03-27-2012, 01:29 PM
Vibration on slow acceleration
I know there are a lot of threads about vibration when accelerating, but I can't seem to find any that sound similar to my issue.
I have a 2005 Limited with 145k miles and have just recently begun experiencing what I would call a light vibration, which I can feel in the steering wheel, when slowly accelerating. It feels as though it is coming from the front end, but I'm not positive. It occurs at around 30 to 35 MPH. It only lasts a few seconds if I keep accelerating. I do not feel the vibration at all if I quickly accelerate. There is no vibration when slowing down.
I have had the tires balanced, but the vibration is still present.
03-27-2012, 01:37 PM
v8 or v6? Could be a engine mount or other physical vibration elimination device. The v8 has a large counter weight and I would imagine if that was bad you would notice it.
The V6 will have a more noticeable engine vibration and if a mount or other isolation device (body mount) is bad you might be noticing it.
It could also be the tranny. At low speeds, the torque and engine vibration are resonating through the tranny?
Just a couple of suggestions.
03-27-2012, 01:46 PM
It is a v6.
Would a bad engine mount be visible noticeable?
03-27-2012, 02:05 PM
Usually. Like I said, I am just spit balling. Your power steering system could be bad. I know that the power steering pump is under pressure and that you need the system the most the slower you go. You could be getting some feedback in the steering system from it.
If a mount were bad, then yea, sometimes you can see the engine "hop" in the bay. Other times, if it is just weak... then you can't see anything. If the engine is slightly out of balance.. you can feel but not see it.
I guess this is a time where you just have to start eliminating things.. you know. Does it get worse or go away in gear?? At acceleration or without? If it is vibrating and you crank the wheel, what does it do?
03-27-2012, 02:46 PM
DC is right...this is going to be very difficult to diagnose over the internet.
Could be motor mount...could even be tire out of round...
Power steering system is a good guess too.
03-27-2012, 02:49 PM
My internet diagnosis is bent wheel or bad tire. Both conditions can happen even with a good wheel balance.
04-10-2012, 05:48 PM
Exact same problem
Your description s sounds exactly like what is happening to my '05 SR5 - started about a month ago and has gotten noticeably worse. As with you, it doesn't happen when I accelerate quickly.
I have a good friend that is a mechanic for a toyota dealer and he and a coworker determined that it is something that they haven't figured out how to repair and said out will require a new or rebuilt transmission. they said they've had a few of them doing the same thing in the past and tried to replace the torque converter but that didn't solve it. They had no other answers for me.
I'm desperate to find out what is the culprit and how to repair it.
Let me know if you come across any other answers, good luck
07-24-2012, 10:53 PM
I too am now having similar symptoms... It only happens while accelerating, most often between 25-30mph. It seems to be coming from the passenger front. The only difference in mine is that I can't feel it so much through the steering wheel, mostly the whole front end. I had not noticed this at all until the day after a big rain and we were driving through a bunch of deep water, (sometimes at speed ) At no time during the drive did I feel / hear anything terrible happen, but starting the day after, this vibration is now a daily occurrence.
The vibration only lasts a few seconds and then stops. I will be trying to use my GoPro to film the suspension / engine bay components to see if i can determine what might be causing the problem.
Anyone else have any ideas?
07-25-2012, 03:54 AM
Real Name: 660hp/488tq Evo X
What about driveshaft bearings...aka u joints.
Need lights???...Text me @ 3054239215
IG: @CREVOZ_X
07-25-2012, 08:31 AM
When waa the list time u grease up all the zerk fittings?
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
07-29-2012, 12:08 PM
I just purchased the 4R in May 2012, so I haven't greased the zerks on the drive shafts yet. I'll try that this weekend. There's also no noise or clunk coming from the car, just a deep vibration. It feels as if I'm going over washboard for a few seconds even when the road is completely flat.
I looked at the drive shaft and there doesn't seem to be any missing balancing weights. I'll also check my tie-rods - but again the steering wheel doesn't shake at all.
I really want to get this figured out cause it's making me crazy
How would I tell if the motor mounts are bad - I assume visual inspection to look for cracks or deformity?
07-29-2012, 12:17 PM
Have you ever had the transmission serviced? If not, it may help to have it serviced and checked. It could be a transmission problem.
2006 Toyota 4Runner SR5 V8 4x4-Nautical Blue Metallic
1986 Toyota MR2 AW11 NA 5 Speed
NJshadow93's 2006 SR5 Build
07-31-2012, 12:43 AM
I have not had the transmission serviced since I purchased it. When I purchased it, with 51k miles, the service record at the dealer said they did a full transmission flush.
Other updates, I thought maybe a wheel weight was knocked off or something, but I just got new wheels / tires and the problem persists
Next step will be the driveline lube, and I'm going to try and get more footage of the wheels / driveline while driving with the GoPro.
White 2007 Toyota 4Runner SR5 4x4 V6. OW 2.0" full kit, LR UCA's, 17" Level8 Guardians - BFGoodrich Mud-Terrain T/A KM2 285/70-17
07-31-2012, 01:51 AM
If you put it in 4WD does it still happen? What about 4LO? Does it still happen if the center diff is locked?
Does it get better or worse if you're turning left/right or no difference?
2004 Sport Edition V8 in "rare" Titanium Metallic
~165k miles, 2nd owner since 99k miles.
08-02-2012, 01:39 PM
So 4WD Hi doesn't change anything - it still happens / feels the same. I haven't tried 4Lo at 35mph, so not sure then.. It seems to only happen when going straight, or at least I haven't been cornering too much at 30-35mph. Also if I accelerate quickly then it doesn't seem to do it at all.
I'm going to lube the zerks and go get an alignment and I'll report back.
PS: First forum post: I've been lurking for a long time and have had countless questions answered by searching! Thanks to everyone who contributes to this forum and makes it a great community. I hope to contribute what I learn along the way!
