Old 04-05-2012, 08:06 PM #1
popalzai popalzai is offline
popalzai is on a distinguished road
is leaking CV boot part of powertrain warranty
I was just going through powertrain warranty details for 2007 4runner it says
for front wheel drive system the parts covered are
final drive housing and all internal parts,axle shafts,drive shafts,CV joints, front hub,bearings,seals and gaskets..
now my 4runner is still under powertrain warrannty and like at 44K miles dealership recomended that CV boots should be changed as these are leaking grease and i got all 4 CV boots replaced and charge was around 800$...should this be under warranty? and should i go back to dealer ship and ask them for refund?
popalzai is offline   Reply With QuoteReply With Quote
Old 04-05-2012, 08:13 PM #2
black_120 black_120 is offline
black_120 is on a distinguished road
at this point since you've already paid, you'll need to submit a claim to the warranty co. Is it a Toyota warranty or 3rd party?
06' 4runner 2wd v6 w/excess pee wheels
black_120 is offline   Reply With QuoteReply With Quote
Old 04-05-2012, 08:15 PM #3
it is toyota powertrain warranty which is 60k miles or 5 years.so you think that leaking CV boot should be covered under warranty?
Old 04-05-2012, 09:43 PM #4
08T4R 08T4R is offline
08T4R is on a distinguished road
Power train usually referrs to any internally lubricated part. Mine has the Toyota cpo warranty, and I remember reading that disclosure. I'm sure it can be found on the Toyota owners site, or a quick message to Toyota can give you a definite answer..
But to me the cv boot would be a seal, so I would think it was covered.
08 Blizzard Pearl UR 4wd
08T4R is offline   Reply With QuoteReply With Quote
Old 04-05-2012, 09:54 PM #5
thanks for the answer also can you please give an idea on
Rear wheel bearings
and steering assembly like sliding yoke and shaft
Old 04-05-2012, 10:16 PM #6
NJshadow93's Avatar
NJshadow93 NJshadow93 is offline
NJshadow93 is on a distinguished road
NJshadow93's Avatar
I had an aftermarket warranty that did not cover the leaky book. It said the same thing yours says "CV joint" but that literally means just the axle, such as if a malfunction would occur. I believe mine specifically said CV boots weren't covered. I don't remember now.
2006 Toyota 4Runner SR5 V8 4x4-Nautical Blue Metallic
1986 Toyota MR2 AW11 NA 5 Speed
NJshadow93's 2006 SR5 Build
NJshadow93 is offline   Reply With QuoteReply With Quote
Old 04-05-2012, 10:20 PM #7
TheTuckerTaxi's Avatar
TheTuckerTaxi TheTuckerTaxi is offline
TheTuckerTaxi is on a distinguished road
I had all of my boots replaced under CPO warranty and it wasn't too bad, something like $100-$200. I would definitely go talk to them.
2006 Sport Edition V6 4x4
OME 884 + Superflex | 275/65/18 Goodyear Duratracs | Lightforce UCAs | Midland 75
TheTuckerTaxi is offline   Reply With QuoteReply With Quote
Old 04-05-2012, 11:39 PM #8
Thanks for reply..
Old 04-06-2012, 10:54 AM #9
cparise's Avatar
cparise cparise is offline
cparise is an unknown quantity at this point
cparise's Avatar
Originally Posted by popalzai View Post
Thanks for reply..
yes cv boots are covered its part of the shaft which is part of the drivetrain....plus when they refused to fix it under warranty you should of told them ok ill just keep driving until all the grease leaks out and the cv joints fail then you can put in new shafts which would cost them more....
cparise is offline   Reply With QuoteReply With Quote
Old 04-06-2012, 11:35 AM #10
Rear wheel bearings
The bearings should be covered since they are inside the axle housing. Not too sure about the steering assembly, since that's technically not part of the powertrain.
Lifetime Powertrain Warranty Grizzld 5th gen T4Rs 9 02-23-2012 07:58 PM
Is this covered under POWERTRAIN WARRANTY????? 2007 4runner 4th Gen T4Rs 16 02-07-2011 10:42 PM
Powertrain warranty on used 2001 domstriker 3rd gen T4Rs 9 04-27-2010 12:59 AM
Powertrain warranty coverage question. TC3racerM11 Problems & Warranty Issues 0 05-05-2009 10:45 AM
Chrysler Announces Lifetime Powertrain Warranty Thai Comparisons & Reviews 14 02-01-2008 08:12 AM
