Old 03-05-2021, 09:42 PM #646
momo.75's Avatar
momo.75 momo.75 is offline
Registered User
Real Name: Morris
momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of momo.75 has much to be proud of
Registered User
momo.75's Avatar
Real Name: Morris
Did a thing....lol
momo.75 Build ThreadClick to order T4R.ORG Decals • @urban_overland
momo.75 is offline   Reply With QuoteReply With Quote
Old 03-06-2021, 11:51 AM #647
montijo505's Avatar
montijo505's Avatar
Originally Posted by momo.75 View Post
Did a thing....lol
In, until you get a patch made.
Old 04-19-2021, 10:06 AM #648
Seabee27 Seabee27 is offline
Real Name: Seabee
Seabee27 is on a distinguished road
Real Name: Seabee
A few weeks ago i worked on mounting the SwitchPros switch panel on my center console. I was really please with the results. Leave it to @TiN to come up with an even better solution. He sent me one of his prototype mounts for the SP unit. I received the mount, backing plate, threaded rods and nuts.
Mounting couldn’t be any easier. Just pop out the three blanks in the console, put the switch in the mount with the threaded rods installed. Place the mounting plate on the underside of the console piece amd thread the nuts. It fits the contours of the console perfectly. Go check out @solid shiftconcepts for some of his other cool pieces.
Thanks for the amazing work Trevor. Check out his site for some other cool pieces. solidshiftconcepts.com
Momo,
I am also setting up a Switch Pro (SP9100,) and after looking throughout the whole toyota-4Runner.org looking on how people setup their SPs in a 4Runner 4th Generation, I came across your posting. And, I have a few questions regarding your setting.
1) What holes did you use to pass the controller and trigger wires thru the firewall?
2) How many trigger wires did you passed thru? I understand the ignition wire does not have to pass thru the firewall, at difference from the 5th Gen, ours has the ignition fuse in the engine compartment.
I love what you have done to your rig, I've been closely following your blog for inspirations. I just pulled the trigger on the SP9100, and I love the way you set it on the center console!
3) Would you be able to take a few snap shots of that section of the setting?
Looking forward for your response
Seabee27 is offline   Reply With QuoteReply With Quote
Old 04-19-2021, 02:12 PM #649
momo.75's Avatar
Registered User
Real Name: Morris
Registered User
momo.75's Avatar
Real Name: Morris
I appreciate that. We ran the wire from the controller through the firewall to the main unit. We just ran it through right above the pedals. I did run the positive wires for the side and rear lights through the cabin and through the firewall in the same location. For those lights we ended up making a grounding bar in the rear so we didn't have to run the negatives all the way forward. What part were you wanting pictures of?
Old 04-19-2021, 02:47 PM #650
Real Name: Seabee
Real Name: Seabee
It's a great idea to make a ground bar in the back, instead of running ground wires all the way to the front.
I don't need pictures now. Your explanation clarified my concerns
Thanks!
Old 04-19-2021, 07:16 PM #651
momo.75's Avatar
Registered User
Real Name: Morris
Registered User
momo.75's Avatar
Real Name: Morris
If you have one of those Fish Tape things it makes it much easier to push it through the firewall. If you have any other questions feel free to reach out. I am not the best at wiring. I had a buddy help me with it all but I was there helping out so I remember most of what we did.
Old 04-20-2021, 10:48 AM #652
Real Name: Seabee
Real Name: Seabee
I made my own power tray in AutoCad and a laser cutter and this is what came out:
momo.75's '03 Sport 4.7L V8 Build-img_4729-jpg  momo.75's '03 Sport 4.7L V8 Build-img_4732-jpg  momo.75's '03 Sport 4.7L V8 Build-img_4736-jpg  momo.75's '03 Sport 4.7L V8 Build-img_4738-jpg
Old 04-20-2021, 10:54 AM #653
Real Name: Seabee
Real Name: Seabee
I had to modified the design a couple times, since it did not fit well when I closed the hood. Soon, I will install the power tray, and follow your instructions to pass the wires through the firewall into the cabin. I'll post a few pictures once is installed
Old 04-20-2021, 01:56 PM #654
momo.75's Avatar
Registered User
Real Name: Morris
Registered User
momo.75's Avatar
Real Name: Morris
That looks great! I had the same problem so we ended up mounting the brain under the tray
Old 04-29-2021, 08:45 PM #655
momo.75's Avatar
Registered User
Real Name: Morris
Registered User
momo.75's Avatar
Real Name: Morris
I had ordered some 3" decals through a special a while back but they were just a little too small. I just got some new ones in that are 3.5" tall. If interested shoot me a pm. $5 a piece shipped to lower 48
Old 04-29-2021, 08:51 PM #656
montijo505's Avatar
montijo505's Avatar
I’ll take one!
Old 11-12-2021, 04:15 PM #657
momo.75's Avatar
Registered User
Real Name: Morris
Registered User
momo.75's Avatar
Real Name: Morris
I finally took the short amount of time to install my diff breather courtesy of @montijo505 . I really appreciate it. The easy to install Blais Bros Taco kit has been sitting on my work bench for a while. It has everything you need. Thanks man!
Old 01-03-2022, 11:55 PM #658
momo.75's Avatar
Registered User
Real Name: Morris
Registered User
momo.75's Avatar
Real Name: Morris
Santa brought me a pair of STEDI 7” Type-X Sport lights. The craftsmanship of these lights is second to none. Starting with the top notch packaging i knew they had to be good.
The only issue i had was the mounting space on the top of my Demello Offroad bumper. Because the grill on the 4th gen opens with the hood i had to reverse the mounting brackets to push them out a little from the grill.
They are complete secured with the STEDI Anti Theft nuts and bolts. I will try to get some output pics but from what I have tried so far it doesn’t do them justice.
Old 01-16-2022, 09:38 PM #659
November Sun November Sun is offline
November Sun is on a distinguished road
Originally Posted by montijo505 View Post
I’ll take one!
I'll take a couple of those stickers. It'll look good on my back window and
compliment your old rack.
November Sun is offline   Reply With QuoteReply With Quote
Old 01-16-2022, 10:35 PM #660
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Lights look good. Any issues with your winch? Im looking at the smittybilt 9500 as my next purchase
Lignum's build thread: 2000 Sport Lignum 3rd gen T4Rs 88 10-22-2019 03:22 AM
hungwin jza80's Build Thread - 2001 Sport Blk/Oak hungwin jza80 3rd gen T4Rs 189 07-11-2017 08:45 AM
ZachAttack's Build Thread - 2004 Sport Edition ZachAttack 4th Gen T4Rs 133 12-28-2013 02:35 AM
Starting My build 02 Sport. Recommend me a wheel size! ar1five 3rd gen T4Rs 12 11-04-2011 04:50 PM
My Build Thread - 04 Sport V8 T4Rsoldier04 Gallery 24 04-30-2008 12:25 PM
