Originally Posted by Acidmeld
Camber 0.0
Caster 2.2-2.5 (the more, the better)
Toe 0.3
If the tech can't get these numbers he's being lazy.
yeh, he must be lazy...
there is no guarantee theres enough adjustment after a lift.
EVERY vehicle is different.
it might be, that from the factory, it required just a tiny bit more adjustment one way, than the other to bring it into spec. if thats the SAME direction its needed after a lift, guess what, you wont have enough.
also slightly different ride heights, different frame flex, or HOW the rig has been used also comes in to play.
by all means, if you dont trust the alignment guy, go somewhere else.
