Alright guys I have a 03 Limted 4Runner. I want to mod it. Things I have in mind are leveling it, bigger tires and rims, and maybe a lift. Problem is I don't know anything about lifts. Help me out by telling me what to do and suggestions. Tell me about sizes also.
The FJ springs (do a search on which ones you want) and the Bilstein 5100's (set @ .85") are a good place to start if you want it leveled and a minor lift... It really makes the truck look better and it handles just fine if you had the X-reas, better if you had the stock shocks/springs. I went up one tire size, stock rims, but that was before the lift. I'd like maybe one size larger if I could get them in the well.
Other than some replacement LED bulbs in the running boards and inside the truck, and HIR blubs in the headlamps, I haven't done anything.
Weathertech floormats all around are a must IMHO, nobody's flormats compare.
I have the same runner as you I totally did away with the x reas suspension and did a full 3" ome lift kit you have 3 choices for stiffness soft medium hard I did soft in front medium in rear and it handles like a sports car
