ICON | Warn | Overland Warehouse | Goodyear | Lightforce | Spidertrax | Powertank | Complete LED Conversion
darkie3495 is offline   Reply With QuoteReply With Quote
Old 05-14-2012, 10:30 AM #14
Casper421's Avatar
Casper421 Casper421 is offline
Real Name: Chris
Casper421 is on a distinguished road
Casper421's Avatar
Real Name: Chris
Looks like a good time!
Gotta ask, what's with the new blue color for the 4runners? Painters tape?
2007 SE V8
HID's, interior LED mod, sweet floor mats, awesome tunes and some more stuff...
...more stuff
Casper421 is offline   Reply With QuoteReply With Quote
Old 05-14-2012, 10:37 AM #15
gaterose's Avatar
Real Name: Matt
gaterose's Avatar
Real Name: Matt
I was just wondering the same thing
Nice pictures though, looks fun!
A10MileHusker's 4th Gen Build Page A10MileHusker 4th Gen T4Rs 247 07-17-2017 01:25 PM
Sam's Build Thread... I AM SAM 5th gen T4Rs 87 11-13-2012 08:51 PM
rfc's build thread rfc 4th Gen T4Rs 6 01-17-2011 12:23 PM
My build thread Kirby Engines / Suspension / Wheels / Tires / Audio / Accessories 22 02-08-2007 11:02 PM
