installed sony nav. now 4 runner wont start
Last night i installed a Sony double din with nav in the 2005 Toyota 4 runner limited.
The factory unit is a non-nav JBL. I used the PAC TATO JBL interface harness. I connected The park brake wire to Pin #1 of 24-pin plug on front of dash fuse panel, L.GN wire. I did not hook up the speed input or reverse, I also did not buy the harness for steering wheel controls.
Everything was working fine and i had the vehicle running. then i took the dash back apart to run the cable for the nav module.
when i got it all back together and turned it on the sony unit shuts down if i honk the horn/step on break/turn the heat/ac fan on. etc. and the vehicle also won't start.
I noticed when i reconnect the battery the DRL flash twice but i can't seem to find what that means
Any help would be apprectated.
