Originally Posted by MikeInNH
Is you check-engine light on??
The VSC light is on...but couldn't tell if the check-engine light is on.
First thing I'd do is determine what is causing the flashing and illuminating warning lights.
Good call, I just noticed those myself. Very likely has something to do with an electronic system detecting an error condition. All vehicles with modern ATs have "limp home" modes that are enabled if a safety threshold is not met. I suspected TPMS at first because it's the light that jumped out at me, but you're right, VSC/TRAC lights are on, which indicate a problem. I have since checked documentation for my '08, and there's nothing in the TPMS section that indicates slow response with low tire pressure.
On these cars, VSC/TRAC lights go on for many different conditions, and all of them can affect the ECU's decisions on how to run. Best is to get the diagnostic codes on the car to find out what is going on. Fix the problem, and the car will, in all likelihood, return to normal operation. The way it's responding, to me, indicates that this is all at the direction of an electronic system. As there are no mechanical parts that are involved in your vehicle responding this way, it has to be electronic.
