Out of the blue I could smell something coming from the back of my 4runner. I noticed the rear drivers brake rotor was super hot. When I spit on it, it sizzled.
I took it apart today and the caliper depressed like normal, the pad were still 70% or better but glazed (assuming from heat)
I checked for play in the wheel bearing and it didnt have any movement other than a little slop left to right which I assume is normal.
I adjusted the parking brake all the way out, and then tightened it up little by little until the rotor fit on snug.
Installed new pads and tested it out.
Same issue.
I think tomorrorw morning im going to replace the caliper and back the ebrake all the way out to see if that can isolate the problem.
Is there something common with these 4th gens that I should know about?
I did search and read a few threads where people had simliar issues, but never posted a result of fix.
Thanks in advance for your help.
and a pic of my 4runner for your time
